RTEMS 5 GNAT/Ada
Mon Feb 21 16:28:18 UTC 2022
On 21/02/2022 17:20, Joel Sherrill wrote:
> On Mon, Feb 21, 2022 at 5:28 AM<dave at synergy.org>  wrote:
>> Hello,
>> Is there a current Quick Start/Ada document for version 5?  I've chased some
>> older versions.  I have a running C/C++ environment, but I'd like to convert
>> over to Ada.
> Building the tools only requires adding --with-ada to the RSB line you used
> to build C and C++ tools.
> https://docs.rtems.org/branches/master/user/rsb/project-sets.html
To build the RTEMS tool suite with --with-ada you need a native GNAT
installed with exactly the same GCC major version.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
