[PATCH 00/27] Change License to BSD-2
Mon Feb 28 16:08:12 UTC 2022
This series of relicense changes looks good. Thanks for getting this
cleaned up. I think you can push it.
On Fri, Feb 25, 2022 at 5:23 PM Joel Sherrill <joel at rtems.org> wrote:
> This large series of patches is mechanical and almost completely
> generated by a script. I focused on directories where all authors
> had given permission. There are other directories in cpukit/ which
> are not third-party code which should also be able to be updated.
> I will follow up later with changes to those. This is large enough.
> Some ports in score/cpu do not yet have permission from the authors.
> I have skipped those. At least two of those have been identified
> for removal for technical reasons.
> --joel
> Joel Sherrill (27):
>   score/src/[a-m]*.c: Change license to BSD-2
>   score/src/[n-s]*.c: Change license to BSD-2
>   score/src/[t-z]*.c: Change license to BSD-2
>   cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2
>   cpukit/include/rtems/score/[s-z]*.h: Change license to BSD-2
>   cpukit/rtems/src/[a-r]*.c: Change license to BSD-2
>   cpukit/rtems/src/[s-z]*.c: Change license to BSD-2
>   cpukit/include/rtems/rtems/*.h: Change license to BSD-2
>   cpukit/posix/src/[a-o]*.c: Change license to BSD-2
>   cpukit/posix/src/[p-z]*.c: Change license to BSD-2
>   posix/src/_execve.c: Change license to BSD-2
>   cpukit/include/rtems/posix/*.h: Change license to BSD-2
>   sapi/src/*.c: Change license to BSD-2
>   score/cpu/arm: Change license to BSD-2
>   score/cpu/i386: Change license to BSD-2
>   score/cpu/m68k: Change license to BSD-2
>   score/cpu/mips: Change license to BSD-2
>   score/cpu/nios2: Change license to BSD-2
>   score/cpu/no_cpu: Change license to BSD-2
>   score/cpu/or1k: Change license to BSD-2
>   score/cpu/powerpc: Change license to BSD-2
>   score/cpu/sparc: Change license to BSD-2
>   score/cpu/sparc64: Change license to BSD-2
>   score/cpu/v850: Change license to BSD-2
>   cpukit/include/adainclude: Change license to BSD-2
>   cpukit/ftpd: Change license to BSD-2
>   cpukit/libblock: Change license to BSD-2
>  cpukit/ftpd/ftpd-init.c                       | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-barrier.adb   | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-barrier.ads   | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-clock.adb     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-clock.ads     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-cpu_usage.ads | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-event.adb     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-event.ads     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-extension.adb | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-extension.ads | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-fatal.adb     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-fatal.ads     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-interrupt.ads | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-io.adb        | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-io.ads        | 25 ++++++++++++++---
>  .../adainclude/rtems-message_queue.adb        | 25 ++++++++++++++---
>  .../adainclude/rtems-message_queue.ads        | 25 ++++++++++++++---
>  .../adainclude/rtems-multiprocessing.adb      | 25 ++++++++++++++---
>  .../adainclude/rtems-multiprocessing.ads      | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-object.adb    | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-object.ads    | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-partition.adb | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-partition.ads | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-port.adb      | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-port.ads      | 25 ++++++++++++++---
>  .../adainclude/rtems-rate_monotonic.adb       | 25 ++++++++++++++---
>  .../adainclude/rtems-rate_monotonic.ads       | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-region.adb    | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-region.ads    | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-semaphore.adb | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-semaphore.ads | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-signal.adb    | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-signal.ads    | 25 ++++++++++++++---
>  .../adainclude/rtems-stack_checker.ads        | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-tasks.adb     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-tasks.ads     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-timer.adb     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems-timer.ads     | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems.adb           | 25 ++++++++++++++---
>  cpukit/include/adainclude/rtems.ads           | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/aio_misc.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/barrierimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/condimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/key.h              | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/keyimpl.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/mmanimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/mqueue.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/mqueueimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/muteximpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/posixapi.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/priorityimpl.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/psignal.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/psignalimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/pthread.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/pthreadattrimpl.h  | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/pthreadimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/rwlockimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/semaphore.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/semaphoreimpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/shm.h              | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/shmimpl.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/sigset.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/spinlockimpl.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/threadsup.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/timer.h            | 25 ++++++++++++++---
>  cpukit/include/rtems/posix/timerimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/asrdata.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/attrimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/barrierdata.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/barrierimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/clockimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/dpmemdata.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/dpmemimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/eventdata.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/eventimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/eventmp.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/mainpage.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/messagedata.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/messageimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/modesimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/msgmp.h            | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/optionsimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/partdata.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/partimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/partmp.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/ratemondata.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/ratemonimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/regiondata.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/regionimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/semdata.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/semimpl.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/semmp.h            | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/signalimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/signalmp.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/statusimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/taskmp.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/tasksdata.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/tasksimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/timerdata.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/rtems/timerimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/address.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/apimutex.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/assert.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/atomic.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/chain.h            | 25 ++++++++++++++---
