[PATCH 1/2] microblaze: Add support for libbsd.
Joel Sherrill
joel at rtems.org
Wed Jan 5 00:17:13 UTC 2022
On Tue, Jan 4, 2022, 4:34 PM Chris Johns <chrisj at rtems.org> wrote:
> On 5/1/22 5:10 am, Alex White wrote:
> > From: Jennifer Averett <jennifer.averett at oarcorp.com>
> > .../microblaze_fpga/dts/microblaze-dtb.c | 962 ++++++++++++++++++
> > .../microblaze/microblaze_fpga/dts/system.dts | 452 ++++++++
> > bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c | 21 +
> > bsps/microblaze/microblaze_fpga/include/bsp.h | 4 +
> > .../bsps/microblaze/microblaze_fpga/obj.yml | 2 +
> > 5 files changed, 1441 insertions(+)
> > create mode 100644 bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
> > create mode 100644 bsps/microblaze/microblaze_fpga/dts/system.dts
> > create mode 100644 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
> How does a user with an FPGA microblaze implementation provide there own
> FDT? I
> see the clock speed is a setting.
> Is there a means to add such support available?
> I am OK with a specific implementation keyed into a specific BSP being in
> our
> source but that must be limited to a specific piece of hardware and FPGA
> is too
> general given this is a soft processor. I think there needs to a workflow
> that
> allows users to customize these settings for their own build.
I agree but this should match the kcu105 default Xilinx configuration.
Perhaps the name of the file could be changed to reflect that.
There should be a way to override this although the first Microblaze user
doesn't do that.
Should we be documenting what parameters a bsp reads from a device tree?
> Chris
> devel mailing list
> devel at rtems.org
