[PATCH 27/27] cpukit/libblock: Change license to BSD-2
Fri Feb 25 18:06:12 UTC 2022
Updates #3053.
 cpukit/libblock/src/bdpart-create.c      | 25 +++++++++++++++++++++---
 cpukit/libblock/src/bdpart-dump.c        | 25 +++++++++++++++++++++---
 cpukit/libblock/src/bdpart-read.c        | 25 +++++++++++++++++++++---
 cpukit/libblock/src/bdpart-register.c    | 25 +++++++++++++++++++++---
 cpukit/libblock/src/bdpart-sort.c        | 25 +++++++++++++++++++++---
 cpukit/libblock/src/bdpart-write.c       | 25 +++++++++++++++++++++---
 cpukit/libblock/src/blkdev-blkstats.c    | 25 +++++++++++++++++++++---
 cpukit/libblock/src/blkdev-imfs.c        | 25 +++++++++++++++++++++---
 cpukit/libblock/src/blkdev-ops.c         | 25 +++++++++++++++++++++---
 cpukit/libblock/src/blkdev-print-stats.c | 25 +++++++++++++++++++++---
 cpukit/libblock/src/diskdevs-init.c      | 25 +++++++++++++++++++++---
 cpukit/libblock/src/flashdisk.c          | 25 +++++++++++++++++++++---
 cpukit/libblock/src/ide_part_table.c     | 25 +++++++++++++++++++++---
 cpukit/libblock/src/media-desc.c         | 25 +++++++++++++++++++++---
 cpukit/libblock/src/media-dev-ident.c    | 25 +++++++++++++++++++++---
 cpukit/libblock/src/media-path.c         | 25 +++++++++++++++++++++---
 cpukit/libblock/src/media-server.c       | 25 +++++++++++++++++++++---
 cpukit/libblock/src/media.c              | 25 +++++++++++++++++++++---
 cpukit/libblock/src/nvdisk-sram.c        | 25 +++++++++++++++++++++---
 cpukit/libblock/src/nvdisk.c             | 25 +++++++++++++++++++++---
 cpukit/libblock/src/ramdisk-init.c       | 25 +++++++++++++++++++++---
 cpukit/libblock/src/ramdisk-register.c   | 25 +++++++++++++++++++++---
 cpukit/libblock/src/show_bdbuf.c         | 25 +++++++++++++++++++++---
 cpukit/libblock/src/sparse-disk.c        | 25 +++++++++++++++++++++---
 24 files changed, 528 insertions(+), 72 deletions(-)
diff --git a/cpukit/libblock/src/bdpart-create.c b/cpukit/libblock/src/bdpart-create.c
index 8bfc1de302..0ff18cf6e6 100644
--- a/cpukit/libblock/src/bdpart-create.c
+++ b/cpukit/libblock/src/bdpart-create.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  * Germany
  * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libblock/src/bdpart-dump.c b/cpukit/libblock/src/bdpart-dump.c
index ce58a0020f..7da41a73ef 100644
--- a/cpukit/libblock/src/bdpart-dump.c
+++ b/cpukit/libblock/src/bdpart-dump.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  * Germany
+ * are met:
diff --git a/cpukit/libblock/src/bdpart-read.c b/cpukit/libblock/src/bdpart-read.c
index cfebdbc9d4..abef4cf4e1 100644
--- a/cpukit/libblock/src/bdpart-read.c
+++ b/cpukit/libblock/src/bdpart-read.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  * Germany
+ * are met:
diff --git a/cpukit/libblock/src/bdpart-register.c b/cpukit/libblock/src/bdpart-register.c
index 857c0163bd..a7cedfd885 100644
--- a/cpukit/libblock/src/bdpart-register.c
+++ b/cpukit/libblock/src/bdpart-register.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/bdpart-sort.c b/cpukit/libblock/src/bdpart-sort.c
index 52de38b442..74f4b8a751 100644
--- a/cpukit/libblock/src/bdpart-sort.c
+++ b/cpukit/libblock/src/bdpart-sort.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  * Germany
+ * are met:
diff --git a/cpukit/libblock/src/bdpart-write.c b/cpukit/libblock/src/bdpart-write.c
index 0418e82850..05d18193b3 100644
--- a/cpukit/libblock/src/bdpart-write.c
+++ b/cpukit/libblock/src/bdpart-write.c
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  * Germany
+ * are met:
diff --git a/cpukit/libblock/src/blkdev-blkstats.c b/cpukit/libblock/src/blkdev-blkstats.c
index a6b336af2d..5dfe5669d1 100644
--- a/cpukit/libblock/src/blkdev-blkstats.c
+++ b/cpukit/libblock/src/blkdev-blkstats.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
index c7e582cfbc..21e864b55b 100644
--- a/cpukit/libblock/src/blkdev-imfs.c
+++ b/cpukit/libblock/src/blkdev-imfs.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/blkdev-ops.c b/cpukit/libblock/src/blkdev-ops.c