>  cpukit/include/rtems/score/chainimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/context.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/copyrt.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/corebarrier.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/corebarrierimpl.h  | 25 ++++++++++++++---
>  cpukit/include/rtems/score/coremsg.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/coremsgimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/coremutex.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/coremuteximpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/corerwlockimpl.h   | 25 ++++++++++++++---
>  cpukit/include/rtems/score/coresem.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/coresemimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/cpustdatomic.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/freechain.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/freechainimpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/heap.h             | 25 ++++++++++++++---
>  cpukit/include/rtems/score/heapimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/heapinfo.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/interr.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/io.h               | 25 ++++++++++++++---
>  cpukit/include/rtems/score/isr.h              | 25 ++++++++++++++---
>  cpukit/include/rtems/score/isrlevel.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/isrlock.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/mpci.h             | 25 ++++++++++++++---
>  cpukit/include/rtems/score/mpciimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/mppkt.h            | 25 ++++++++++++++---
>  cpukit/include/rtems/score/mrsp.h             | 25 ++++++++++++++---
>  cpukit/include/rtems/score/mrspimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/muteximpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/object.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/objectdata.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/objectimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/objectmp.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/onceimpl.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/percpu.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/percpudata.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/priority.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/prioritybitmap.h   | 25 ++++++++++++++---
>  .../include/rtems/score/prioritybitmapimpl.h  | 25 ++++++++++++++---
>  cpukit/include/rtems/score/priorityimpl.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/processormask.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/profiling.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/protectedheap.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/rbtree.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/rbtreeimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/scheduler.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulercbs.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulercbsimpl.h | 25 ++++++++++++++---
>  cpukit/include/rtems/score/scheduleredf.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/scheduleredfimpl.h | 25 ++++++++++++++---
>  cpukit/include/rtems/score/scheduleredfsmp.h  | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulerimpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulernode.h    | 25 ++++++++++++++---
>  .../include/rtems/score/schedulernodeimpl.h   | 25 ++++++++++++++---
>  .../include/rtems/score/schedulerpriority.h   | 25 ++++++++++++++---
>  .../score/schedulerpriorityaffinitysmp.h      | 25 ++++++++++++++---
>  .../rtems/score/schedulerpriorityimpl.h       | 25 ++++++++++++++---
>  .../rtems/score/schedulerprioritysmp.h        | 25 ++++++++++++++---
>  .../rtems/score/schedulerprioritysmpimpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulersimple.h  | 25 ++++++++++++++---
>  .../include/rtems/score/schedulersimpleimpl.h | 25 ++++++++++++++---
>  .../include/rtems/score/schedulersimplesmp.h  | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulersmp.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/schedulersmpimpl.h | 25 ++++++++++++++---
>  cpukit/include/rtems/score/semaphoreimpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smp.h              | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smpbarrier.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smpimpl.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smplock.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smplockmcs.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smplockseq.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smplockstats.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/smplockticket.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/stack.h            | 25 ++++++++++++++---
>  cpukit/include/rtems/score/stackimpl.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/states.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/statesimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/status.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/sysstate.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/thread.h           | 25 ++++++++++++++---
>  cpukit/include/rtems/score/threaddispatch.h   | 25 ++++++++++++++---
>  cpukit/include/rtems/score/threadimpl.h       | 25 ++++++++++++++---
>  cpukit/include/rtems/score/threadmp.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/threadq.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/threadqimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/timecounter.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/timecounterimpl.h  | 25 ++++++++++++++---
>  cpukit/include/rtems/score/timestamp.h        | 25 ++++++++++++++---
>  cpukit/include/rtems/score/timestampimpl.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/tls.h              | 25 ++++++++++++++---
>  cpukit/include/rtems/score/todimpl.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/userext.h          | 25 ++++++++++++++---
>  cpukit/include/rtems/score/userextdata.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/userextimpl.h      | 25 ++++++++++++++---
>  cpukit/include/rtems/score/watchdog.h         | 25 ++++++++++++++---
>  cpukit/include/rtems/score/watchdogimpl.h     | 25 ++++++++++++++---
>  cpukit/include/rtems/score/watchdogticks.h    | 25 ++++++++++++++---
>  cpukit/include/rtems/score/wkspace.h          | 25 ++++++++++++++---
>  cpukit/libblock/src/bdpart-create.c           | 25 ++++++++++++++---
>  cpukit/libblock/src/bdpart-dump.c             | 25 ++++++++++++++---
>  cpukit/libblock/src/bdpart-read.c             | 25 ++++++++++++++---
>  cpukit/libblock/src/bdpart-register.c         | 25 ++++++++++++++---
>  cpukit/libblock/src/bdpart-sort.c             | 25 ++++++++++++++---
>  cpukit/libblock/src/bdpart-write.c            | 25 ++++++++++++++---
>  cpukit/libblock/src/blkdev-blkstats.c         | 25 ++++++++++++++---
>  cpukit/libblock/src/blkdev-imfs.c             | 25 ++++++++++++++---
>  cpukit/libblock/src/blkdev-ops.c              | 25 ++++++++++++++---
>  cpukit/libblock/src/blkdev-print-stats.c      | 25 ++++++++++++++---
>  cpukit/libblock/src/diskdevs-init.c           | 25 ++++++++++++++---
>  cpukit/libblock/src/flashdisk.c               | 25 ++++++++++++++---
>  cpukit/libblock/src/ide_part_table.c          | 25 ++++++++++++++---
>  cpukit/libblock/src/media-desc.c              | 25 ++++++++++++++---
>  cpukit/libblock/src/media-dev-ident.c         | 25 ++++++++++++++---
>  cpukit/libblock/src/media-path.c              | 25 ++++++++++++++---
>  cpukit/libblock/src/media-server.c            | 25 ++++++++++++++---
>  cpukit/libblock/src/media.c                   | 25 ++++++++++++++---
>  cpukit/libblock/src/nvdisk-sram.c             | 25 ++++++++++++++---
>  cpukit/libblock/src/nvdisk.c                  | 25 ++++++++++++++---
>  cpukit/libblock/src/ramdisk-init.c            | 25 ++++++++++++++---
>  cpukit/libblock/src/ramdisk-register.c        | 25 ++++++++++++++---
>  cpukit/libblock/src/show_bdbuf.c              | 25 ++++++++++++++---
>  cpukit/libblock/src/sparse-disk.c             | 25 ++++++++++++++---
