[PATCH rtems-tools] tiers: Add AArch64 to tier 1
Wed Jan 19 15:13:55 UTC 2022
On 19/01/2022 15:42, Kinsey Moore wrote:
> On 1/18/2022 10:23, Sebastian Huber wrote:
>> On 18/01/2022 17:19, Kinsey Moore wrote:
>>> Hardware test results have recently been posted for AArch64.
>>> Closes #4581
>> It would be nice if you could run also the new validation tests on
>> this branch:
>> https://git.rtems.org/sebh/rtems.git/log/?h=validation
> It looks like when running with that branch, tar02 and psxftw01 are
> consistently failing with a PC in the stack since sometime after
> 68b0db358c81a7f770a44ceb819197bdc320bc99 which is what the other test
> run used. I'll have to track that down.
Thanks for testing. It would be good to do a git bisect to figure out
the problem.
> ts-performance-no-clock-0 gets test-too-long, but passes with modified
> tester timeouts and all the other validation tests pass just fine.
Great, did the ts-validation-intr test run also? It fails on my Qemu
simulator.
I think the issue with ts-performance-no-clock-0 is the size of the data
cache. However, the data cache is an important factor for the
performance data, so there is no way around this.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
