[PATCH 1/3] bsps/aarch64: refactor register init and hooks
Thu Jan 6 22:13:50 UTC 2022
 bsps/aarch64/shared/start/start.S             | 81 ++++++++++---------
 .../xilinx-zynqmp/start/bspstarthooks.c       | 12 +--
 2 files changed, 48 insertions(+), 45 deletions(-)
diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
index f03c7921ca..d5c7bdc3d5 100644
--- a/bsps/aarch64/shared/start/start.S
+++ b/bsps/aarch64/shared/start/start.S
@@ -55,6 +55,11 @@ _start:
   mov x5, x1    /* machine type number or ~0 for DT boot */
   mov x6, x2    /* physical address of ATAGs or DTB */
 #else /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
+   * This block is dead code. No aarch64 targets require this. It might be
+   * needed for hardware simulations or in future processor variants with
+   * lock-step cores.
   mov x0, XZR
   mov x1, XZR
   mov x2, XZR
@@ -87,8 +92,42 @@ _start:
   mov x29, XZR
   mov x30, XZR
 #ifdef AARCH64_MULTILIB_VFP
-#endif
-#endif
+  mov CPTR_EL3, XZR
+  mov CPTR_EL2, XZR
+  mov d0, XZR
+  mov d1, XZR
+  mov d2, XZR
+  mov d3, XZR
+  mov d4, XZR
+  mov d5, XZR
+  mov d6, XZR
+  mov d7, XZR
+  mov d8, XZR
+  mov d9, XZR
+  mov d10, XZR
+  mov d11, XZR
+  mov d12, XZR
+  mov d13, XZR
+  mov d14, XZR
+  mov d15, XZR
+  mov d16, XZR
+  mov d17, XZR
+  mov d18, XZR
+  mov d19, XZR
+  mov d20, XZR
+  mov d21, XZR
+  mov d22, XZR
+  mov d23, XZR
+  mov d24, XZR
+  mov d25, XZR
+  mov d26, XZR
+  mov d27, XZR
+  mov d28, XZR
+  mov d29, XZR
+  mov d30, XZR
+  mov d31, XZR
+#endif /* AARCH64_MULTILIB_VFP */
+#endif /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
   /* Initialize SCTLR_EL1 */
   mov x0, XZR
@@ -252,44 +291,6 @@ _el1_start:
   /* FPU does not need to be enabled on AArch64 */
-#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
-  mov x0, #0
-  mov CPTR_EL3, XZR
-  mov CPTR_EL2, XZR
-  mov d0, XZR
-  mov d1, XZR
-  mov d2, XZR
-  mov d3, XZR
-  mov d4, XZR
-  mov d5, XZR
-  mov d6, XZR
-  mov d7, XZR
-  mov d8, XZR
-  mov d9, XZR
-  mov d10, XZR
-  mov d11, XZR
-  mov d12, XZR
-  mov d13, XZR
-  mov d14, XZR
-  mov d15, XZR
-  mov d16, XZR
-  mov d17, XZR
-  mov d18, XZR
-  mov d19, XZR
-  mov d20, XZR
-  mov d21, XZR
-  mov d22, XZR
-  mov d23, XZR
-  mov d24, XZR
-  mov d25, XZR
-  mov d26, XZR
-  mov d27, XZR
-  mov d28, XZR
-  mov d29, XZR
-  mov d30, XZR
-  mov d31, XZR
-#endif /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
index ad688088e5..14f2bcc280 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
@@ -46,6 +46,11 @@
 #endif
 BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
+  /* do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
 #ifdef RTEMS_SMP
   uint32_t cpu_index_self;
@@ -72,13 +77,10 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
     _SMP_Start_multitasking_on_secondary_processor(
       _Per_CPU_Get_by_index( cpu_index_self )
+    /* Unreached */
+#endif /* RTEMS_SMP */
-#endif
-BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
   AArch64_start_set_vector_base();
   bsp_start_copy_sections();
   zynqmp_setup_mmu_and_cache();
2.25.1
