[PATCH rtems-tools] tiers: Add AArch64 to tier 1
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jan 19 14:42:59 UTC 2022
On 1/18/2022 10:23, Sebastian Huber wrote:
> On 18/01/2022 17:19, Kinsey Moore wrote:
>> Hardware test results have recently been posted for AArch64.
>> Closes #4581
> It would be nice if you could run also the new validation tests on
> this branch:
> https://git.rtems.org/sebh/rtems.git/log/?h=validation
It looks like when running with that branch, tar02 and psxftw01 are
consistently failing with a PC in the stack since sometime after
68b0db358c81a7f770a44ceb819197bdc320bc99 which is what the other test
run used. I'll have to track that down.
ts-performance-no-clock-0 gets test-too-long, but passes with modified
tester timeouts and all the other validation tests pass just fine.
Kinsey
