NTP client recommendation for RTEMS?
Joel Sherrill
joel at rtems.org
Wed Feb 23 16:56:05 UTC 2022
On Wed, Feb 23, 2022 at 9:03 AM Sebastian Huber <
> On 22/02/2022 21:25, Joel Sherrill wrote:
> > On Tue, Feb 22, 2022, 1:45 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 22/02/2022 20:30, Joel Sherrill wrote:
> > > On Tue, Feb 22, 2022 at 1:21 PM Sebastian Huber
> > >> On 22/02/2022 19:22, Joel Sherrill wrote:
> > >>> Are you planning to get the NTP server side of the freebsd-org
> > code working?
> > >>> Or get it building but not testing it?
> > >>> Or just focusing on building and testing JUST the client part.
> > >> I ported the ntpd from FreeBSD to an older version of the
> > libbsd. I only
> > >> tested the client part and this seems to work fine after some
> > basic tests.
> > > OK. That matches what I expected. Is the libbsd version to old to
> > merge
> > > against? Any plans to merge this?
> > > Alternatively, is your work available to be used as the basis for
> > updating
> > > to 6-freebsd-12?
> > I have a very long TODO list. Actually, I started with the current
> > 6-freebsd-12 branch, but it didn't work, so in principle generating
> > patches for this branch should be easy.
> > Thanks. If we end up working on this, we will sync with you to help and
> > avoid duplicate work.
> I pushed the NTP work to my github repository:
> https://github.com/sebhub/rtems-libbsd/tree/6-freebsd-12-ntpd
> Right now it doesn't work. The test program ntp01.exe crashes after some
> time. I don't have time to look into this in the next weeks.
Thanks. We'll see who can get to it first.
> I think we
> have to revert some changes done for the NFS support. For example, I
> don't know why the system call support for kqueue and the sockets moved
> to a separate file and was changed to use the FreeBSD file descriptors.
This would be a conversation with Chris. I know he had good reasons. I
remember some of those being that it enabled other functionality down
the road.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
