[PATCH 14/27] score/cpu/arm: Change license to BSD-2
Fri Feb 25 18:05:59 UTC 2022
Updates #3053.
 cpukit/score/cpu/arm/__aeabi_read_tp.c        | 25 +++++++++++++++---
 cpukit/score/cpu/arm/__tls_get_addr.c         | 25 +++++++++++++++---
 cpukit/score/cpu/arm/arm-context-validate.S   | 25 +++++++++++++++---
 .../cpu/arm/arm-context-volatile-clobber.S    | 25 +++++++++++++++---
 cpukit/score/cpu/arm/arm-exception-default.c  | 25 +++++++++++++++---
 .../score/cpu/arm/arm-exception-frame-print.c | 25 +++++++++++++++---
 cpukit/score/cpu/arm/arm_exc_abort.S          | 25 +++++++++++++++---
 cpukit/score/cpu/arm/arm_exc_interrupt.S      | 25 +++++++++++++++---
 .../score/cpu/arm/armv4-exception-default.S   | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv4-sync-synchronize.c | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7-thread-idle.c      | 25 +++++++++++++++---
 .../score/cpu/arm/armv7m-context-initialize.c | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7m-context-restore.c | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7m-context-switch.c  | 25 +++++++++++++++---
 .../score/cpu/arm/armv7m-exception-default.c  | 25 +++++++++++++++---
 .../cpu/arm/armv7m-exception-handler-get.c    | 25 +++++++++++++++---
 .../cpu/arm/armv7m-exception-handler-set.c    | 25 +++++++++++++++---
 .../cpu/arm/armv7m-exception-priority-get.c   | 25 +++++++++++++++---
 .../arm/armv7m-exception-priority-handler.c   | 25 +++++++++++++++---
 .../cpu/arm/armv7m-exception-priority-set.c   | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7m-isr-dispatch.c    | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7m-isr-enter-leave.c | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7m-isr-level-get.c   | 25 +++++++++++++++---
 cpukit/score/cpu/arm/armv7m-isr-level-set.c   | 25 +++++++++++++++---
 .../score/cpu/arm/armv7m-isr-vector-install.c | 25 +++++++++++++++---
 .../cpu/arm/armv7m-multitasking-start-stop.c  | 25 +++++++++++++++---
 cpukit/score/cpu/arm/cpu.c                    | 25 +++++++++++++++---
 cpukit/score/cpu/arm/cpu_asm.S                | 25 +++++++++++++++---
 .../score/cpu/arm/include/libcpu/arm-cp15.h   | 25 +++++++++++++++---
 cpukit/score/cpu/arm/include/rtems/asm.h      | 25 +++++++++++++++---
 .../score/cpu/arm/include/rtems/score/arm.h   | 25 +++++++++++++++---
 .../score/cpu/arm/include/rtems/score/armv4.h | 25 +++++++++++++++---
 .../cpu/arm/include/rtems/score/armv7m.h      | 25 +++++++++++++++---
 .../score/cpu/arm/include/rtems/score/cpu.h   | 25 +++++++++++++++---
 .../cpu/arm/include/rtems/score/cpu_asm.h     | 25 +++++++++++++++---
 .../cpu/arm/include/rtems/score/cpuatomic.h   | 25 +++++++++++++++---
 .../cpu/arm/include/rtems/score/cpuimpl.h     | 25 +++++++++++++++---
 .../cpu/arm/include/rtems/score/paravirt.h    | 26 ++++++++++++++++---
 38 files changed, 836 insertions(+), 115 deletions(-)
diff --git a/cpukit/score/cpu/arm/__aeabi_read_tp.c b/cpukit/score/cpu/arm/__aeabi_read_tp.c
index 22acc770e3..9478951245 100644
--- a/cpukit/score/cpu/arm/__aeabi_read_tp.c
+++ b/cpukit/score/cpu/arm/__aeabi_read_tp.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
  *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/arm/__tls_get_addr.c b/cpukit/score/cpu/arm/__tls_get_addr.c
index 837395bd8a..cc76f601e5 100644
--- a/cpukit/score/cpu/arm/__tls_get_addr.c
+++ b/cpukit/score/cpu/arm/__tls_get_addr.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2014-2015 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
index 257a9ff1cb..e67c4f7732 100644
--- a/cpukit/score/cpu/arm/arm-context-validate.S
+++ b/cpukit/score/cpu/arm/arm-context-validate.S
@@ -1,3 +1,5 @@
  * Copyright (c) 2013, 2017 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
index d94e107736..93581ada34 100644
--- a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
+++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/arm-exception-default.c b/cpukit/score/cpu/arm/arm-exception-default.c
index 6d4d88f3d0..0178fb786f 100644
--- a/cpukit/score/cpu/arm/arm-exception-default.c
