[PATCH 16/27] score/cpu/m68k: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:01 UTC 2022
Updates #3053.
cpukit/score/cpu/m68k/__m68k_read_tp.c | 25 ++++++++++++++++---
cpukit/score/cpu/m68k/cpu.c | 25 ++++++++++++++++---
cpukit/score/cpu/m68k/cpu_asm.S | 25 ++++++++++++++++---
.../score/cpu/m68k/include/rtems/score/cpu.h | 25 ++++++++++++++++---
.../cpu/m68k/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
.../cpu/m68k/include/rtems/score/cpuimpl.h | 25 ++++++++++++++++---
.../score/cpu/m68k/include/rtems/score/m68k.h | 25 ++++++++++++++++---
.../cpu/m68k/m68k-exception-frame-print.c | 25 ++++++++++++++++---
8 files changed, 176 insertions(+), 24 deletions(-)
diff --git a/cpukit/score/cpu/m68k/__m68k_read_tp.c b/cpukit/score/cpu/m68k/__m68k_read_tp.c
index 466f979e57..985089746d 100644
--- a/cpukit/score/cpu/m68k/__m68k_read_tp.c
+++ b/cpukit/score/cpu/m68k/__m68k_read_tp.c
@@ -1,3 +1,5 @@
* Copyright (c) 2014-2015 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
* <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/m68k/cpu.c b/cpukit/score/cpu/m68k/cpu.c
index e6a5c9dbf3..9f6fb9223e 100644
--- a/cpukit/score/cpu/m68k/cpu.c
+++ b/cpukit/score/cpu/m68k/cpu.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/cpukit/score/cpu/m68k/cpu_asm.S b/cpukit/score/cpu/m68k/cpu_asm.S
index 3c16e62fbc..28c0cb51eb 100644
--- a/cpukit/score/cpu/m68k/cpu_asm.S
+++ b/cpukit/score/cpu/m68k/cpu_asm.S
@@ -1,3 +1,5 @@
/* cpu_asm.s
* This file contains all assembly code for the MC68020 implementation
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
index 95e75ad1eb..e72b735501 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
#ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
index 833ff071b8..e3b61efd9f 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2013 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/m68k.h b/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
index eb262d30ab..399fb6518c 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/m68k.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
#ifndef _RTEMS_SCORE_M68K_H
diff --git a/cpukit/score/cpu/m68k/m68k-exception-frame-print.c b/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
index e54eb60e9f..106f153ba1 100644
--- a/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
+++ b/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
@@ -1,3 +1,5 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
+ * are met:
2.24.4
