NTP client recommendation for RTEMS?
Joel Sherrill
joel at rtems.org
Tue Feb 22 19:30:46 UTC 2022
On Tue, Feb 22, 2022 at 1:21 PM Sebastian Huber
> On 22/02/2022 19:22, Joel Sherrill wrote:
> > Are you planning to get the NTP server side of the freebsd-org code working?
> > Or get it building but not testing it?
> > Or just focusing on building and testing JUST the client part.
> I ported the ntpd from FreeBSD to an older version of the libbsd. I only
> tested the client part and this seems to work fine after some basic tests.
OK. That matches what I expected. Is the libbsd version to old to merge
against? Any plans to merge this?
Alternatively, is your work available to be used as the basis for updating
to 6-freebsd-12?
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
