NTP client recommendation for RTEMS?
Fri Feb 18 13:43:08 UTC 2022
On Fri, Feb 18, 2022, 7:22 AM Sebastian Huber <
> Hello,
> I would like to add an NTP client support for RTEMS. The ntp_adjtime()
> implementation is already available as a patch. For testing purposes I
> ported the NTP daemon from FreeBSD to libbsd. This basically works fine.
> I am not sure about the maintenance status of this code
> (https://www.ntp.org/). There is also
> https://www.ntpsec.org/
> This project has a public Git repository and seems to be more active.
> However, there is no standard package for openSUSE Leap 15.3. Maybe this
> is because most Linux users use now timesyncd from systemd. Any
> recommendations?
I'd stick with ntp.org without much thought. With that being what FreeBSD
uses, it is icing on the cake.
Did you eliminate use of signals like Chris had to do with ptpd?
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
