[PATCH 1/2] cpukit/aarch64: Keep state across context switch
Kinsey Moore
kinsey.moore at oarcorp.com
Sat Feb 26 07:03:50 UTC 2022
On 2/26/2022 00:53, Sebastian Huber wrote:
> On 26/02/2022 00:41, Kinsey Moore wrote:
>> This may also be an issue for ARM, RISC-V and others as it doesn't
>> appear that ARM saves CPSR during context switch and I couldn't tell
>> that RISC-V does this either, though I'm less familiar with it.
> This doesn't look like the right way to fix this issue.
> There is currently the assumption that all processors start
> multitasking with a context switch to _Thread_Handler() which sets the
> interrupt level. It is possible to construct a scenario in which we
> start multitasking with a migration of a thread which already executed
> the _Thread_Handler() prologue. This would result in an execution with
> disabled interrupts. I think the proper fix for this scenario is to
> enable interrupts in _CPU_SMP_Prepare_start_multitasking().
> Doing a context switch with interrupts disabled is a fatal application
> error on all architectures with
> #define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
> or enabled SMP support.
Ok, great. I was wondering if that was the case and this is definitely
the kind of feedback I was looking for. I'll adjust the patch set to
reflect that. I still wonder if this is an issue on other SMP CPU ports,
though, since most of them don't implement that hook, either.
Thanks,
Kinsey
