[PATCH 12/27] cpukit/include/rtems/posix/*.h: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:05:57 UTC 2022
Updates #3053.
cpukit/include/rtems/posix/aio_misc.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/barrierimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/condimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/key.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/keyimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/mmanimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/mqueue.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/mqueueimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/muteximpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/posixapi.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/priorityimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/psignal.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/psignalimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/pthread.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/pthreadattrimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/pthreadimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/rwlockimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/semaphore.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/semaphoreimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/shm.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/shmimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/sigset.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/spinlockimpl.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/threadsup.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/timer.h | 25 +++++++++++++++++---
cpukit/include/rtems/posix/timerimpl.h | 25 +++++++++++++++++---
26 files changed, 572 insertions(+), 78 deletions(-)
diff --git a/cpukit/include/rtems/posix/aio_misc.h b/cpukit/include/rtems/posix/aio_misc.h
index 059753ef58..8356d3df5a 100644
--- a/cpukit/include/rtems/posix/aio_misc.h
+++ b/cpukit/include/rtems/posix/aio_misc.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright 2010, Alin Rus <alin.codejunkie at gmail.com>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifndef _AIO_MISC_H
diff --git a/cpukit/include/rtems/posix/barrierimpl.h b/cpukit/include/rtems/posix/barrierimpl.h
index a1794b82fd..44c1d4317c 100644
--- a/cpukit/include/rtems/posix/barrierimpl.h
+++ b/cpukit/include/rtems/posix/barrierimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Copyright (c) 2017 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_POSIX_BARRIERIMPL_H
diff --git a/cpukit/include/rtems/posix/condimpl.h b/cpukit/include/rtems/posix/condimpl.h
index 66e09bf6d8..10c044de72 100644
--- a/cpukit/include/rtems/posix/condimpl.h
+++ b/cpukit/include/rtems/posix/condimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2013.
* On-Line Applications Research Corporation (OAR).
+ * are met:
#ifndef _RTEMS_POSIX_CONDIMPL_H
diff --git a/cpukit/include/rtems/posix/key.h b/cpukit/include/rtems/posix/key.h
index a710855b93..c3fa8ce51c 100644
--- a/cpukit/include/rtems/posix/key.h
+++ b/cpukit/include/rtems/posix/key.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Copyright (c) 2016 embedded brains GmbH.
+ * are met:
#ifndef _RTEMS_POSIX_KEY_H
diff --git a/cpukit/include/rtems/posix/keyimpl.h b/cpukit/include/rtems/posix/keyimpl.h
index eed5d3fed2..8f8644ca71 100644
--- a/cpukit/include/rtems/posix/keyimpl.h
+++ b/cpukit/include/rtems/posix/keyimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
#include <rtems/posix/key.h>
diff --git a/cpukit/include/rtems/posix/mmanimpl.h b/cpukit/include/rtems/posix/mmanimpl.h
index e1cc672331..80dda40671 100644
--- a/cpukit/include/rtems/posix/mmanimpl.h
+++ b/cpukit/include/rtems/posix/mmanimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* Copyright (c) 2012 Chris Johns
+ * are met:
#ifndef _RTEMS_POSIX_MMANIMPL_H
diff --git a/cpukit/include/rtems/posix/mqueue.h b/cpukit/include/rtems/posix/mqueue.h
index 84010e7d4f..4145891d7b 100644
--- a/cpukit/include/rtems/posix/mqueue.h
+++ b/cpukit/include/rtems/posix/mqueue.h
@@ -1,3 +1,5 @@
* @file
@@ -23,9 +25,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
#ifndef _RTEMS_POSIX_MQUEUE_H
diff --git a/cpukit/include/rtems/posix/mqueueimpl.h b/cpukit/include/rtems/posix/mqueueimpl.h
index 14573287ad..127709c0f1 100644
--- a/cpukit/include/rtems/posix/mqueueimpl.h
+++ b/cpukit/include/rtems/posix/mqueueimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_MQUEUE_INL
diff --git a/cpukit/include/rtems/posix/muteximpl.h b/cpukit/include/rtems/posix/muteximpl.h
index 3decb6f4ac..e2b4e187d1 100644
--- a/cpukit/include/rtems/posix/muteximpl.h
+++ b/cpukit/include/rtems/posix/muteximpl.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
/* COPYRIGHT (c) 1989-2013.
+ * are met:
#ifndef _RTEMS_POSIX_MUTEXIMPL_H
diff --git a/cpukit/include/rtems/posix/posixapi.h b/cpukit/include/rtems/posix/posixapi.h
index 8d30ee21e5..d166608774 100644
--- a/cpukit/include/rtems/posix/posixapi.h
+++ b/cpukit/include/rtems/posix/posixapi.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_POSIXAPI_H
diff --git a/cpukit/include/rtems/posix/priorityimpl.h b/cpukit/include/rtems/posix/priorityimpl.h
index eb2e3e059f..e391448372 100644
--- a/cpukit/include/rtems/posix/priorityimpl.h
+++ b/cpukit/include/rtems/posix/priorityimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_PRIORITYIMPL_H
diff --git a/cpukit/include/rtems/posix/psignal.h b/cpukit/include/rtems/posix/psignal.h
index 4a078c57aa..de4848e000 100644
--- a/cpukit/include/rtems/posix/psignal.h
+++ b/cpukit/include/rtems/posix/psignal.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_PSIGNAL_H
diff --git a/cpukit/include/rtems/posix/psignalimpl.h b/cpukit/include/rtems/posix/psignalimpl.h
index cccc3dafc9..c5c02edf65 100644
--- a/cpukit/include/rtems/posix/psignalimpl.h
+++ b/cpukit/include/rtems/posix/psignalimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_PSIGNALIMPL_H
diff --git a/cpukit/include/rtems/posix/pthread.h b/cpukit/include/rtems/posix/pthread.h
index 8aa11c53fe..b76c61159e 100644
--- a/cpukit/include/rtems/posix/pthread.h
+++ b/cpukit/include/rtems/posix/pthread.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_PTHREAD_H
diff --git a/cpukit/include/rtems/posix/pthreadattrimpl.h b/cpukit/include/rtems/posix/pthreadattrimpl.h
index b5e02ec1c7..b94c6fc193 100644
--- a/cpukit/include/rtems/posix/pthreadattrimpl.h
+++ b/cpukit/include/rtems/posix/pthreadattrimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_PTHREADATTRIMPL_H
diff --git a/cpukit/include/rtems/posix/pthreadimpl.h b/cpukit/include/rtems/posix/pthreadimpl.h
index 0dc7d9dac5..2f75b4aafb 100644
--- a/cpukit/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/include/rtems/posix/pthreadimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_PTHREADIMPL_H
diff --git a/cpukit/include/rtems/posix/rwlockimpl.h b/cpukit/include/rtems/posix/rwlockimpl.h
index b92ca9d04c..2f77cbabad 100644
--- a/cpukit/include/rtems/posix/rwlockimpl.h
+++ b/cpukit/include/rtems/posix/rwlockimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_RWLOCKIMPL_H
diff --git a/cpukit/include/rtems/posix/semaphore.h b/cpukit/include/rtems/posix/semaphore.h
index db36b39c9d..cce16a2ca2 100644
--- a/cpukit/include/rtems/posix/semaphore.h
+++ b/cpukit/include/rtems/posix/semaphore.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_SEMAPHORE_H
diff --git a/cpukit/include/rtems/posix/semaphoreimpl.h b/cpukit/include/rtems/posix/semaphoreimpl.h
index b662d001cb..b10e3731c5 100644
--- a/cpukit/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/include/rtems/posix/semaphoreimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_SEMAPHOREIMPL_H
diff --git a/cpukit/include/rtems/posix/shm.h b/cpukit/include/rtems/posix/shm.h
index 3d10e65fea..f2985f4874 100644
--- a/cpukit/include/rtems/posix/shm.h
+++ b/cpukit/include/rtems/posix/shm.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2016 Gedare Bloom.
+ * are met:
#ifndef _RTEMS_POSIX_SHM_H
diff --git a/cpukit/include/rtems/posix/shmimpl.h b/cpukit/include/rtems/posix/shmimpl.h
index 6882119a83..b0630acbe1 100644
--- a/cpukit/include/rtems/posix/shmimpl.h
+++ b/cpukit/include/rtems/posix/shmimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_SHMIMPL_H
diff --git a/cpukit/include/rtems/posix/sigset.h b/cpukit/include/rtems/posix/sigset.h
index 6f46f61104..0fcd8da464 100644
--- a/cpukit/include/rtems/posix/sigset.h
+++ b/cpukit/include/rtems/posix/sigset.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_SIGSET_H
diff --git a/cpukit/include/rtems/posix/spinlockimpl.h b/cpukit/include/rtems/posix/spinlockimpl.h
index d28e0391fc..be3245f90a 100644
--- a/cpukit/include/rtems/posix/spinlockimpl.h
+++ b/cpukit/include/rtems/posix/spinlockimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_SPINLOCKIMPL_H
diff --git a/cpukit/include/rtems/posix/threadsup.h b/cpukit/include/rtems/posix/threadsup.h
index 127d897531..95f56abb12 100644
--- a/cpukit/include/rtems/posix/threadsup.h
+++ b/cpukit/include/rtems/posix/threadsup.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
#ifndef _RTEMS_POSIX_THREADSUP_H
diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
index 7ae089173a..05a6f36eab 100644
--- a/cpukit/include/rtems/posix/timer.h
+++ b/cpukit/include/rtems/posix/timer.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_TIMER_H
diff --git a/cpukit/include/rtems/posix/timerimpl.h b/cpukit/include/rtems/posix/timerimpl.h
index 2b4eec1e24..8f92186e30 100644
--- a/cpukit/include/rtems/posix/timerimpl.h
+++ b/cpukit/include/rtems/posix/timerimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_POSIX_TIMERIMPL_H
2.24.4