>  cpukit/posix/src/_execve.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/aio_cancel.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/aio_error.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/aio_fsync.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/aio_misc.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/aio_read.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/aio_return.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/aio_suspend.c                | 25 ++++++++++++++---
>  cpukit/posix/src/aio_write.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/alarm.c                      | 25 ++++++++++++++---
>  cpukit/posix/src/barrierattrdestroy.c         | 25 ++++++++++++++---
>  cpukit/posix/src/barrierattrgetpshared.c      | 25 ++++++++++++++---
>  cpukit/posix/src/barrierattrinit.c            | 25 ++++++++++++++---
>  cpukit/posix/src/barrierattrsetpshared.c      | 25 ++++++++++++++---
>  cpukit/posix/src/cancel.c                     | 25 ++++++++++++++---
>  cpukit/posix/src/cleanuppush.c                | 25 ++++++++++++++---
>  cpukit/posix/src/clockgetcpuclockid.c         | 25 ++++++++++++++---
>  cpukit/posix/src/clockgetres.c                | 25 ++++++++++++++---
>  cpukit/posix/src/clockgettime.c               | 25 ++++++++++++++---
>  cpukit/posix/src/clocknanosleep.c             | 25 ++++++++++++++---
>  cpukit/posix/src/clocksettime.c               | 25 ++++++++++++++---
>  cpukit/posix/src/condattrdestroy.c            | 25 ++++++++++++++---
>  cpukit/posix/src/condattrgetclock.c           | 25 ++++++++++++++---
>  cpukit/posix/src/condattrgetpshared.c         | 25 ++++++++++++++---
>  cpukit/posix/src/condattrinit.c               | 25 ++++++++++++++---
>  cpukit/posix/src/condattrsetclock.c           | 25 ++++++++++++++---
>  cpukit/posix/src/condattrsetpshared.c         | 25 ++++++++++++++---
>  cpukit/posix/src/condbroadcast.c              | 25 ++++++++++++++---
>  cpukit/posix/src/conddefaultattributes.c      | 25 ++++++++++++++---
>  cpukit/posix/src/conddestroy.c                | 25 ++++++++++++++---
>  cpukit/posix/src/condinit.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/condsignal.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/condsignalsupp.c             | 25 ++++++++++++++---
>  cpukit/posix/src/condtimedwait.c              | 25 ++++++++++++++---
>  cpukit/posix/src/condwait.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/condwaitsupp.c               | 25 ++++++++++++++---
>  cpukit/posix/src/fork.c                       | 25 ++++++++++++++---
>  cpukit/posix/src/getitimer.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/keycreate.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/keydelete.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/keygetspecific.c             | 25 ++++++++++++++---
>  cpukit/posix/src/keysetspecific.c             | 25 ++++++++++++++---
>  cpukit/posix/src/kill.c                       | 25 ++++++++++++++---
>  cpukit/posix/src/kill_r.c                     | 25 ++++++++++++++---
>  cpukit/posix/src/killinfo.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/lio_listio.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/mlock.c                      | 25 ++++++++++++++---
>  cpukit/posix/src/mlockall.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/mmap.c                       | 25 ++++++++++++++---
>  cpukit/posix/src/mprotect.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/mqueueclose.c                | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuedeletesupp.c           | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuegetattr.c              | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuenotify.c               | 25 ++++++++++++++---
>  cpukit/posix/src/mqueueopen.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuereceive.c              | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuerecvsupp.c             | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuesend.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuesendsupp.c             | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuesetattr.c              | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuetimedreceive.c         | 25 ++++++++++++++---
>  cpukit/posix/src/mqueuetimedsend.c            | 25 ++++++++++++++---
>  cpukit/posix/src/mqueueunlink.c               | 25 ++++++++++++++---
>  cpukit/posix/src/msync.c                      | 25 ++++++++++++++---
>  cpukit/posix/src/munlock.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/munlockall.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/munmap.c                     | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrdestroy.c           | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrgetprioceiling.c    | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrgetprotocol.c       | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrgetpshared.c        | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrgettype.c           | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrinit.c              | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrsetprioceiling.c    | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrsetprotocol.c       | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrsetpshared.c        | 25 ++++++++++++++---
>  cpukit/posix/src/mutexattrsettype.c           | 25 ++++++++++++++---
>  cpukit/posix/src/mutexdestroy.c               | 25 ++++++++++++++---
>  cpukit/posix/src/mutexgetprioceiling.c        | 25 ++++++++++++++---
>  cpukit/posix/src/mutexinit.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/mutexlock.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/mutexlocksupp.c              | 25 ++++++++++++++---
>  cpukit/posix/src/mutexsetprioceiling.c        | 25 ++++++++++++++---
>  cpukit/posix/src/mutextimedlock.c             | 25 ++++++++++++++---
>  cpukit/posix/src/mutextrylock.c               | 25 ++++++++++++++---
>  cpukit/posix/src/mutexunlock.c                | 25 ++++++++++++++---
>  cpukit/posix/src/nanosleep.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/pause.c                      | 25 ++++++++++++++---
>  cpukit/posix/src/pbarrierdestroy.c            | 25 ++++++++++++++---
>  cpukit/posix/src/pbarrierinit.c               | 25 ++++++++++++++---
>  cpukit/posix/src/pbarrierwait.c               | 25 ++++++++++++++---
>  cpukit/posix/src/posix_madvise.c              | 25 ++++++++++++++---
>  cpukit/posix/src/prwlockdestroy.c             | 25 ++++++++++++++---
>  cpukit/posix/src/prwlockinit.c                | 25 ++++++++++++++---
>  cpukit/posix/src/prwlockrdlock.c              | 25 ++++++++++++++---
>  cpukit/posix/src/prwlocktimedrdlock.c         | 25 ++++++++++++++---
>  cpukit/posix/src/prwlocktimedwrlock.c         | 25 ++++++++++++++---
>  cpukit/posix/src/prwlocktryrdlock.c           | 25 ++++++++++++++---
>  cpukit/posix/src/prwlocktrywrlock.c           | 25 ++++++++++++++---
>  cpukit/posix/src/prwlockunlock.c              | 25 ++++++++++++++---
>  cpukit/posix/src/prwlockwrlock.c              | 25 ++++++++++++++---
>  cpukit/posix/src/psignal.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/psignalclearprocesssignals.c | 25 ++++++++++++++---
>  cpukit/posix/src/psignalclearsignals.c        | 25 ++++++++++++++---
>  cpukit/posix/src/psignalsetprocesssignals.c   | 25 ++++++++++++++---
>  cpukit/posix/src/psignalunblockthread.c       | 25 ++++++++++++++---
>  cpukit/posix/src/pspindestroy.c               | 25 ++++++++++++++---
>  cpukit/posix/src/pspininit.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/pspinlock.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/pspinunlock.c                | 25 ++++++++++++++---
>  cpukit/posix/src/psxnametoid.c                | 25 ++++++++++++++---
>  cpukit/posix/src/psxpriorityisvalid.c         | 25 ++++++++++++++---
>  cpukit/posix/src/psxtimercreate.c             | 25 ++++++++++++++---
>  cpukit/posix/src/psxtimerdelete.c             | 25 ++++++++++++++---
>  cpukit/posix/src/psxtransschedparam.c         | 25 ++++++++++++++---
