[PATCH rtems-libbsd v2 0/3] MicroBlaze AXI Ethernet Support
Alex White
alex.white at oarcorp.com
Wed Feb 23 21:15:23 UTC 2022
On Mon, Feb 14, 2022 at 7:40 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 10/02/2022 23:12, Alex White wrote:
> > v2:
> > - Reworked patches to follow CONTRIBUTING.md guide
> > - Excluded unneeded vmem calls
> > - Moved ethernet frame alignment handling to the network interface driver
> > This patch set adds support for Xilinx's AXI Ethernet IP core. It has
> > been tested both in QEMU and on the KCU105 board using the default
> > FPGA implementation from the Xilinx's KCU105 PetaLinux BSP.
> The patch set in general looks good. For which libbsd branch is this
> import? From which FreeBSD commit did you import the driver code?
Hi Sebastian,
This is for the 6-freebsd-12 branch.
The driver code came from commit 0d1c391 which is the current commit pointed to by freebsd-org in the 6-freebsd-12 branch.
These changes rely on some of Chris's changes that were committed to the 6-freebsd-12 branch with no current plan to merge to the master branch. This means that these changes will also have to live on the 6-freebsd-12 branch until all of it can be brought over.
Alex
