[PATCH 2/2] microblaze: Add support for libbsd networking
Alex White alex.white at oarcorp.com
Tue Jan 4 18:10:56 UTC 2022
This includes fixes and improvements necessary to get libbsd networking
running.
 .../microblaze_fpga/dts/microblaze-dtb.c      |  7 +++--
 .../microblaze/microblaze_fpga/dts/system.dts |  4 +--
 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c |  1 +
 bsps/microblaze/microblaze_fpga/include/bsp.h |  5 ++++
 bsps/microblaze/microblaze_fpga/irq/irq.c     |  2 +-
 .../microblaze_fpga/start/bspstart.c          |  6 ++++
 .../start/microblaze_enable_dcache.S          | 20 +++++++++++++
 .../start/microblaze_enable_icache.S          | 20 +++++++++++++
 .../start/microblaze_invalidate_dcache.S      | 29 +++++++++++++++++++
 .../start/microblaze_invalidate_icache.S      | 28 ++++++++++++++++++
 cpukit/score/cpu/microblaze/cpu.c             |  1 -
 cpukit/score/cpu/microblaze/cpu_asm.S         |  4 +--
 .../bsps/microblaze/microblaze_fpga/grp.yml   | 12 ++++++++
 .../bsps/microblaze/microblaze_fpga/obj.yml   |  4 +++
 .../microblaze_fpga/optdcachebaseaddress.yml  | 18 ++++++++++++
 .../microblaze_fpga/optdcachelinelen.yml      | 17 +++++++++++
 .../microblaze_fpga/optdcachesize.yml         | 17 +++++++++++
 .../microblaze_fpga/opticachebaseaddress.yml  | 18 ++++++++++++
 .../microblaze_fpga/opticachelinelen.yml      | 17 +++++++++++
 .../microblaze_fpga/opticachesize.yml         | 17 +++++++++++
 20 files changed, 237 insertions(+), 10 deletions(-)
 create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
 create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
 create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
 create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml
diff --git a/bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c b/bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
index ad72fac0b8..2615089012 100644
--- a/bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
+++ b/bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
@@ -4,9 +4,10 @@
  *  WARNING: Automatically generated -- do not edit!
+#include <rtems/score/basedefs.h>
 #include <sys/types.h>
-const unsigned char system_dtb[] = {
+const unsigned char system_dtb[] RTEMS_ALIGNED(8) = {
   0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x2c, 0x85, 0x00, 0x00, 0x00, 0x38,
   0x00, 0x00, 0x1c, 0xa0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
   0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe5,
@@ -307,7 +308,7 @@ const unsigned char system_dtb[] = {
   0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
   0x00, 0x00, 0x0c, 0xcc, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
-  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x0c, 0xd1, 0x72, 0x78, 0x00, 0x74,
+  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x0c, 0xd1, 0x74, 0x78, 0x00, 0x72,
   0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
   0x00, 0x00, 0x0c, 0xdb, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x01,
   0x6d, 0x64, 0x69, 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
@@ -317,7 +318,7 @@ const unsigned char system_dtb[] = {
   0x31, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0d,
   0x00, 0x00, 0x00, 0x95, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
   0x2d, 0x70, 0x68, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
-  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xf3, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xf3, 0x00, 0x00, 0x00, 0x07,
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x0a, 0x62,
   0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x64, 0x6d, 0x61, 0x40,
diff --git a/bsps/microblaze/microblaze_fpga/dts/system.dts b/bsps/microblaze/microblaze_fpga/dts/system.dts
index 587d569f03..9972e753d2 100644
