NTP client recommendation for RTEMS?
Tue Feb 22 19:45:19 UTC 2022
On 22/02/2022 20:30, Joel Sherrill wrote:
> On Tue, Feb 22, 2022 at 1:21 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> On 22/02/2022 19:22, Joel Sherrill wrote:
>>> Are you planning to get the NTP server side of the freebsd-org code working?
>>> Or get it building but not testing it?
>>> Or just focusing on building and testing JUST the client part.
>> I ported the ntpd from FreeBSD to an older version of the libbsd. I only
>> tested the client part and this seems to work fine after some basic tests.
> OK. That matches what I expected. Is the libbsd version to old to merge
> against? Any plans to merge this?
> Alternatively, is your work available to be used as the basis for updating
> to 6-freebsd-12?
I have a very long TODO list. Actually, I started with the current
6-freebsd-12 branch, but it didn't work, so in principle generating
patches for this branch should be easy.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