>  cpukit/posix/src/pthread.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadatfork.c              | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrdefault.c         | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrdestroy.c         | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetaffinitynp.c   | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetdetachstate.c  | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetguardsize.c    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetinheritsched.c | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetschedparam.c   | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetschedpolicy.c  | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetscope.c        | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetstack.c        | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetstackaddr.c    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrgetstacksize.c    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrinit.c            | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetaffinitynp.c   | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetdetachstate.c  | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetguardsize.c    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetinheritsched.c | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetschedparam.c   | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetschedpolicy.c  | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetscope.c        | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetstack.c        | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetstackaddr.c    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadattrsetstacksize.c    | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadconcurrency.c         | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadcreate.c              | 25 ++++++++++++++---
>  cpukit/posix/src/pthreaddetach.c              | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadequal.c               | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadexit.c                | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadgetaffinitynp.c       | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadgetattrnp.c           | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadgetcpuclockid.c       | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadgetnamenp.c           | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadgetschedparam.c       | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadinitthreads.c         | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadjoin.c                | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadkill.c                | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadonce.c                | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadsetaffinitynp.c       | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadsetnamenp.c           | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadsetschedparam.c       | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadsetschedprio.c        | 25 ++++++++++++++---
>  cpukit/posix/src/pthreadsigmask.c             | 25 ++++++++++++++---
>  cpukit/posix/src/rwlockattrdestroy.c          | 25 ++++++++++++++---
>  cpukit/posix/src/rwlockattrgetpshared.c       | 25 ++++++++++++++---
>  cpukit/posix/src/rwlockattrinit.c             | 25 ++++++++++++++---
>  cpukit/posix/src/rwlockattrsetpshared.c       | 25 ++++++++++++++---
>  cpukit/posix/src/sched_getparam.c             | 25 ++++++++++++++---
>  cpukit/posix/src/sched_getprioritymax.c       | 25 ++++++++++++++---
>  cpukit/posix/src/sched_getprioritymin.c       | 25 ++++++++++++++---
>  cpukit/posix/src/sched_getscheduler.c         | 25 ++++++++++++++---
>  cpukit/posix/src/sched_rr_get_interval.c      | 25 ++++++++++++++---
>  cpukit/posix/src/sched_setparam.c             | 25 ++++++++++++++---
>  cpukit/posix/src/sched_setscheduler.c         | 25 ++++++++++++++---
>  cpukit/posix/src/sched_yield.c                | 25 ++++++++++++++---
>  cpukit/posix/src/semaphoredeletesupp.c        | 25 ++++++++++++++---
>  cpukit/posix/src/semclose.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/semdestroy.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/semgetvalue.c                | 25 ++++++++++++++---
>  cpukit/posix/src/seminit.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/semopen.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/sempost.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/semtimedwait.c               | 25 ++++++++++++++---
>  cpukit/posix/src/semtrywait.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/semunlink.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/semwait.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/setcancelstate.c             | 25 ++++++++++++++---
>  cpukit/posix/src/setcanceltype.c              | 25 ++++++++++++++---
>  cpukit/posix/src/setitimer.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/shmheap.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/shmopen.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/shmunlink.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/shmwkspace.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/sigaction.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/sigaddset.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/sigdelset.c                  | 25 ++++++++++++++---
>  cpukit/posix/src/sigemptyset.c                | 25 ++++++++++++++---
>  cpukit/posix/src/sigfillset.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/sigismember.c                | 25 ++++++++++++++---
>  cpukit/posix/src/signal_2.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/sigpending.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/sigprocmask.c                | 25 ++++++++++++++---
>  cpukit/posix/src/sigqueue.c                   | 25 ++++++++++++++---
>  cpukit/posix/src/sigsuspend.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/sigtimedwait.c               | 25 ++++++++++++++---
>  cpukit/posix/src/sigwait.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/sigwaitinfo.c                | 25 ++++++++++++++---
>  cpukit/posix/src/sysconf.c                    | 25 ++++++++++++++---
>  cpukit/posix/src/testcancel.c                 | 25 ++++++++++++++---
>  cpukit/posix/src/timergetoverrun.c            | 25 ++++++++++++++---
>  cpukit/posix/src/timergettime.c               | 25 ++++++++++++++---
>  cpukit/posix/src/timersettime.c               | 25 ++++++++++++++---
>  cpukit/posix/src/ualarm.c                     | 25 ++++++++++++++---
>  cpukit/posix/src/vfork.c                      | 25 ++++++++++++++---
>  cpukit/posix/src/wait.c                       | 25 ++++++++++++++---
>  cpukit/posix/src/waitpid.c                    | 25 ++++++++++++++---
>  cpukit/rtems/src/barriercreate.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/barrierdelete.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/barrierrelease.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/barrierwait.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgetsecondssinceepoch.c  | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgettickspersecond.c     | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgettod.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgettodtimeval.c         | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgetuptime.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgetuptimenanoseconds.c  | 25 ++++++++++++++---
>  cpukit/rtems/src/clockgetuptimetimeval.c      | 25 ++++++++++++++---
>  cpukit/rtems/src/clockset.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/clocktick.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/clocktodtoseconds.c          | 25 ++++++++++++++---
>  cpukit/rtems/src/clocktodvalidate.c           | 25 ++++++++++++++---
>  cpukit/rtems/src/dpmemcreate.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/dpmemdelete.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/dpmemexternal2internal.c     | 25 ++++++++++++++---
>  cpukit/rtems/src/dpmeminternal2external.c     | 25 ++++++++++++++---
>  cpukit/rtems/src/eventmp.c                    | 25 ++++++++++++++---
>  cpukit/rtems/src/eventreceive.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/eventseize.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/eventsend.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/eventsurrender.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/intrbody.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/intrcatch.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/modes.c                      | 25 ++++++++++++++---
>  cpukit/rtems/src/mp.c                         | 25 ++++++++++++++---
>  cpukit/rtems/src/msgmp.c                      | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqbroadcast.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqconstruct.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqdelete.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqflush.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqgetnumberpending.c       | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqreceive.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqsend.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/msgqurgent.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/partcreate.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/partdelete.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/partgetbuffer.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/partmp.c                     | 25 ++++++++++++++---
