[PATCH 1/2] cpukit/aarch64: Keep state across context switch
Mon Feb 28 18:19:26 UTC 2022
On 26/02/2022 08:03, Kinsey Moore wrote:
> On 2/26/2022 00:53, Sebastian Huber wrote:
>> On 26/02/2022 00:41, Kinsey Moore wrote:
>>> This may also be an issue for ARM, RISC-V and others as it doesn't
>>> appear that ARM saves CPSR during context switch and I couldn't tell
>>> that RISC-V does this either, though I'm less familiar with it.
>> This doesn't look like the right way to fix this issue.
>> There is currently the assumption that all processors start
>> multitasking with a context switch to _Thread_Handler() which sets the
>> interrupt level. It is possible to construct a scenario in which we
>> start multitasking with a migration of a thread which already executed
>> the _Thread_Handler() prologue. This would result in an execution with
>> disabled interrupts. I think the proper fix for this scenario is to
>> enable interrupts in _CPU_SMP_Prepare_start_multitasking().
>> Doing a context switch with interrupts disabled is a fatal application
>> error on all architectures with
>> #define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
>> or enabled SMP support.
> Ok, great. I was wondering if that was the case and this is definitely
> the kind of feedback I was looking for. I'll adjust the patch set to
> reflect that. I still wonder if this is an issue on other SMP CPU ports,
> though, since most of them don't implement that hook, either.
I would like to have a closer look at this next week then I am back from
holidays.
Enabling interrupts in _CPU_SMP_Prepare_start_multitasking() would not
work since we use the interrupt stack at this point. We should add a
ticket and a test case for this (I can do this next week). How did you
observe this bug?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
