[PATCH 13/27] sapi/src/*.c: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:05:58 UTC 2022
Updates #3053.
cpukit/sapi/src/chainappendnotify.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/chaingetnotify.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/chaingetwait.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/chainprependnotify.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/chainprotected.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/cpucounterconverter.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/delaynano.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/delayticks.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/exinit.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/exshutdown.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/extensioncreate.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/extensiondelete.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/fatal.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/fatalsrctext.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/getversionstring.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/interrtext.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/io.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/ioclose.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/iocontrol.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/ioinitialize.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/ioopen.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/ioread.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/ioregisterdriver.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/iounregisterdriver.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/iowrite.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/profilingiterate.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/profilingreportxml.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/rbheap.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/rbtree.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/rbtreefind.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/sapirbtreeinsert.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/tcsimpleinstall.c | 25 ++++++++++++++++++++++---
cpukit/sapi/src/version.c | 25 ++++++++++++++++++++++---
33 files changed, 726 insertions(+), 99 deletions(-)
diff --git a/cpukit/sapi/src/chainappendnotify.c b/cpukit/sapi/src/chainappendnotify.c
index c4f618458e..ec77287416 100644
--- a/cpukit/sapi/src/chainappendnotify.c
+++ b/cpukit/sapi/src/chainappendnotify.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
* <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/sapi/src/chaingetnotify.c b/cpukit/sapi/src/chaingetnotify.c
index 004d87443a..360ff39bcf 100644
--- a/cpukit/sapi/src/chaingetnotify.c
+++ b/cpukit/sapi/src/chaingetnotify.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/chaingetwait.c b/cpukit/sapi/src/chaingetwait.c
index a62c7f748e..51bc0b8935 100644
--- a/cpukit/sapi/src/chaingetwait.c
+++ b/cpukit/sapi/src/chaingetwait.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/chainprependnotify.c b/cpukit/sapi/src/chainprependnotify.c
index c08bb627af..7d29b4f126 100644
--- a/cpukit/sapi/src/chainprependnotify.c
+++ b/cpukit/sapi/src/chainprependnotify.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/chainprotected.c b/cpukit/sapi/src/chainprotected.c
index 54b4140250..a7f66c7691 100644
--- a/cpukit/sapi/src/chainprotected.c
+++ b/cpukit/sapi/src/chainprotected.c
@@ -1,3 +1,5 @@
* @file
@@ -19,9 +21,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/cpucounterconverter.c b/cpukit/sapi/src/cpucounterconverter.c
index 88403987d2..29a4233394 100644
--- a/cpukit/sapi/src/cpucounterconverter.c
+++ b/cpukit/sapi/src/cpucounterconverter.c
@@ -1,3 +1,5 @@
* Copyright (c) 2014, 2018 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
+ * are met:
#include <rtems/counter.h>
diff --git a/cpukit/sapi/src/delaynano.c b/cpukit/sapi/src/delaynano.c
index e6fc742a50..9658ae8764 100644
--- a/cpukit/sapi/src/delaynano.c
+++ b/cpukit/sapi/src/delaynano.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/delayticks.c b/cpukit/sapi/src/delayticks.c
index 8fec35173e..7def4c125d 100644
--- a/cpukit/sapi/src/delayticks.c
+++ b/cpukit/sapi/src/delayticks.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index c98ed08f10..ae974982f4 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 1989-2014.
* On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/cpukit/sapi/src/exshutdown.c b/cpukit/sapi/src/exshutdown.c
index 0297cad104..a994c7b806 100644
--- a/cpukit/sapi/src/exshutdown.c
+++ b/cpukit/sapi/src/exshutdown.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/cpukit/sapi/src/extensioncreate.c b/cpukit/sapi/src/extensioncreate.c
index 383ca66000..ba2fc936f7 100644
--- a/cpukit/sapi/src/extensioncreate.c
