[PATCH v1 1/5] cpukit/libdebugger: Avoid missed swbreak removal
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Feb 15 20:38:44 UTC 2022
It is possible to remove software breaks without actually restoring the
original instruction to memory. When this happens, the original
instruction is lost. This ensures that when a software break is removed,
its original instruction is restored.
cpukit/libdebugger/rtems-debugger-target.c | 16 ++++++++++++++++
1 file changed, 16 insertions(+)
diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
index 04b274909b..c298a62357 100644
--- a/cpukit/libdebugger/rtems-debugger-target.c
+++ b/cpukit/libdebugger/rtems-debugger-target.c
@@ -191,6 +191,22 @@ rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr, DB_UINT kind)
if (loc == swbreaks[i].address) {
size_t remaining;
if (!insert) {
+ if (target->breakpoint_size > 4)
+ memcpy(loc, swbreaks[i].contents, target->breakpoint_size);
+ else {
+ switch (target->breakpoint_size) {
+ case 4:
+ loc[3] = swbreaks[i].contents[3];
+ case 3:
+ loc[2] = swbreaks[i].contents[2];
+ case 2:
+ loc[1] = swbreaks[i].contents[1];
+ case 1:
+ loc[0] = swbreaks[i].contents[0];
+ break;
+ rtems_debugger_target_cache_sync(&swbreaks[i]);
--target->swbreaks.level;
remaining = (target->swbreaks.level - i) * swbreak_size;
memmove(&swbreaks[i], &swbreaks[i + 1], remaining);
2.30.2
