[PATCH 0/2] microblaze: libbsd support
Joel Sherrill
joel at rtems.org
Wed Jan 5 00:18:35 UTC 2022
On Tue, Jan 4, 2022, 4:29 PM Chris Johns <chrisj at rtems.org> wrote:
> Which repo is this for?
Looks like RTEMS.git to me and per the comment fixes issues found when
debugging libbsd support.
> On 5/1/22 5:10 am, Alex White wrote:
> > This patch set adds support for libbsd to the MicroBlaze BSPs and
> contains fixes
> > for issues found while debugging the rtems-libbsd telnetd01 test in QEMU
> and on
> > the Xilinx KCU105 board.
> > Alex White (1):
> > microblaze: Add support for libbsd networking
> > Jennifer Averett (1):
> > microblaze: Add support for libbsd.
> > .../microblaze_fpga/dts/microblaze-dtb.c | 963 ++++++++++++++++++
> > .../microblaze/microblaze_fpga/dts/system.dts | 452 ++++++++
> > bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c | 22 +
> > bsps/microblaze/microblaze_fpga/include/bsp.h | 9 +
> > bsps/microblaze/microblaze_fpga/irq/irq.c | 2 +-
> > .../microblaze_fpga/start/bspstart.c | 6 +
> > .../start/microblaze_enable_dcache.S | 20 +
> > .../start/microblaze_enable_icache.S | 20 +
> > .../start/microblaze_invalidate_dcache.S | 29 +
> > .../start/microblaze_invalidate_icache.S | 28 +
> > cpukit/score/cpu/microblaze/cpu.c | 1 -
> > cpukit/score/cpu/microblaze/cpu_asm.S | 4 +-
> > .../bsps/microblaze/microblaze_fpga/grp.yml | 12 +
> > .../bsps/microblaze/microblaze_fpga/obj.yml | 6 +
> > .../microblaze_fpga/optdcachebaseaddress.yml | 18 +
> > .../microblaze_fpga/optdcachelinelen.yml | 17 +
> > .../microblaze_fpga/optdcachesize.yml | 17 +
> > .../microblaze_fpga/opticachebaseaddress.yml | 18 +
> > .../microblaze_fpga/opticachelinelen.yml | 17 +
> > .../microblaze_fpga/opticachesize.yml | 17 +
> > 20 files changed, 1673 insertions(+), 5 deletions(-)
> > create mode 100644 bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
> > create mode 100644 bsps/microblaze/microblaze_fpga/dts/system.dts
> > create mode 100644 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
> > create mode 100644
> bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
> > create mode 100644
> bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
> > create mode 100644
> bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
> > create mode 100644
> bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
> > create mode 100644
> spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml
> > create mode 100644
> spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml
> > create mode 100644
> spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml
> > create mode 100644
> spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml
> > create mode 100644
> spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml
> > create mode 100644
> spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml
> devel mailing list
> devel at rtems.org
