[PATCH rtems-tools] tiers: Add AArch64 to tier 1
Joel Sherrill
joel at rtems.org
Wed Jan 19 18:08:00 UTC 2022
Are the Tier 1 architectures/BSPs documented anywhere besides an INI file?
--joel
On Wed, Jan 19, 2022 at 11:49 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> On 1/19/2022 09:41, Kinsey Moore wrote:
> > On 1/19/2022 09:13, Sebastian Huber wrote:
> >> On 19/01/2022 15:42, Kinsey Moore wrote:
> >>> On 1/18/2022 10:23, Sebastian Huber wrote:
> >>>> On 18/01/2022 17:19, Kinsey Moore wrote:
> >>>>> Hardware test results have recently been posted for AArch64.
> >>>>> Closes #4581
> >>>> It would be nice if you could run also the new validation tests on
> >>>> this branch:
> >>>> https://git.rtems.org/sebh/rtems.git/log/?h=validation
> >>> It looks like when running with that branch, tar02 and psxftw01 are
> >>> consistently failing with a PC in the stack since sometime after
> >>> 68b0db358c81a7f770a44ceb819197bdc320bc99 which is what the other
> >>> test run used. I'll have to track that down.
> >> Thanks for testing. It would be good to do a git bisect to figure out
> >> the problem.
> > I'm currently doing that now and should have it narrowed down soon.
> It looks like this was actually just a bad partial build and a full
> rebuild resolved the two failures.
> Kinsey
> devel mailing list
> devel at rtems.org