index a25857ed4f..3f2cb1b028 100644
--- a/cpukit/libblock/src/blkdev-ops.c
+++ b/cpukit/libblock/src/blkdev-ops.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
 #include <rtems/blkdev.h>
diff --git a/cpukit/libblock/src/blkdev-print-stats.c b/cpukit/libblock/src/blkdev-print-stats.c
index 539ff08157..8134e2efb2 100644
--- a/cpukit/libblock/src/blkdev-print-stats.c
+++ b/cpukit/libblock/src/blkdev-print-stats.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/diskdevs-init.c b/cpukit/libblock/src/diskdevs-init.c
index 35923506bc..d2e16cfea7 100644
--- a/cpukit/libblock/src/diskdevs-init.c
+++ b/cpukit/libblock/src/diskdevs-init.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index 91f99e0d52..65751bad9e 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (C) 2007 Chris Johns
+ * are met:
diff --git a/cpukit/libblock/src/ide_part_table.c b/cpukit/libblock/src/ide_part_table.c
index a802be5dfb..2ce48c37aa 100644
--- a/cpukit/libblock/src/ide_part_table.c
+++ b/cpukit/libblock/src/ide_part_table.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
  * Author: Konstantin Abramenko <Konstantin.Abramenko at oktet.ru>
  *         Alexander Kukuta <Alexander.Kukuta at oktet.ru>
+ * are met:
diff --git a/cpukit/libblock/src/media-desc.c b/cpukit/libblock/src/media-desc.c
index ffe3a0b222..ed30491b8c 100644
--- a/cpukit/libblock/src/media-desc.c
+++ b/cpukit/libblock/src/media-desc.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
 #include <rtems/media.h>
diff --git a/cpukit/libblock/src/media-dev-ident.c b/cpukit/libblock/src/media-dev-ident.c
index 32958f227b..237c7b9838 100644
--- a/cpukit/libblock/src/media-dev-ident.c
+++ b/cpukit/libblock/src/media-dev-ident.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
 #include <sys/types.h>
diff --git a/cpukit/libblock/src/media-path.c b/cpukit/libblock/src/media-path.c
index 12b0fa36bc..ab65edbe7f 100644
--- a/cpukit/libblock/src/media-path.c
+++ b/cpukit/libblock/src/media-path.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/media-server.c b/cpukit/libblock/src/media-server.c
index 3bcc822d20..0e1b609dee 100644
--- a/cpukit/libblock/src/media-server.c
+++ b/cpukit/libblock/src/media-server.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/media.c b/cpukit/libblock/src/media.c
index c176e12243..5a70c9f7d8 100644
--- a/cpukit/libblock/src/media.c
+++ b/cpukit/libblock/src/media.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/nvdisk-sram.c b/cpukit/libblock/src/nvdisk-sram.c
index ec99985090..677edbcedd 100644
--- a/cpukit/libblock/src/nvdisk-sram.c
+++ b/cpukit/libblock/src/nvdisk-sram.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright 2007 Chris Johns (chrisj at rtems.org)
+ * are met:
diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
index a7f4167d33..ae44f97479 100644
--- a/cpukit/libblock/src/nvdisk.c
+++ b/cpukit/libblock/src/nvdisk.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libblock/src/ramdisk-init.c b/cpukit/libblock/src/ramdisk-init.c
index ad71c51b70..93b40a2154 100644
--- a/cpukit/libblock/src/ramdisk-init.c
+++ b/cpukit/libblock/src/ramdisk-init.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/ramdisk-register.c b/cpukit/libblock/src/ramdisk-register.c
index 9005cf32a0..ef02f4b61d 100644
--- a/cpukit/libblock/src/ramdisk-register.c
+++ b/cpukit/libblock/src/ramdisk-register.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/libblock/src/show_bdbuf.c b/cpukit/libblock/src/show_bdbuf.c
index 7b1750ebd9..3bc5eafe52 100644
--- a/cpukit/libblock/src/show_bdbuf.c
+++ b/cpukit/libblock/src/show_bdbuf.c
@@ -1,3 +1,5 @@
  * @file
@@ -21,9 +23,26 @@
  * Germany
  * rtems at embedded-brains.de
+ * are met:
diff --git a/cpukit/libblock/src/sparse-disk.c b/cpukit/libblock/src/sparse-disk.c
index 550c8349d2..ea0b3b51fa 100644
--- a/cpukit/libblock/src/sparse-disk.c
+++ b/cpukit/libblock/src/sparse-disk.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Germany
+ * are met:
