[PATCH 11/27] posix/src/_execve.c: Change license to BSD-2
Fri Feb 25 18:05:56 UTC 2022
Updates #3053.
 cpukit/posix/src/_execve.c | 25 ++++++++++++++++++++++---
 1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/cpukit/posix/src/_execve.c b/cpukit/posix/src/_execve.c
index 2c8b436889..2858d13082 100644
--- a/cpukit/posix/src/_execve.c
+++ b/cpukit/posix/src/_execve.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  *  COPYRIGHT (c) 1989-2013,2016.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
2.24.4
