[PATCH 21/27] score/cpu/powerpc: Change license to BSD-2
Fri Feb 25 18:06:06 UTC 2022
Updates #3053.
 cpukit/score/cpu/powerpc/cpu.c                | 25 ++++++++++++++---
 .../powerpc/include/rtems/powerpc/registers.h | 25 ++++++++++++++---
 .../cpu/powerpc/include/rtems/score/cpu.h     | 25 ++++++++++++++---
 .../powerpc/include/rtems/score/cpuatomic.h   | 25 ++++++++++++++---
 .../cpu/powerpc/include/rtems/score/cpuimpl.h | 25 ++++++++++++++---
 .../powerpc/include/rtems/score/paravirt.h    | 26 +++++++++++++++---
 .../cpu/powerpc/include/rtems/score/powerpc.h | 27 ++++++++++++++-----
 .../score/cpu/powerpc/ppc-context-validate.S  | 25 ++++++++++++++---
 .../powerpc/ppc-context-volatile-clobber.S    | 25 ++++++++++++++---
 .../score/cpu/powerpc/ppc-isr-disable-mask.S  | 25 ++++++++++++++---
 10 files changed, 219 insertions(+), 34 deletions(-)
diff --git a/cpukit/score/cpu/powerpc/cpu.c b/cpukit/score/cpu/powerpc/cpu.c
index 41f1c202cc..6147d7be74 100644
--- a/cpukit/score/cpu/powerpc/cpu.c
+++ b/cpukit/score/cpu/powerpc/cpu.c
@@ -1,3 +1,5 @@
  *  @file
@@ -7,9 +9,26 @@
  * Copyright (C) 2009, 2017 embedded brains GmbH.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
diff --git a/cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h b/cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h
index 5dad87016d..b651261493 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h
@@ -1,3 +1,5 @@
  * @file
@@ -16,9 +18,26 @@
  *  Surrey Satellite Technology Limited
+ * are met:
 #ifndef _RTEMS_POWERPC_REGISTERS_H
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
index 9cb47bcaa6..42900aeb1d 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
  * @file
@@ -29,9 +31,26 @@
  *  Copyright (c) 2010, 2017 embedded brains GmbH.
+ * are met:
 #ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
  * COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
 #ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
index 69eeeb183c..cfed43ced4 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
  * Copyright (c) 2009, 2017 embedded brains GmbH
+ * are met:
 #ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/paravirt.h b/cpukit/score/cpu/powerpc/include/rtems/score/paravirt.h
index 5efbd3bef7..e6f067b495 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/paravirt.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/paravirt.h
@@ -1,3 +1,5 @@
  * @file
@@ -11,12 +13,28 @@
  *  COPYRIGHT (c) 2018.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
+ * are met:
 #ifndef RTEMS_PARAVIRT
 #error "This file should only be included with paravirtualization is enabled."
 #endif
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/powerpc.h b/cpukit/score/cpu/powerpc/include/rtems/score/powerpc.h
index 84e164d70b..542ab154d2 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/powerpc.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/powerpc.h
@@ -1,3 +1,5 @@
  * @file
@@ -32,13 +34,26 @@
  *  COPYRIGHT (c) 1989-1997.
+ * are met:
- * Note:
- *      This file is included by both C and assembler code ( -DASM )
diff --git a/cpukit/score/cpu/powerpc/ppc-context-validate.S b/cpukit/score/cpu/powerpc/ppc-context-validate.S
index b65ccacfb8..4e2ae2819c 100644
--- a/cpukit/score/cpu/powerpc/ppc-context-validate.S
+++ b/cpukit/score/cpu/powerpc/ppc-context-validate.S
@@ -1,3 +1,5 @@
  * Copyright (c) 2013, 2017 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
  *  <rtems at embedded-brains.de>
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S b/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
index ea217b27ce..3f555595e7 100644
--- a/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
+++ b/cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S b/cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S
index 9f78cf9a63..6b7b31fbff 100644
--- a/cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S
+++ b/cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S
@@ -1,3 +1,5 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
2.24.4