>  cpukit/rtems/src/partreturnbuffer.c           | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemoncancel.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemoncreate.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemondelete.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemongetstatistics.c       | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemongetstatus.c           | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemonperiod.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemonreportstatistics.c    | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemonresetall.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemonresetstatistics.c     | 25 ++++++++++++++---
>  cpukit/rtems/src/ratemontimeout.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/regioncreate.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/regiondelete.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/regionextend.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/regiongetfreeinfo.c          | 25 ++++++++++++++---
>  cpukit/rtems/src/regiongetinfo.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/regiongetsegment.c           | 25 ++++++++++++++---
>  cpukit/rtems/src/regiongetsegmentsize.c       | 25 ++++++++++++++---
>  cpukit/rtems/src/regionprocessqueue.c         | 25 ++++++++++++++---
>  cpukit/rtems/src/regionresizesegment.c        | 25 ++++++++++++++---
>  cpukit/rtems/src/regionreturnsegment.c        | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsbuildid.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsbuildname.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectapimaximumclass.c | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectapiminimumclass.c | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectgetapiclassname.c | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectgetapiname.c      | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectgetclassicname.c  | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectgetclassinfo.c    | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectgetname.c         | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectidapimaximum.c    | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectidapiminimum.c    | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectidgetapi.c        | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectidgetclass.c      | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectidgetindex.c      | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectidgetnode.c       | 25 ++++++++++++++---
>  cpukit/rtems/src/rtemsobjectsetname.c         | 25 ++++++++++++++---
>  cpukit/rtems/src/scheduleraddprocessor.c      | 25 ++++++++++++++---
>  cpukit/rtems/src/schedulergetprocessorset.c   | 25 ++++++++++++++---
>  cpukit/rtems/src/schedulerident.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/scheduleridentbyprocessor.c  | 25 ++++++++++++++---
>  .../rtems/src/scheduleridentbyprocessorset.c  | 25 ++++++++++++++---
>  cpukit/rtems/src/schedulerremoveprocessor.c   | 25 ++++++++++++++---
>  cpukit/rtems/src/semcreate.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/semdelete.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/semflush.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/semmp.c                      | 25 ++++++++++++++---
>  cpukit/rtems/src/semobtain.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/semrelease.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/semsetpriority.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/signalcatch.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/signalmp.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/signalsend.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/statustext.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/statustoerrno.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/systemeventreceive.c         | 25 ++++++++++++++---
>  cpukit/rtems/src/systemeventsend.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/taskconstruct.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/taskdelete.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/taskexit.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/taskgetaffinity.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/taskgetpriority.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/taskgetscheduler.c           | 25 ++++++++++++++---
>  cpukit/rtems/src/taskinitusers.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/taskissuspended.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/taskiterate.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/taskmode.c                   | 25 ++++++++++++++---
>  cpukit/rtems/src/taskmp.c                     | 25 ++++++++++++++---
>  cpukit/rtems/src/taskrestart.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/taskresume.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/tasks.c                      | 25 ++++++++++++++---
>  cpukit/rtems/src/tasksetaffinity.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/tasksetpriority.c            | 25 ++++++++++++++---
>  cpukit/rtems/src/tasksetscheduler.c           | 25 ++++++++++++++---
>  cpukit/rtems/src/taskstart.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/tasksuspend.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/taskwakeafter.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/taskwakewhen.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/timercancel.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/timercreate.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/timerdelete.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/timerfireafter.c             | 25 ++++++++++++++---
>  cpukit/rtems/src/timerfirewhen.c              | 25 ++++++++++++++---
>  cpukit/rtems/src/timergetinfo.c               | 25 ++++++++++++++---
>  cpukit/rtems/src/timerreset.c                 | 25 ++++++++++++++---
>  cpukit/rtems/src/timerserver.c                | 25 ++++++++++++++---
>  cpukit/rtems/src/timerserverfireafter.c       | 25 ++++++++++++++---
>  cpukit/rtems/src/timerserverfirewhen.c        | 25 ++++++++++++++---
>  cpukit/rtems/src/workspace.c                  | 25 ++++++++++++++---
>  cpukit/rtems/src/workspacegreedy.c            | 25 ++++++++++++++---
>  cpukit/sapi/src/chainappendnotify.c           | 25 ++++++++++++++---
>  cpukit/sapi/src/chaingetnotify.c              | 25 ++++++++++++++---
>  cpukit/sapi/src/chaingetwait.c                | 25 ++++++++++++++---
>  cpukit/sapi/src/chainprependnotify.c          | 25 ++++++++++++++---
>  cpukit/sapi/src/chainprotected.c              | 25 ++++++++++++++---
>  cpukit/sapi/src/cpucounterconverter.c         | 25 ++++++++++++++---
>  cpukit/sapi/src/delaynano.c                   | 25 ++++++++++++++---
>  cpukit/sapi/src/delayticks.c                  | 25 ++++++++++++++---
>  cpukit/sapi/src/exinit.c                      | 25 ++++++++++++++---
>  cpukit/sapi/src/exshutdown.c                  | 25 ++++++++++++++---
>  cpukit/sapi/src/extensioncreate.c             | 25 ++++++++++++++---
>  cpukit/sapi/src/extensiondelete.c             | 25 ++++++++++++++---
>  cpukit/sapi/src/fatal.c                       | 25 ++++++++++++++---
>  cpukit/sapi/src/fatalsrctext.c                | 25 ++++++++++++++---
>  cpukit/sapi/src/getversionstring.c            | 25 ++++++++++++++---
>  cpukit/sapi/src/interrtext.c                  | 25 ++++++++++++++---
>  cpukit/sapi/src/io.c                          | 25 ++++++++++++++---
>  cpukit/sapi/src/ioclose.c                     | 25 ++++++++++++++---
>  cpukit/sapi/src/iocontrol.c                   | 25 ++++++++++++++---
>  cpukit/sapi/src/ioinitialize.c                | 25 ++++++++++++++---
>  cpukit/sapi/src/ioopen.c                      | 25 ++++++++++++++---
>  cpukit/sapi/src/ioread.c                      | 25 ++++++++++++++---
>  cpukit/sapi/src/ioregisterdriver.c            | 25 ++++++++++++++---
>  cpukit/sapi/src/iounregisterdriver.c          | 25 ++++++++++++++---
>  cpukit/sapi/src/iowrite.c                     | 25 ++++++++++++++---
>  cpukit/sapi/src/profilingiterate.c            | 25 ++++++++++++++---
>  cpukit/sapi/src/profilingreportxml.c          | 25 ++++++++++++++---
>  cpukit/sapi/src/rbheap.c                      | 25 ++++++++++++++---
>  cpukit/sapi/src/rbtree.c                      | 25 ++++++++++++++---
