[PATCH 2/2] cpukit/aarch64: Add Per_CPU_Control accessor
Kinsey Moore kinsey.moore at oarcorp.com
Mon Feb 28 13:30:28 UTC 2022
On 2/26/2022 12:50, Gedare Bloom wrote:
> this part looks ok
Thanks, I'm going to hold off on committing this part because the
optimization shaved enough time off of task execution that it exposed
the bug described in the other patch which is why they're bundled.
Kinsey
> On Fri, Feb 25, 2022 at 5:51 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
>> Add an architecture-specific implementation for
>> _CPU_Get_current_per_CPU_control() to reduce overhead for getting the
>> current CPU's Per_CPU_Control structure.
>>   .../cpu/aarch64/include/rtems/score/cpuimpl.h | 23 +++++++++++++++++++
>>   1 file changed, 23 insertions(+)
>> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
>> index 90fd48ad4e..ffdef2f30a 100644
>> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
>> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
>> @@ -125,6 +125,29 @@ typedef struct {
>>     uint64_t register_fpcr;
>>   } CPU_Interrupt_frame;
>> +#ifdef RTEMS_SMP
>> +static inline
>> +struct Per_CPU_Control *_AARCH64_Get_current_per_CPU_control( void )
>> +  struct Per_CPU_Control *cpu_self;
>> +  uint64_t value;
>> +  __asm__ volatile (
>> +    "mrs %0, TPIDR_EL1" : "=&r" ( value ) : : "memory"
>> +  /* Use EL1 Thread ID Register (TPIDR_EL1) */
>> +  cpu_self = (struct Per_CPU_Control *)(uintptr_t)value;
>> +  return cpu_self;
>> +#define _CPU_Get_current_per_CPU_control() \
>> +  _AARCH64_Get_current_per_CPU_control()
>> +#endif /* RTEMS_SMP */
>>   void _CPU_Context_volatile_clobber( uintptr_t pattern );
>>   void _CPU_Context_validate( uintptr_t pattern );
>> 2.30.2
>> devel mailing list
>> devel at rtems.org
