[PATCH rtems-libbsd v2 0/3] MicroBlaze AXI Ethernet Support
Thu Feb 24 07:16:09 UTC 2022
On 23/02/2022 22:15, Alex White wrote:
> On Mon, Feb 14, 2022 at 7:40 AM Sebastian Huber<sebastian.huber at embedded-brains.de>  wrote:
>> On 10/02/2022 23:12, Alex White wrote:
>>> v2:
>>> - Reworked patches to follow CONTRIBUTING.md guide
>>> - Excluded unneeded vmem calls
>>> - Moved ethernet frame alignment handling to the network interface driver
>>> This patch set adds support for Xilinx's AXI Ethernet IP core. It has
>>> been tested both in QEMU and on the KCU105 board using the default
>>> FPGA implementation from the Xilinx's KCU105 PetaLinux BSP.
>> The patch set in general looks good. For which libbsd branch is this
>> import? From which FreeBSD commit did you import the driver code?
> Hi Sebastian,
> This is for the 6-freebsd-12 branch.
> The driver code came from commit 0d1c391 which is the current commit pointed to by freebsd-org in the 6-freebsd-12 branch.
Ok, good.
> These changes rely on some of Chris's changes that were committed to the 6-freebsd-12 branch with no current plan to merge to the master branch. This means that these changes will also have to live on the 6-freebsd-12 branch until all of it can be brought over.
The update to a newer FreeBSD version (for example 13 or 14) will be
done from the master branch. Everything which is not present on the
master branch will be lost during an update. All the contributions from
embedded brains are on the 6-freebsd-12 and master branches.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