>  cpukit/sapi/src/rbtreefind.c                  | 25 ++++++++++++++---
>  cpukit/sapi/src/sapirbtreeinsert.c            | 25 ++++++++++++++---
>  cpukit/sapi/src/tcsimpleinstall.c             | 25 ++++++++++++++---
>  cpukit/sapi/src/version.c                     | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/__aeabi_read_tp.c        | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/__tls_get_addr.c         | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/arm-context-validate.S   | 25 ++++++++++++++---
>  .../cpu/arm/arm-context-volatile-clobber.S    | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/arm-exception-default.c  | 25 ++++++++++++++---
>  .../score/cpu/arm/arm-exception-frame-print.c | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/arm_exc_abort.S          | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/arm_exc_interrupt.S      | 25 ++++++++++++++---
>  .../score/cpu/arm/armv4-exception-default.S   | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv4-sync-synchronize.c | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7-thread-idle.c      | 25 ++++++++++++++---
>  .../score/cpu/arm/armv7m-context-initialize.c | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7m-context-restore.c | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7m-context-switch.c  | 25 ++++++++++++++---
>  .../score/cpu/arm/armv7m-exception-default.c  | 25 ++++++++++++++---
>  .../cpu/arm/armv7m-exception-handler-get.c    | 25 ++++++++++++++---
>  .../cpu/arm/armv7m-exception-handler-set.c    | 25 ++++++++++++++---
>  .../cpu/arm/armv7m-exception-priority-get.c   | 25 ++++++++++++++---
>  .../arm/armv7m-exception-priority-handler.c   | 25 ++++++++++++++---
>  .../cpu/arm/armv7m-exception-priority-set.c   | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7m-isr-dispatch.c    | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7m-isr-enter-leave.c | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7m-isr-level-get.c   | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/armv7m-isr-level-set.c   | 25 ++++++++++++++---
>  .../score/cpu/arm/armv7m-isr-vector-install.c | 25 ++++++++++++++---
>  .../cpu/arm/armv7m-multitasking-start-stop.c  | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/cpu.c                    | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/cpu_asm.S                | 25 ++++++++++++++---
>  .../score/cpu/arm/include/libcpu/arm-cp15.h   | 25 ++++++++++++++---
>  cpukit/score/cpu/arm/include/rtems/asm.h      | 25 ++++++++++++++---
>  .../score/cpu/arm/include/rtems/score/arm.h   | 25 ++++++++++++++---
>  .../score/cpu/arm/include/rtems/score/armv4.h | 25 ++++++++++++++---
>  .../cpu/arm/include/rtems/score/armv7m.h      | 25 ++++++++++++++---
>  .../score/cpu/arm/include/rtems/score/cpu.h   | 25 ++++++++++++++---
>  .../cpu/arm/include/rtems/score/cpu_asm.h     | 25 ++++++++++++++---
>  .../cpu/arm/include/rtems/score/cpuatomic.h   | 25 ++++++++++++++---
>  .../cpu/arm/include/rtems/score/cpuimpl.h     | 25 ++++++++++++++---
>  .../cpu/arm/include/rtems/score/paravirt.h    | 26 +++++++++++++++---
>  cpukit/score/cpu/i386/cpu.c                   | 23 +++++++++++++---
>  cpukit/score/cpu/i386/cpu_asm.S               | 25 ++++++++++++++---
>  .../score/cpu/i386/include/rtems/score/cpu.h  | 25 ++++++++++++++---
>  .../cpu/i386/include/rtems/score/cpuatomic.h  | 25 ++++++++++++++---
>  .../cpu/i386/include/rtems/score/cpuimpl.h    | 25 ++++++++++++++---
>  .../score/cpu/i386/include/rtems/score/i386.h | 25 ++++++++++++++---
>  .../score/cpu/i386/include/rtems/score/idtr.h | 25 ++++++++++++++---
>  .../cpu/i386/include/rtems/score/interrupts.h | 25 ++++++++++++++---
>  .../cpu/i386/include/rtems/score/paravirt.h   | 25 ++++++++++++++---
>  .../cpu/i386/include/rtems/score/registers.h  | 25 ++++++++++++++---
>  cpukit/score/cpu/m68k/__m68k_read_tp.c        | 25 ++++++++++++++---
>  cpukit/score/cpu/m68k/cpu.c                   | 25 ++++++++++++++---
>  cpukit/score/cpu/m68k/cpu_asm.S               | 25 ++++++++++++++---
>  .../score/cpu/m68k/include/rtems/score/cpu.h  | 25 ++++++++++++++---
>  .../cpu/m68k/include/rtems/score/cpuatomic.h  | 25 ++++++++++++++---
>  .../cpu/m68k/include/rtems/score/cpuimpl.h    | 25 ++++++++++++++---
>  .../score/cpu/m68k/include/rtems/score/m68k.h | 25 ++++++++++++++---
>  .../cpu/m68k/m68k-exception-frame-print.c     | 25 ++++++++++++++---
>  cpukit/score/cpu/mips/cpu.c                   | 25 ++++++++++++++---
>  cpukit/score/cpu/mips/cpu_asm.S               | 25 ++++++++++++++---
>  .../score/cpu/mips/include/rtems/score/cpu.h  | 25 ++++++++++++++---
>  .../cpu/mips/include/rtems/score/cpuatomic.h  | 25 ++++++++++++++---
>  .../cpu/mips/include/rtems/score/cpuimpl.h    | 25 ++++++++++++++---
>  .../score/cpu/mips/include/rtems/score/mips.h | 25 ++++++++++++++---
>  .../score/cpu/nios2/include/rtems/score/cpu.h | 25 ++++++++++++++---
>  .../cpu/nios2/include/rtems/score/cpu_asm.h   | 25 ++++++++++++++---
>  .../cpu/nios2/include/rtems/score/cpuatomic.h | 25 ++++++++++++++---
>  .../cpu/nios2/include/rtems/score/cpuimpl.h   | 25 ++++++++++++++---
>  .../include/rtems/score/nios2-count-zeros.h   | 25 ++++++++++++++---
>  .../nios2/include/rtems/score/nios2-utility.h | 25 ++++++++++++++---
>  .../cpu/nios2/include/rtems/score/nios2.h     | 25 ++++++++++++++---
>  .../cpu/nios2/nios2-context-initialize.c      | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-context-switch.S | 25 ++++++++++++++---
>  .../score/cpu/nios2/nios2-context-validate.S  | 25 ++++++++++++++---
>  .../nios2/nios2-context-volatile-clobber.S    | 25 ++++++++++++++---
>  .../score/cpu/nios2/nios2-eic-il-low-level.S  | 25 ++++++++++++++---
>  .../cpu/nios2/nios2-exception-frame-print.c   | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-fatal-halt.c     | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-iic-irq.c        | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-iic-low-level.S  | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-initialize.c     | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-isr-get-level.c  | 25 ++++++++++++++---
>  .../cpu/nios2/nios2-isr-install-vector.c      | 25 ++++++++++++++---
>  .../cpu/nios2/nios2-isr-is-in-progress.c      | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-isr-set-level.c  | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-mpu-add-region.c | 25 ++++++++++++++---
>  .../score/cpu/nios2/nios2-mpu-configuration.c | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-mpu-descriptor.c | 25 ++++++++++++++---
>  .../cpu/nios2/nios2-mpu-disable-protected.c   | 25 ++++++++++++++---
>  cpukit/score/cpu/nios2/nios2-mpu-reset.c      | 25 ++++++++++++++---
>  .../nios2/nios2-thread-dispatch-disabled.c    | 25 ++++++++++++++---
>  cpukit/score/cpu/no_cpu/cpu.c                 | 25 ++++++++++++++---
>  cpukit/score/cpu/no_cpu/cpu_asm.c             | 25 ++++++++++++++---
>  cpukit/score/cpu/no_cpu/cpucounterfrequency.c | 25 ++++++++++++++---
>  cpukit/score/cpu/no_cpu/cpucounterread.c      | 25 ++++++++++++++---
>  cpukit/score/cpu/no_cpu/cpuidle.c             | 25 ++++++++++++++---
>  .../cpu/no_cpu/include/rtems/score/cpu.h      | 25 ++++++++++++++---
>  .../cpu/no_cpu/include/rtems/score/cpu_asm.h  | 25 ++++++++++++++---
>  .../cpu/no_cpu/include/rtems/score/cpuimpl.h  | 25 ++++++++++++++---
>  .../cpu/no_cpu/include/rtems/score/no_cpu.h   | 25 ++++++++++++++---
>  cpukit/score/cpu/or1k/cpu.c                   | 25 ++++++++++++++---
>  .../score/cpu/or1k/include/rtems/score/cpu.h  | 25 ++++++++++++++---
>  .../cpu/or1k/include/rtems/score/cpu_asm.h    | 25 ++++++++++++++---
>  .../cpu/or1k/include/rtems/score/cpuatomic.h  | 25 ++++++++++++++---
>  .../cpu/or1k/include/rtems/score/cpuimpl.h    | 25 ++++++++++++++---
>  .../or1k/include/rtems/score/or1k-utility.h   | 25 ++++++++++++++---
>  .../score/cpu/or1k/include/rtems/score/or1k.h | 25 ++++++++++++++---
>  .../score/cpu/or1k/or1k-context-initialize.c  | 25 ++++++++++++++---
>  cpukit/score/cpu/or1k/or1k-context-switch.S   | 25 ++++++++++++++---
>  cpukit/score/cpu/or1k/or1k-context-validate.S | 25 ++++++++++++++---
>  .../cpu/or1k/or1k-context-volatile-clobber.S  | 25 ++++++++++++++---
>  .../score/cpu/or1k/or1k-exception-default.c   | 25 ++++++++++++++---
>  .../cpu/or1k/or1k-exception-frame-print.c     | 25 ++++++++++++++---
>  .../cpu/or1k/or1k-exception-handler-low.S     | 25 ++++++++++++++---
>  cpukit/score/cpu/powerpc/cpu.c                | 25 ++++++++++++++---
>  .../powerpc/include/rtems/powerpc/registers.h | 25 ++++++++++++++---
>  .../cpu/powerpc/include/rtems/score/cpu.h     | 25 ++++++++++++++---
>  .../powerpc/include/rtems/score/cpuatomic.h   | 25 ++++++++++++++---
