[PATCH 0/2] microblaze: libbsd support
Tue Jan 4 22:28:53 UTC 2022
Which repo is this for?
On 5/1/22 5:10 am, Alex White wrote:
> This patch set adds support for libbsd to the MicroBlaze BSPs and contains fixes
> for issues found while debugging the rtems-libbsd telnetd01 test in QEMU and on
> the Xilinx KCU105 board.
> Alex White (1):
>   microblaze: Add support for libbsd networking
> Jennifer Averett (1):
>   microblaze: Add support for libbsd.
>  .../microblaze_fpga/dts/microblaze-dtb.c      | 963 ++++++++++++++++++
>  .../microblaze/microblaze_fpga/dts/system.dts | 452 ++++++++
>  bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c |  22 +
>  bsps/microblaze/microblaze_fpga/include/bsp.h |   9 +
>  bsps/microblaze/microblaze_fpga/irq/irq.c     |   2 +-
>  .../microblaze_fpga/start/bspstart.c          |   6 +
>  .../start/microblaze_enable_dcache.S          |  20 +
>  .../start/microblaze_enable_icache.S          |  20 +
>  .../start/microblaze_invalidate_dcache.S      |  29 +
>  .../start/microblaze_invalidate_icache.S      |  28 +
>  cpukit/score/cpu/microblaze/cpu.c             |   1 -
>  cpukit/score/cpu/microblaze/cpu_asm.S         |   4 +-
>  .../bsps/microblaze/microblaze_fpga/grp.yml   |  12 +
>  .../bsps/microblaze/microblaze_fpga/obj.yml   |   6 +
>  .../microblaze_fpga/optdcachebaseaddress.yml  |  18 +
>  .../microblaze_fpga/optdcachelinelen.yml      |  17 +
>  .../microblaze_fpga/optdcachesize.yml         |  17 +
>  .../microblaze_fpga/opticachebaseaddress.yml  |  18 +
>  .../microblaze_fpga/opticachelinelen.yml      |  17 +
>  .../microblaze_fpga/opticachesize.yml         |  17 +
>  20 files changed, 1673 insertions(+), 5 deletions(-)
>  create mode 100644 bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
>  create mode 100644 bsps/microblaze/microblaze_fpga/dts/system.dts
>  create mode 100644 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
>  create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
>  create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
>  create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
>  create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
>  create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml
>  create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml
>  create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml
>  create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml
>  create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml
>  create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml
