[PATCH 17/27] score/cpu/mips: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:02 UTC 2022
Updates #3053.
cpukit/score/cpu/mips/cpu.c | 25 ++++++++++++++++---
cpukit/score/cpu/mips/cpu_asm.S | 25 ++++++++++++++++---
.../score/cpu/mips/include/rtems/score/cpu.h | 25 ++++++++++++++++---
.../cpu/mips/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
.../cpu/mips/include/rtems/score/cpuimpl.h | 25 ++++++++++++++++---
.../score/cpu/mips/include/rtems/score/mips.h | 25 ++++++++++++++++---
6 files changed, 132 insertions(+), 18 deletions(-)
diff --git a/cpukit/score/cpu/mips/cpu.c b/cpukit/score/cpu/mips/cpu.c
index 8d1018dbf6..526f7db13f 100644
--- a/cpukit/score/cpu/mips/cpu.c
+++ b/cpukit/score/cpu/mips/cpu.c
@@ -1,3 +1,5 @@
* @file
@@ -41,9 +43,26 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/mips/cpu_asm.S b/cpukit/score/cpu/mips/cpu_asm.S
index 327df4d2e9..b3aefebbe0 100644
--- a/cpukit/score/cpu/mips/cpu_asm.S
+++ b/cpukit/score/cpu/mips/cpu_asm.S
@@ -1,3 +1,5 @@
* This file contains the basic algorithms for all assembly code used
* in an specific CPU port of RTEMS. These algorithms must be implemented
@@ -43,9 +45,26 @@
* COPYRIGHT (c) 1989-2002.
+ * are met:
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index 67d1465daa..fdb7ee4d73 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
* @file
@@ -36,9 +38,26 @@
+ * are met:
#ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
index 554d8be1c8..0568134351 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2013 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/mips/include/rtems/score/mips.h b/cpukit/score/cpu/mips/include/rtems/score/mips.h
index d3dccb1c54..db9f119178 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/mips.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/mips.h
@@ -1,3 +1,5 @@
* @file
@@ -15,9 +17,26 @@
* COPYRIGHT (c) 1989-2001.
+ * are met:
#ifndef _RTEMS_SCORE_MIPS_H
2.24.4