>  .../cpu/powerpc/include/rtems/score/cpuimpl.h | 25 ++++++++++++++---
>  .../powerpc/include/rtems/score/paravirt.h    | 26 +++++++++++++++---
>  .../cpu/powerpc/include/rtems/score/powerpc.h | 27 ++++++++++++++-----
>  .../score/cpu/powerpc/ppc-context-validate.S  | 25 ++++++++++++++---
>  .../powerpc/ppc-context-volatile-clobber.S    | 25 ++++++++++++++---
>  .../score/cpu/powerpc/ppc-isr-disable-mask.S  | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/access_le.c            | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/cpu.c                  | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/cpu_asm.S              | 25 ++++++++++++++---
>  .../score/cpu/sparc/include/libcpu/access.h   | 25 ++++++++++++++---
>  .../cpu/sparc/include/libcpu/byteorder.h      | 25 ++++++++++++++---
>  .../score/cpu/sparc/include/rtems/score/cpu.h | 25 ++++++++++++++---
>  .../cpu/sparc/include/rtems/score/cpuatomic.h | 25 ++++++++++++++---
>  .../cpu/sparc/include/rtems/score/cpuimpl.h   | 25 ++++++++++++++---
>  .../cpu/sparc/include/rtems/score/sparc.h     | 25 ++++++++++++++---
>  .../cpu/sparc/include/rtems/score/sparcimpl.h | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/sparc-access.S         | 25 ++++++++++++++---
>  .../score/cpu/sparc/sparc-context-validate.S  | 25 ++++++++++++++---
>  .../sparc/sparc-context-volatile-clobber.S    | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/sparc-counter-asm.S    | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/sparc-isr-handler.S    | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc/sparc-isr-install.c    | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc64/context.S            | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc64/cpu.c                | 25 ++++++++++++++---
>  .../cpu/sparc64/include/rtems/score/cpu.h     | 25 ++++++++++++++---
>  .../sparc64/include/rtems/score/cpuatomic.h   | 25 ++++++++++++++---
>  .../cpu/sparc64/include/rtems/score/cpuimpl.h | 25 ++++++++++++++---
>  .../cpu/sparc64/include/rtems/score/sparc64.h | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc64/interrupt.S          | 25 ++++++++++++++---
>  .../sparc64/sparc64-exception-frame-print.c   | 25 ++++++++++++++---
>  cpukit/score/cpu/sparc64/sparc64-syscall.S    | 25 ++++++++++++++---
>  cpukit/score/cpu/v850/cpu.c                   | 25 ++++++++++++++---
>  cpukit/score/cpu/v850/cpu_asm.S               | 25 ++++++++++++++---
>  .../score/cpu/v850/include/rtems/score/cpu.h  | 25 ++++++++++++++---
>  .../cpu/v850/include/rtems/score/cpu_asm.h    | 25 ++++++++++++++---
>  .../cpu/v850/include/rtems/score/cpuatomic.h  | 25 ++++++++++++++---
>  .../cpu/v850/include/rtems/score/cpuimpl.h    | 25 ++++++++++++++---
>  .../score/cpu/v850/include/rtems/score/v850.h | 25 ++++++++++++++---
>  .../cpu/v850/v850-exception-frame-print.c     | 25 ++++++++++++++---
>  cpukit/score/src/allocatormutex.c             | 25 ++++++++++++++---
>  cpukit/score/src/apimutexisowner.c            | 25 ++++++++++++++---
>  cpukit/score/src/apimutexlock.c               | 25 ++++++++++++++---
>  cpukit/score/src/apimutexunlock.c             | 25 ++++++++++++++---
>  cpukit/score/src/chain.c                      | 25 ++++++++++++++---
>  cpukit/score/src/chainnodecount.c             | 25 ++++++++++++++---
>  cpukit/score/src/condition.c                  | 25 ++++++++++++++---
>  cpukit/score/src/corebarrier.c                | 25 ++++++++++++++---
>  cpukit/score/src/corebarrierwait.c            | 25 ++++++++++++++---
>  cpukit/score/src/coremsg.c                    | 25 ++++++++++++++---
>  cpukit/score/src/coremsgbroadcast.c           | 25 ++++++++++++++---
>  cpukit/score/src/coremsgclose.c               | 25 ++++++++++++++---
>  cpukit/score/src/coremsgflush.c               | 25 ++++++++++++++---
>  cpukit/score/src/coremsgflushwait.c           | 25 ++++++++++++++---
>  cpukit/score/src/coremsginsert.c              | 25 ++++++++++++++---
>  cpukit/score/src/coremsgseize.c               | 25 ++++++++++++++---
>  cpukit/score/src/coremsgsubmit.c              | 25 ++++++++++++++---
>  cpukit/score/src/coremutexseize.c             | 25 ++++++++++++++---
>  cpukit/score/src/corerwlock.c                 | 25 ++++++++++++++---
>  cpukit/score/src/corerwlockobtainread.c       | 25 ++++++++++++++---
>  cpukit/score/src/corerwlockobtainwrite.c      | 25 ++++++++++++++---
>  cpukit/score/src/corerwlockrelease.c          | 25 ++++++++++++++---
>  cpukit/score/src/coresem.c                    | 25 ++++++++++++++---
>  cpukit/score/src/coretod.c                    | 25 ++++++++++++++---
>  cpukit/score/src/coretodadjust.c              | 25 ++++++++++++++---
>  cpukit/score/src/coretodset.c                 | 25 ++++++++++++++---
>  .../src/debugisthreaddispatchingallowed.c     | 25 ++++++++++++++---
>  cpukit/score/src/freechain.c                  | 25 ++++++++++++++---
>  cpukit/score/src/futex.c                      | 25 ++++++++++++++---
>  cpukit/score/src/heap.c                       | 25 ++++++++++++++---
>  cpukit/score/src/heapallocate.c               | 25 ++++++++++++++---
>  cpukit/score/src/heapextend.c                 | 25 ++++++++++++++---
>  cpukit/score/src/heapfree.c                   | 25 ++++++++++++++---
>  cpukit/score/src/heapgetfreeinfo.c            | 25 ++++++++++++++---
>  cpukit/score/src/heapgetinfo.c                | 25 ++++++++++++++---
>  cpukit/score/src/heapgreedy.c                 | 25 ++++++++++++++---
>  cpukit/score/src/heapiterate.c                | 25 ++++++++++++++---
>  cpukit/score/src/heapnoextend.c               | 25 ++++++++++++++---
>  cpukit/score/src/heapresizeblock.c            | 25 ++++++++++++++---
>  cpukit/score/src/heapsizeofuserarea.c         | 25 ++++++++++++++---
>  cpukit/score/src/heapwalk.c                   | 25 ++++++++++++++---
>  cpukit/score/src/interr.c                     | 25 ++++++++++++++---
>  cpukit/score/src/ioprintf.c                   | 25 ++++++++++++++---
>  cpukit/score/src/isr.c                        | 25 ++++++++++++++---
>  cpukit/score/src/isrisinprogress.c            | 25 ++++++++++++++---
>  cpukit/score/src/iterateoverthreads.c         | 25 ++++++++++++++---
>  cpukit/score/src/libatomic.c                  | 25 ++++++++++++++---
>  cpukit/score/src/log2table.c                  | 25 ++++++++++++++---
>  cpukit/score/src/mpci.c                       | 25 ++++++++++++++---
>  cpukit/score/src/mpcidefault.c                | 25 ++++++++++++++---
>  cpukit/score/src/mutex.c                      | 25 ++++++++++++++---
>  cpukit/score/src/objectactivecount.c          | 25 ++++++++++++++---
>  cpukit/score/src/objectapimaximumclass.c      | 25 ++++++++++++++---
>  cpukit/score/src/objectclose.c                | 25 ++++++++++++++---
>  cpukit/score/src/objectextendinformation.c    | 25 ++++++++++++++---
>  cpukit/score/src/objectfree.c                 | 25 ++++++++++++++---
>  cpukit/score/src/objectgetinfo.c              | 25 ++++++++++++++---
>  cpukit/score/src/objectgetinfoid.c            | 25 ++++++++++++++---
>  cpukit/score/src/objectgetlocal.c             | 25 ++++++++++++++---
>  cpukit/score/src/objectgetnameasstring.c      | 25 ++++++++++++++---
>  cpukit/score/src/objectgetnext.c              | 25 ++++++++++++++---
>  cpukit/score/src/objectgetnoprotection.c      | 25 ++++++++++++++---
>  cpukit/score/src/objectidtoname.c             | 25 ++++++++++++++---
>  .../score/src/objectinitializeinformation.c   | 25 ++++++++++++++---
>  cpukit/score/src/objectmp.c                   | 25 ++++++++++++++---
>  cpukit/score/src/objectnamespaceremove.c      | 25 ++++++++++++++---
>  cpukit/score/src/objectnametoid.c             | 25 ++++++++++++++---
>  cpukit/score/src/objectnametoidstring.c       | 25 ++++++++++++++---
>  cpukit/score/src/objectsetname.c              | 25 ++++++++++++++---
>  cpukit/score/src/objectshrinkinformation.c    | 25 ++++++++++++++---
>  cpukit/score/src/percpu.c                     | 25 ++++++++++++++---
>  cpukit/score/src/percpuasm.c                  | 25 ++++++++++++++---
>  cpukit/score/src/percpustatewait.c            | 25 ++++++++++++++---
>  cpukit/score/src/pheapallocate.c              | 25 ++++++++++++++---
>  cpukit/score/src/pheapextend.c                | 25 ++++++++++++++---
>  cpukit/score/src/pheapfree.c                  | 25 ++++++++++++++---
>  cpukit/score/src/pheapgetblocksize.c          | 25 ++++++++++++++---
>  cpukit/score/src/pheapgetfreeinfo.c           | 25 ++++++++++++++---
>  cpukit/score/src/pheapgetinfo.c               | 25 ++++++++++++++---
>  cpukit/score/src/pheapgetsize.c               | 25 ++++++++++++++---
>  cpukit/score/src/pheapiterate.c               | 25 ++++++++++++++---