+++ b/cpukit/sapi/src/extensioncreate.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/cpukit/sapi/src/extensiondelete.c b/cpukit/sapi/src/extensiondelete.c
index 9b5454bfc5..d934d99bc9 100644
--- a/cpukit/sapi/src/extensiondelete.c
+++ b/cpukit/sapi/src/extensiondelete.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/fatal.c b/cpukit/sapi/src/fatal.c
index 6e4c452e5d..ae8d85040a 100644
--- a/cpukit/sapi/src/fatal.c
+++ b/cpukit/sapi/src/fatal.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/cpukit/sapi/src/fatalsrctext.c b/cpukit/sapi/src/fatalsrctext.c
index 636878da4c..0948a8ba60 100644
--- a/cpukit/sapi/src/fatalsrctext.c
+++ b/cpukit/sapi/src/fatalsrctext.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/getversionstring.c b/cpukit/sapi/src/getversionstring.c
index 5a68f5e3ff..45b583a537 100644
--- a/cpukit/sapi/src/getversionstring.c
+++ b/cpukit/sapi/src/getversionstring.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 2a588a5b76..e96d90706c 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/io.c b/cpukit/sapi/src/io.c
index 78b71ec0f8..3a3780610e 100644
--- a/cpukit/sapi/src/io.c
+++ b/cpukit/sapi/src/io.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/ioclose.c b/cpukit/sapi/src/ioclose.c
index faa9657816..cf2d639f4d 100644
--- a/cpukit/sapi/src/ioclose.c
+++ b/cpukit/sapi/src/ioclose.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/iocontrol.c b/cpukit/sapi/src/iocontrol.c
index 9076ac9d02..a01af02deb 100644
--- a/cpukit/sapi/src/iocontrol.c
+++ b/cpukit/sapi/src/iocontrol.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/ioinitialize.c b/cpukit/sapi/src/ioinitialize.c
index af8e7881bd..94ff96dd3b 100644
--- a/cpukit/sapi/src/ioinitialize.c
+++ b/cpukit/sapi/src/ioinitialize.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/ioopen.c b/cpukit/sapi/src/ioopen.c
index 01ed0e2bc9..9bad66a61c 100644
--- a/cpukit/sapi/src/ioopen.c
+++ b/cpukit/sapi/src/ioopen.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/ioread.c b/cpukit/sapi/src/ioread.c
index 113018457f..07ddcfcb44 100644
--- a/cpukit/sapi/src/ioread.c
+++ b/cpukit/sapi/src/ioread.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/ioregisterdriver.c b/cpukit/sapi/src/ioregisterdriver.c
index 2a4ea21a09..76da0c8701 100644
--- a/cpukit/sapi/src/ioregisterdriver.c
+++ b/cpukit/sapi/src/ioregisterdriver.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Copyright (c) 2009 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/sapi/src/iounregisterdriver.c b/cpukit/sapi/src/iounregisterdriver.c
index 8fa3241945..1f3613fdc5 100644
--- a/cpukit/sapi/src/iounregisterdriver.c
+++ b/cpukit/sapi/src/iounregisterdriver.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/iowrite.c b/cpukit/sapi/src/iowrite.c
index a5d26a7dd5..93660c9cd8 100644
--- a/cpukit/sapi/src/iowrite.c
+++ b/cpukit/sapi/src/iowrite.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
index 0af1beefa9..c392d0bfe1 100644
--- a/cpukit/sapi/src/profilingiterate.c
+++ b/cpukit/sapi/src/profilingiterate.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/profilingreportxml.c b/cpukit/sapi/src/profilingreportxml.c
index 8468ee2c59..e9d928239c 100644
--- a/cpukit/sapi/src/profilingreportxml.c
+++ b/cpukit/sapi/src/profilingreportxml.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/rbheap.c b/cpukit/sapi/src/rbheap.c
index be25536909..189b8d3fb0 100644
--- a/cpukit/sapi/src/rbheap.c
+++ b/cpukit/sapi/src/rbheap.c
@@ -1,3 +1,5 @@
* @file
@@ -18,9 +20,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/rbtree.c b/cpukit/sapi/src/rbtree.c
index a632efb554..f5e8bdb1db 100644
--- a/cpukit/sapi/src/rbtree.c
+++ b/cpukit/sapi/src/rbtree.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* Copyright (c) 2010 Gedare Bloom.
+ * are met:
diff --git a/cpukit/sapi/src/rbtreefind.c b/cpukit/sapi/src/rbtreefind.c
index e043618621..fb3f8f3f87 100644
--- a/cpukit/sapi/src/rbtreefind.c
+++ b/cpukit/sapi/src/rbtreefind.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/sapi/src/sapirbtreeinsert.c b/cpukit/sapi/src/sapirbtreeinsert.c
index e470bc2c09..0d0871891c 100644
--- a/cpukit/sapi/src/sapirbtreeinsert.c
+++ b/cpukit/sapi/src/sapirbtreeinsert.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* Copyright (c) 2010-2012 Gedare Bloom.
+ * are met:
diff --git a/cpukit/sapi/src/tcsimpleinstall.c b/cpukit/sapi/src/tcsimpleinstall.c
index adde036ff8..b00a06b349 100644
--- a/cpukit/sapi/src/tcsimpleinstall.c
+++ b/cpukit/sapi/src/tcsimpleinstall.c
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* Germany
+ * are met:
diff --git a/cpukit/sapi/src/version.c b/cpukit/sapi/src/version.c
index feafe7b935..385cf83f2a 100644
--- a/cpukit/sapi/src/version.c
+++ b/cpukit/sapi/src/version.c
@@ -1,3 +1,5 @@
* @file
@@ -19,9 +21,26 @@
* Copyright (C) 2017.
* Chris Johns <chrisj at rtems.org>
+ * are met:
2.24.4
