[PATCH 1/2] cpukit/aarch64: Keep state across context switch
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Feb 25 23:41:43 UTC 2022
This may also be an issue for ARM, RISC-V and others as it doesn't
appear that ARM saves CPSR during context switch and I couldn't tell
that RISC-V does this either, though I'm less familiar with it.
Kinsey
On 2/25/2022 17:33, Kinsey Moore wrote:
> If a task migrates to a newly turned-up CPU as the first task it
> executes, no guarantees are made about whether interrupts are enabled
> and it is possible for a task to change interrupt enable states during
> the migration. This preserves interrupt state across context switches.
> cpukit/score/cpu/aarch64/cpu_asm.S | 4 ++++
> cpukit/score/cpu/aarch64/include/rtems/score/cpu.h | 7 ++++---
> 2 files changed, 8 insertions(+), 3 deletions(-)
> diff --git a/cpukit/score/cpu/aarch64/cpu_asm.S b/cpukit/score/cpu/aarch64/cpu_asm.S
> index 2379698336..4234b428aa 100644
> --- a/cpukit/score/cpu/aarch64/cpu_asm.S
> +++ b/cpukit/score/cpu/aarch64/cpu_asm.S
> @@ -83,6 +83,8 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> stp fp, lr, [x0, #0x50]
> mov x4, sp
> str x4, [x0, #0x60]
> + mrs x5, daif
> + str x5, [x0, #0x78]
> #ifdef AARCH64_MULTILIB_VFP
> add x5, x0, #AARCH64_CONTEXT_CONTROL_D8_OFFSET
> @@ -151,6 +153,8 @@ DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
> ldp fp, lr, [x1, #0x50]
> ldr x4, [x1, #0x60]
> mov sp, x4
> + ldr x5, [x1, #0x78]
> + msr daif, x5
> ret
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> index e1d9f0a5c2..2f252bf2f4 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> @@ -127,16 +127,16 @@
> #define AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET 0x70
> - #define AARCH64_CONTEXT_CONTROL_D8_OFFSET 0x78
> + #define AARCH64_CONTEXT_CONTROL_D8_OFFSET 0x80
> #endif
> #define AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 0x68
> #ifdef RTEMS_SMP
> #if defined(AARCH64_MULTILIB_VFP)
> - #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0xb8
> + #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0xc0
> #else
> - #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x78
> + #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x80
> #endif
> #endif
> @@ -174,6 +174,7 @@ typedef struct {
> uint64_t register_sp;
> uint64_t isr_dispatch_disable;
> uint64_t thread_id;
> + uint64_t daif;
> uint64_t register_d8;
> uint64_t register_d9;