--- a/bsps/microblaze/microblaze_fpga/dts/system.dts
+++ b/bsps/microblaze/microblaze_fpga/dts/system.dts
@@ -222,7 +222,7 @@
 			phandle = <0x6>;
 			dmas = <&dma 0
 				&dma 1>;
-			dma-names = "rx", "tx";
+			dma-names = "tx", "rx";
 			memory-region = <&dma_reserved>;
 			mdio {
 				#address-cells = <0x1>;
@@ -230,7 +230,7 @@
 				phy at 1 {
 					device_type = "ethernet-phy";
-					reg = <0x1>;
+					reg = <0x7>;
 					phandle = <0x5>;
diff --git a/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c b/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
index e92f9e466e..e2f5419513 100644
--- a/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
+++ b/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
@@ -8,6 +8,7 @@
 #include <bsp.h>
+#include <bsp/fdt.h>
 const void *bsp_fdt_get(void)
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp.h b/bsps/microblaze/microblaze_fpga/include/bsp.h
index 49918c3353..93cf0e4b34 100644
--- a/bsps/microblaze/microblaze_fpga/include/bsp.h
+++ b/bsps/microblaze/microblaze_fpga/include/bsp.h
@@ -50,6 +50,11 @@ extern "C" {
 extern const unsigned char system_dtb[];
 extern const size_t system_dtb_size;
+void microblaze_enable_icache(void);
+void microblaze_enable_dcache(void);
+void microblaze_invalidate_icache(void);
+void microblaze_invalidate_dcache(void);
 #ifdef __cplusplus
 #endif
diff --git a/bsps/microblaze/microblaze_fpga/irq/irq.c b/bsps/microblaze/microblaze_fpga/irq/irq.c
index 67ddf02079..7148aed8cd 100644
--- a/bsps/microblaze/microblaze_fpga/irq/irq.c
+++ b/bsps/microblaze/microblaze_fpga/irq/irq.c
@@ -141,7 +141,7 @@ void bsp_interrupt_dispatch( uint32_t source )
   if ( source == 0xFF ) {
     /* Read interrupt controller to get the source */
-    vector_number = intc->isr;
+    vector_number = intc->isr & intc->ier;
     /* Handle and the first interrupt that is set */
     uint8_t interrupt_status = 0;
diff --git a/bsps/microblaze/microblaze_fpga/start/bspstart.c b/bsps/microblaze/microblaze_fpga/start/bspstart.c
index 0caf385b46..84524d9365 100644
--- a/bsps/microblaze/microblaze_fpga/start/bspstart.c
+++ b/bsps/microblaze/microblaze_fpga/start/bspstart.c
@@ -39,5 +39,11 @@
 void bsp_start( void )
+  microblaze_invalidate_icache();
+  microblaze_enable_icache();
+  microblaze_invalidate_dcache();
+  microblaze_enable_dcache();
   bsp_interrupt_initialize();
diff --git a/bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S b/bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
new file mode 100644
index 0000000000..78babf0176
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
@@ -0,0 +1,20 @@
+* Copyright (c) 2004 - 2020 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+	.text
+	.globl	microblaze_enable_dcache
+	.ent	microblaze_enable_dcache
+	.align	2
+microblaze_enable_dcache:
+    /* Read the MSR register */
+	mfs	r8, rmsr
+	/* Set the interrupt enable bit */
+	ori	r8, r8, 0x80
+	/* Save the MSR register */
+	mts	rmsr, r8
+	/* Return */
+	rtsd	r15, 8
+	nop
+    .end	microblaze_enable_dcache
diff --git a/bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S b/bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
index 0000000000..7de51ac230
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
@@ -0,0 +1,20 @@
+	.text
+	.globl	microblaze_enable_icache
+	.ent	microblaze_enable_icache
+	.align	2
+microblaze_enable_icache:
+	mfs	r8, rmsr
+	ori	r8, r8, 0x20
+	mts	rmsr, r8
+	/* Return */
+	rtsd	r15, 8
+	nop
+	.end	microblaze_enable_icache
diff --git a/bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S b/bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
index 0000000000..d5bf91e626
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
@@ -0,0 +1,29 @@
+* Copyright (c) 2008 - 2020 Xilinx, Inc.  All rights reserved.
