[PATCH 0/5] Update rtems-bsp-builder to match RTEMS master
Chris Johns
chrisj at rtems.org
Wed Jan 19 20:57:46 UTC 2022
Looks great and thank you for taking care of this.
On 20/1/22 5:04 am, Joel Sherrill wrote:
> The set of ini files for rtems-bsp-builder was out of sync
> with the set of architectures and BSPs currently in RTEMS.
> This patch set adds three architectures and a handful of BSPs.
> Build results with these patches are at:
> https://lists.rtems.org/pipermail/build/2022-January/031032.html
> --joel
> Joel Sherrill (5):
> rtems-bsps-arm.ini: Add missing BSPs
> rtems-bsps-riscv.ini: Add missing BSPs
> rtems-bsps-aarch64.ini: New file
> rtems-bsps-microblaze.ini: New file
> rtems-bsps-x86_64.ini: New file
> config/rtems-bsps-aarch64.ini | 31 +++++++++++++++++++++++++++++++
> config/rtems-bsps-arm.ini | 16 +++++++++++++---
> config/rtems-bsps-microblaze.ini | 25 +++++++++++++++++++++++++
> config/rtems-bsps-riscv.ini | 4 +++-
> config/rtems-bsps-x86_64.ini | 25 +++++++++++++++++++++++++
> 5 files changed, 97 insertions(+), 4 deletions(-)
> create mode 100644 config/rtems-bsps-aarch64.ini
> create mode 100644 config/rtems-bsps-microblaze.ini
> create mode 100644 config/rtems-bsps-x86_64.ini