>  cpukit/score/src/pheapresizeblock.c           | 25 ++++++++++++++---
>  cpukit/score/src/pheapwalk.c                  | 25 ++++++++++++++---
>  cpukit/score/src/processormaskcopy.c          | 25 ++++++++++++++---
>  cpukit/score/src/profilingisrentryexit.c      | 25 ++++++++++++++---
>  cpukit/score/src/profilingsmplock.c           | 25 ++++++++++++++---
>  cpukit/score/src/rbtreeextract.c              | 25 ++++++++++++++---
>  cpukit/score/src/rbtreeinsert.c               | 25 ++++++++++++++---
>  cpukit/score/src/rbtreeiterate.c              | 25 ++++++++++++++---
>  cpukit/score/src/rbtreepostorder.c            | 25 ++++++++++++++---
>  cpukit/score/src/rbtreereplace.c              | 25 ++++++++++++++---
>  cpukit/score/src/sched.c                      | 25 ++++++++++++++---
>  cpukit/score/src/scheduler.c                  | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbs.c               | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsattachthread.c   | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbscleanup.c        | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbscreateserver.c   | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsdestroyserver.c  | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsdetachthread.c   | 25 ++++++++++++++---
>  .../score/src/schedulercbsgetapprovedbudget.c | 25 ++++++++++++++---
>  .../score/src/schedulercbsgetexecutiontime.c  | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsgetparameters.c  | 25 ++++++++++++++---
>  .../src/schedulercbsgetremainingbudget.c      | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsgetserverid.c    | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsnodeinit.c       | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsreleasejob.c     | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbssetparameters.c  | 25 ++++++++++++++---
>  cpukit/score/src/schedulercbsunblock.c        | 25 ++++++++++++++---
>  .../score/src/schedulerdefaultmappriority.c   | 25 ++++++++++++++---
>  .../score/src/schedulerdefaultnodedestroy.c   | 25 ++++++++++++++---
>  cpukit/score/src/schedulerdefaultnodeinit.c   | 25 ++++++++++++++---
>  cpukit/score/src/schedulerdefaultreleasejob.c | 25 ++++++++++++++---
>  cpukit/score/src/schedulerdefaultschedule.c   | 25 ++++++++++++++---
>  .../score/src/schedulerdefaultsetaffinity.c   | 25 ++++++++++++++---
>  cpukit/score/src/schedulerdefaultstartidle.c  | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredf.c               | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfblock.c          | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfchangepriority.c | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfnodeinit.c       | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfreleasejob.c     | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfschedule.c       | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfsmp.c            | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfunblock.c        | 25 ++++++++++++++---
>  cpukit/score/src/scheduleredfyield.c          | 25 ++++++++++++++---
>  cpukit/score/src/schedulergetaffinity.c       | 25 ++++++++++++++---
>  cpukit/score/src/schedulerpriority.c          | 25 ++++++++++++++---
>  .../score/src/schedulerpriorityaffinitysmp.c  | 25 ++++++++++++++---
>  cpukit/score/src/schedulerpriorityblock.c     | 25 ++++++++++++++---
>  .../src/schedulerprioritychangepriority.c     | 25 ++++++++++++++---
>  cpukit/score/src/schedulerpriorityschedule.c  | 25 ++++++++++++++---
>  cpukit/score/src/schedulerprioritysmp.c       | 25 ++++++++++++++---
>  cpukit/score/src/schedulerpriorityunblock.c   | 25 ++++++++++++++---
>  cpukit/score/src/schedulerpriorityyield.c     | 25 ++++++++++++++---
>  cpukit/score/src/schedulersetaffinity.c       | 25 ++++++++++++++---
>  cpukit/score/src/schedulersimple.c            | 25 ++++++++++++++---
>  cpukit/score/src/schedulersimpleblock.c       | 27 ++++++++++++++++---
>  .../score/src/schedulersimplechangepriority.c | 25 ++++++++++++++---
>  cpukit/score/src/schedulersimpleschedule.c    | 27 ++++++++++++++++---
>  cpukit/score/src/schedulersimplesmp.c         | 25 ++++++++++++++---
>  cpukit/score/src/schedulersimpleunblock.c     | 27 ++++++++++++++++---
>  cpukit/score/src/schedulersimpleyield.c       | 27 ++++++++++++++++---
>  cpukit/score/src/schedulersmp.c               | 25 ++++++++++++++---
>  cpukit/score/src/schedulersmpstartidle.c      | 25 ++++++++++++++---
>  cpukit/score/src/semaphore.c                  | 25 ++++++++++++++---
>  cpukit/score/src/smp.c                        | 25 ++++++++++++++---
>  cpukit/score/src/smpbarrierwait.c             | 25 ++++++++++++++---
>  cpukit/score/src/smplock.c                    | 25 ++++++++++++++---
>  cpukit/score/src/thread.c                     | 25 ++++++++++++++---
>  cpukit/score/src/threadchangepriority.c       | 25 ++++++++++++++---
>  cpukit/score/src/threadclearstate.c           | 25 ++++++++++++++---
>  cpukit/score/src/threadcreateidle.c           | 25 ++++++++++++++---
>  cpukit/score/src/threaddispatch.c             | 25 ++++++++++++++---
>  cpukit/score/src/threadentryadaptoridle.c     | 25 ++++++++++++++---
>  cpukit/score/src/threadentryadaptornumeric.c  | 25 ++++++++++++++---
>  cpukit/score/src/threadentryadaptorpointer.c  | 25 ++++++++++++++---
>  cpukit/score/src/threadget.c                  | 25 ++++++++++++++---
>  cpukit/score/src/threadgetcputimeused.c       | 25 ++++++++++++++---
>  cpukit/score/src/threadhandler.c              | 25 ++++++++++++++---
>  cpukit/score/src/threadinitialize.c           | 25 ++++++++++++++---
>  cpukit/score/src/threaditerate.c              | 25 ++++++++++++++---
>  cpukit/score/src/threadloadenv.c              | 25 ++++++++++++++---
>  cpukit/score/src/threadmp.c                   | 25 ++++++++++++++---
>  cpukit/score/src/threadname.c                 | 25 ++++++++++++++---
>  cpukit/score/src/threadq.c                    | 25 ++++++++++++++---
>  cpukit/score/src/threadqenqueue.c             | 25 ++++++++++++++---
>  cpukit/score/src/threadqextract.c             | 25 ++++++++++++++---
>  cpukit/score/src/threadqextractwithproxy.c    | 25 ++++++++++++++---
>  cpukit/score/src/threadqfirst.c               | 25 ++++++++++++++---
>  cpukit/score/src/threadqflush.c               | 25 ++++++++++++++---
>  cpukit/score/src/threadqops.c                 | 25 ++++++++++++++---
>  cpukit/score/src/threadqtimeout.c             | 25 ++++++++++++++---
>  cpukit/score/src/threadrestart.c              | 25 ++++++++++++++---
>  cpukit/score/src/threadscheduler.c            | 25 ++++++++++++++---
>  cpukit/score/src/threadsetstate.c             | 25 ++++++++++++++---
>  cpukit/score/src/threadstackallocate.c        | 25 ++++++++++++++---
>  cpukit/score/src/threadstackfree.c            | 25 ++++++++++++++---
>  cpukit/score/src/threadstart.c                | 25 ++++++++++++++---
>  cpukit/score/src/threadstartmultitasking.c    | 25 ++++++++++++++---
>  cpukit/score/src/threadtimeout.c              | 25 ++++++++++++++---
>  cpukit/score/src/threadunpin.c                | 25 ++++++++++++++---
>  cpukit/score/src/threadwaitgetid.c            | 25 ++++++++++++++---
>  cpukit/score/src/threadyield.c                | 25 ++++++++++++++---
>  cpukit/score/src/timespecaddto.c              | 25 ++++++++++++++---
>  cpukit/score/src/timespecdivide.c             | 25 ++++++++++++++---
>  cpukit/score/src/timespecdividebyinteger.c    | 25 ++++++++++++++---
>  cpukit/score/src/timespecfromticks.c          | 25 ++++++++++++++---
>  cpukit/score/src/timespecgetasnanoseconds.c   | 25 ++++++++++++++---
>  cpukit/score/src/timespecisvalid.c            | 25 ++++++++++++++---
>  cpukit/score/src/timespeclessthan.c           | 25 ++++++++++++++---
>  cpukit/score/src/timespecsubtract.c           | 25 ++++++++++++++---
>  cpukit/score/src/timespectoticks.c            | 25 ++++++++++++++---
>  cpukit/score/src/userext.c                    | 25 ++++++++++++++---
>  cpukit/score/src/userextaddset.c              | 25 ++++++++++++++---
>  cpukit/score/src/userextiterate.c             | 25 ++++++++++++++---
>  cpukit/score/src/userextremoveset.c           | 25 ++++++++++++++---
>  cpukit/score/src/watchdoginsert.c             | 25 ++++++++++++++---
>  cpukit/score/src/watchdogremove.c             | 25 ++++++++++++++---
>  cpukit/score/src/watchdogtick.c               | 25 ++++++++++++++---
>  cpukit/score/src/watchdogtickssinceboot.c     | 25 ++++++++++++++---
>  cpukit/score/src/wkstringduplicate.c          | 25 ++++++++++++++---
>  958 files changed, 21081 insertions(+), 2879 deletions(-)
> 2.24.4
> devel mailing list
> devel at rtems.org