+#include <bspopts.h>
+	.text
+	.globl	microblaze_invalidate_dcache
+	.ent	microblaze_invalidate_dcache
+	.align	2
+microblaze_invalidate_dcache:
+	addik 	r5, r0, BSP_MICROBLAZE_FPGA_DCACHE_BASE & (-(4 * BSP_MICROBLAZE_FPGA_DCACHE_LINE_LEN))
+	addik	r6, r5, BSP_MICROBLAZE_FPGA_DCACHE_SIZE &  (-(4 * BSP_MICROBLAZE_FPGA_DCACHE_LINE_LEN))
+L_start:
+	wdc	r5, r0                                          /* Invalidate the Cache */
+	cmpu	r18, r5, r6                                     /* Are we at the end? */
+	blei	r18, L_done
+	brid	L_start                                         /* Branch to the beginning of the loop */
+	addik	r5, r5, (BSP_MICROBLAZE_FPGA_DCACHE_LINE_LEN * 4)   /* Increment the address by 4 (delay slot) */
+L_done:
+	rtsd	r15, 8                                          /* Return */
+	nop
+	.end	microblaze_invalidate_dcache
diff --git a/bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S b/bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
index 0000000000..d75a800560
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
@@ -0,0 +1,28 @@
+	.text
+	.globl	microblaze_invalidate_icache
+	.ent	microblaze_invalidate_icache
+	.align	2
+microblaze_invalidate_icache:
+    addik 	r5, r0, BSP_MICROBLAZE_FPGA_ICACHE_BASE & (-(4 * BSP_MICROBLAZE_FPGA_ICACHE_LINE_LEN))  /* Align to cache line */
+	addik	r6, r5, BSP_MICROBLAZE_FPGA_ICACHE_SIZE & (-(4 * BSP_MICROBLAZE_FPGA_ICACHE_LINE_LEN))  /* Compute end */
+L_start:
+	wic	r5, r0                                          /* Invalidate the Cache */
+	blei	r18, L_done
+	addik	r5, r5, (BSP_MICROBLAZE_FPGA_ICACHE_LINE_LEN * 4)   /* Increment the address by 4 (delay slot) */
+L_done:
+    nop
+	.end	microblaze_invalidate_icache
\ No newline at end of file
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index de8fbfbba1..38fb291906 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -116,6 +116,5 @@ void _CPU_ISR_install_vector(
 void *_CPU_Thread_Idle_body( uintptr_t ignored )
   while ( true ) {
-    __asm__ volatile ( "sleep" );
diff --git a/cpukit/score/cpu/microblaze/cpu_asm.S b/cpukit/score/cpu/microblaze/cpu_asm.S
index d095e62f69..45a81606ee 100644
--- a/cpukit/score/cpu/microblaze/cpu_asm.S
+++ b/cpukit/score/cpu/microblaze/cpu_asm.S
@@ -116,9 +116,7 @@ after_stack_switch:
 	beqi r3, quick_exit
 	/* Return to interrupted thread and make it do a dispatch */
-	addik r14, r0, thread_dispatch
-	rtid r14, 0
-	nop
+	bri thread_dispatch
 quick_exit:
 	/* Simple return from nested interrupt */
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index 991ab04a23..4ef0f84943 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -17,6 +17,18 @@ links:
   uid: start
 - role: build-dependency
   uid: optconsoleinterrupts
+- role: build-dependency
+  uid: optdcachebaseaddress
+  uid: optdcachelinelen
+  uid: optdcachesize
+  uid: opticachebaseaddress
+  uid: opticachelinelen
+  uid: opticachesize
   uid: optintcbaseaddress
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 889a8de5a3..d8c3743a94 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -32,6 +32,10 @@ source:
 - bsps/microblaze/microblaze_fpga/start/bspreset.c
 - bsps/microblaze/microblaze_fpga/start/bspstart.c
 - bsps/microblaze/microblaze_fpga/start/crtinit.S
+- bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
+- bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
+- bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
+- bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
 - bsps/microblaze/shared/dev/serial/uartlite.c
 - bsps/microblaze/shared/dev/serial/uartlite_l.c
 - bsps/shared/cache/nocache.c
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml
index 0000000000..d9f48db96c
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+default: 0x80000000
+default-by-variant: []
+description: |
+  base address of the data cache
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_DCACHE_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml b/spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml
index 0000000000..2a9af43baa
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 4
+description: |
+  length of the data cache line
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_DCACHE_LINE_LEN
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml b/spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml
index 0000000000..71a39a0f10
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 32768
+description: |
+  size of the data cache in bytes
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_DCACHE_SIZE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml b/spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml
index 0000000000..9cb71fc2b8
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+description: |
+  base address of the instruction cache
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_ICACHE_BASE
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml b/spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml
index 0000000000..0c0a55011f
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 8
+description: |
+  length of the instruction cache line
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_ICACHE_LINE_LEN
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml b/spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml
index 0000000000..2b5f083dea
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml
@@ -0,0 +1,17 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default: 32768
+description: |
+  size of the instruction cache in bytes
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_ICACHE_SIZE
+type: build
2.27.0
