Older gcc for MacOS
Ryan Long ral051 at oarcorp.com
Fri Jan 7 21:28:13 UTC 2022
Hi,
Our MacOS VM is failing to build several of the tools on the RTEMS 5
branch. We think that using an older version of gcc should get all of
the tools to build. I tried build gcc-4.8 with the RSB, but I get the
following error.
tester at VM-MacOS bare % ../source-builder/sb-set-builder
--prefix=${HOME}/rtems-cron-5/tools/gcc-48 gnu-tools-4.8.2
RTEMS Source Builder - Set Builder, 5 (6225eadda1de modified)
Build Set: gnu-tools-4.8.2
error: gnu-tools-4.8.2:24: cannot find file: devel/gcc-4.8.2-newlib-cvs-1
Build Set: Time 0:00:00.000607
Build FAILED
Does anyone know how to get these tools to build?
Thanks,
Ryan