+++ b/cpukit/score/cpu/arm/arm-exception-default.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c b/cpukit/score/cpu/arm/arm-exception-frame-print.c
index 252d775de7..8c7e14b6ff 100644
--- a/cpukit/score/cpu/arm/arm-exception-frame-print.c
+++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2012-2013 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/arm_exc_abort.S b/cpukit/score/cpu/arm/arm_exc_abort.S
index 03f7963eac..e747b52504 100644
--- a/cpukit/score/cpu/arm/arm_exc_abort.S
+++ b/cpukit/score/cpu/arm/arm_exc_abort.S
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  * Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 92ff781f40..407c933c8b 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S b/cpukit/score/cpu/arm/armv4-exception-default.S
index 34cc5ade38..843003ff1c 100644
--- a/cpukit/score/cpu/arm/armv4-exception-default.S
+++ b/cpukit/score/cpu/arm/armv4-exception-default.S
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv4-sync-synchronize.c b/cpukit/score/cpu/arm/armv4-sync-synchronize.c
index 7e4c91ee1c..aed7e71787 100644
--- a/cpukit/score/cpu/arm/armv4-sync-synchronize.c
+++ b/cpukit/score/cpu/arm/armv4-sync-synchronize.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
 #include <rtems/score/cpu.h>
diff --git a/cpukit/score/cpu/arm/armv7-thread-idle.c b/cpukit/score/cpu/arm/armv7-thread-idle.c
index 73346266c9..de08e299d7 100644
--- a/cpukit/score/cpu/arm/armv7-thread-idle.c
+++ b/cpukit/score/cpu/arm/armv7-thread-idle.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-context-initialize.c b/cpukit/score/cpu/arm/armv7m-context-initialize.c
index caaa3557b2..3e788360fa 100644
--- a/cpukit/score/cpu/arm/armv7m-context-initialize.c
+++ b/cpukit/score/cpu/arm/armv7m-context-initialize.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-context-restore.c b/cpukit/score/cpu/arm/armv7m-context-restore.c
index adfc261177..c0795a9c4b 100644
--- a/cpukit/score/cpu/arm/armv7m-context-restore.c
+++ b/cpukit/score/cpu/arm/armv7m-context-restore.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-context-switch.c b/cpukit/score/cpu/arm/armv7m-context-switch.c
index bfef67efbd..4db367eda6 100644
--- a/cpukit/score/cpu/arm/armv7m-context-switch.c
+++ b/cpukit/score/cpu/arm/armv7m-context-switch.c
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-exception-default.c b/cpukit/score/cpu/arm/armv7m-exception-default.c
index 39c5b01242..a827fd2f65 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-default.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-default.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-exception-handler-get.c b/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
index 1e86dcfab8..50168023b1 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-exception-handler-set.c b/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
index 9df362817b..7fa56f5d4e 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-get.c b/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
index 4e150b3109..b84b9eed46 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
@@ -1,3 +1,5 @@
  *  @file
@@ -12,9 +14,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c b/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
index 319e2f416a..203650f457 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-set.c b/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
index 2d6c48408c..7cf119c765 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
index 09bf602ece..f074ddda4f 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c b/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
index 0b53873e4e..4c3df46002 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-isr-level-get.c b/cpukit/score/cpu/arm/armv7m-isr-level-get.c
index b7432b5eab..a64e496753 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-level-get.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-level-get.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-isr-level-set.c b/cpukit/score/cpu/arm/armv7m-isr-level-set.c
