[PATCH v1 1/5] cpukit/libdebugger: Avoid missed swbreak removal
Thu Feb 17 19:17:52 UTC 2022
On 16/2/22 7:38 am, Kinsey Moore wrote:
> It is possible to remove software breaks without actually restoring the
> original instruction to memory. When this happens, the original
> instruction is lost.
Should this....
> This ensures that when a software break is removed,
> its original instruction is restored.
be...
This ensures a software break is removed and the original instruction is restored.
>  cpukit/libdebugger/rtems-debugger-target.c | 16 ++++++++++++++++
>  1 file changed, 16 insertions(+)
> diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
> index 04b274909b..c298a62357 100644
> --- a/cpukit/libdebugger/rtems-debugger-target.c
> +++ b/cpukit/libdebugger/rtems-debugger-target.c
> @@ -191,6 +191,22 @@ rtems_debugger_target_swbreak_control(bool insert, uintptr_t addr, DB_UINT kind)
>      if (loc == swbreaks[i].address) {
>        size_t remaining;
>        if (!insert) {
> +        if (target->breakpoint_size > 4)
> +          memcpy(loc, swbreaks[i].contents, target->breakpoint_size);
> +        else {
> +          switch (target->breakpoint_size) {
> +          case 4:
> +            loc[3] = swbreaks[i].contents[3];
> +          case 3:
> +            loc[2] = swbreaks[i].contents[2];
> +          case 2:
> +            loc[1] = swbreaks[i].contents[1];
> +          case 1:
> +            loc[0] = swbreaks[i].contents[0];
> +            break;
> +        rtems_debugger_target_cache_sync(&swbreaks[i]);
>          --target->swbreaks.level;
>          remaining = (target->swbreaks.level - i) * swbreak_size;
>          memmove(&swbreaks[i], &swbreaks[i + 1], remaining);
