New validation test suites
Sebastian Huber
Wed Feb 23 09:17:50 UTC 2022
Hello Chris,
I added a --diff option to the spec2modules.py script in
rtems-central.git. You can now unpack a release archive of
rtems-central.git and then do the following:
1. Unpack the RTEMS release archive to "modules/rtems".
2. Unpack the RTEMS documentation source release archive to
"modules/rtems-docs".
3. Run "./spec2modules.py --diff". This command will output the
differences between the specification point of view of the sources and
the actual sources (or nothing).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
