NTP client recommendation for RTEMS?
Sebastian Huber
Fri Feb 18 13:46:23 UTC 2022
On 18/02/2022 14:43, Joel Sherrill wrote:
> On Fri, Feb 18, 2022, 7:22 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> I would like to add an NTP client support for RTEMS. The ntp_adjtime()
> implementation is already available as a patch. For testing purposes I
> ported the NTP daemon from FreeBSD to libbsd. This basically works
> fine.
> I am not sure about the maintenance status of this code
> (https://www.ntp.org/ <https://www.ntp.org/>). There is also
> https://www.ntpsec.org/ <https://www.ntpsec.org/>
> This project has a public Git repository and seems to be more active.
> However, there is no standard package for openSUSE Leap 15.3. Maybe
> this
> is because most Linux users use now timesyncd from systemd. Any
> recommendations?
> I'd stick with ntp.org <http://ntp.org> without much thought. With that
> being what FreeBSD uses, it is icing on the cake.
The code looks not that good. There seems to be a lot of cleanup done in
ntpsec.org.
> Did you eliminate use of signals like Chris had to do with ptpd?
Not yet, they use both select(), but this should be changed to use
kqueue(). I hacked away the use of signal.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