index 987667d7cc..3bdee8d498 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-level-set.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-level-set.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-isr-vector-install.c b/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
index 6339e00ff9..6546744363 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
@@ -1,3 +1,5 @@
  *  @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c b/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
index ce96ce47a6..cbc512e632 100644
--- a/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
+++ b/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index d3471dc99f..5c5b253470 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -1,3 +1,5 @@
  * @file
@@ -17,9 +19,26 @@
  *  Copyright (c) 2009, 2017 embedded brains GmbH
+ * are met:
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 46eb46b914..54d6f70b0d 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -1,3 +1,5 @@
  * @file
@@ -21,9 +23,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h b/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
index 5bc01dcb32..7237b964a4 100644
--- a/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
+++ b/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
@@ -1,3 +1,5 @@
  * @file
@@ -16,9 +18,26 @@
  *  Germany
  *  <info at embedded-brains.de>
+ * are met:
 #ifndef LIBCPU_SHARED_ARM_CP15_H
diff --git a/cpukit/score/cpu/arm/include/rtems/asm.h b/cpukit/score/cpu/arm/include/rtems/asm.h
index 05e186f73c..0bbe43c837 100644
--- a/cpukit/score/cpu/arm/include/rtems/asm.h
+++ b/cpukit/score/cpu/arm/include/rtems/asm.h
@@ -1,3 +1,5 @@
  * @file
@@ -25,9 +27,26 @@
  *  COPYRIGHT (c) 2000 Canon Research Centre France SA.
  *  Emmanuel Raguet, mailto:raguet at crf.canon.fr
+ * are met:
diff --git a/cpukit/score/cpu/arm/include/rtems/score/arm.h b/cpukit/score/cpu/arm/include/rtems/score/arm.h
index 7eaa69d889..67fa579e67 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/arm.h
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  Copyright (c) 2002 Advent Networks, Inc.
  *       Jay Monkman <jmonkman at adventnetworks.com>
+ * are met:
diff --git a/cpukit/score/cpu/arm/include/rtems/score/armv4.h b/cpukit/score/cpu/arm/include/rtems/score/armv4.h
index caeaa3e553..798140f4e8 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/armv4.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/armv4.h
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
 #ifndef RTEMS_SCORE_ARMV4_H
diff --git a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
index 1803c8d8ca..d46fa3781f 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  Germany
+ * are met:
 #ifndef RTEMS_SCORE_ARMV7M_H
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index c8d4442417..da521528a4 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
  * @file
@@ -20,9 +22,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
index e25dd25f99..30ef04f6a4 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
  *  COPYRIGHT (c) 2002 by Advent Networks, Inc.
+ * are met:
  *  This file is the include file for cpu_asm.S
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
  * COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
 #ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
index a6fe74e9ad..0ce347c86f 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
  * @file
@@ -7,9 +9,26 @@
  * Copyright (c) 2013, 2016 embedded brains GmbH
+ * are met:
 #ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/arm/include/rtems/score/paravirt.h b/cpukit/score/cpu/arm/include/rtems/score/paravirt.h
index d0dc4024e2..e3fb9009ad 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/paravirt.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/paravirt.h
@@ -1,3 +1,5 @@
  * @file
@@ -11,12 +13,28 @@
  *  COPYRIGHT (c) 2018.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
+ * are met:
 #ifndef RTEMS_PARAVIRT
 #error "This file should only be included with paravirtualization is enabled."
 #endif
2.24.4
