[PATCH rtems-tools] tiers: Add AArch64 to tier 1
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jan 19 17:49:35 UTC 2022
On 1/19/2022 09:41, Kinsey Moore wrote:
> On 1/19/2022 09:13, Sebastian Huber wrote:
>> On 19/01/2022 15:42, Kinsey Moore wrote:
>>> On 1/18/2022 10:23, Sebastian Huber wrote:
>>>> On 18/01/2022 17:19, Kinsey Moore wrote:
>>>>> Hardware test results have recently been posted for AArch64.
>>>>> Closes #4581
>>>> It would be nice if you could run also the new validation tests on
>>>> this branch:
>>>> https://git.rtems.org/sebh/rtems.git/log/?h=validation
>>> It looks like when running with that branch, tar02 and psxftw01 are
>>> consistently failing with a PC in the stack since sometime after
>>> 68b0db358c81a7f770a44ceb819197bdc320bc99 which is what the other
>>> test run used. I'll have to track that down.
>> Thanks for testing. It would be good to do a git bisect to figure out
>> the problem.
> I'm currently doing that now and should have it narrowed down soon.
It looks like this was actually just a bad partial build and a full
rebuild resolved the two failures.
Kinsey
