[PATCH rtems-libbsd 0/2] MicroBlaze AXI Ethernet Support
Alex White
alex.white at oarcorp.com
Thu Jan 20 03:54:11 UTC 2022
This patch set adds support for Xilinx's AXI Ethernet IP core. It has
been tested both in QEMU and on the KCU105 board using the default
FPGA implementation from the Xilinx's KCU105 PetaLinux BSP.
Alex White (1):
microblaze: Finish AXI Ethernet support
Jennifer Averett (1):
microblaze: Add AXI Ethernet support
buildset/default.ini | 1 +
freebsd/sys/dev/mii/tiphy.h | 57 +
freebsd/sys/dev/xdma/xdma.c | 501 ++++++++
freebsd/sys/dev/xdma/xdma.h | 285 +++++
freebsd/sys/dev/xdma/xdma_bank.c | 100 ++
freebsd/sys/dev/xdma/xdma_mbuf.c | 151 +++
freebsd/sys/dev/xdma/xdma_queue.c | 126 ++
freebsd/sys/dev/xdma/xdma_sg.c | 661 ++++++++++
freebsd/sys/dev/xdma/xdma_sglist.c | 103 ++
freebsd/sys/dev/xilinx/axidma.c | 676 ++++++++++
freebsd/sys/dev/xilinx/axidma.h | 96 ++
freebsd/sys/dev/xilinx/if_xae.c | 1111 +++++++++++++++++
freebsd/sys/dev/xilinx/if_xaereg.h | 122 ++
freebsd/sys/dev/xilinx/if_xaevar.h | 80 ++
.../sys/microblaze/include/machine/in_cksum.h | 82 ++
freebsd/sys/microblaze/microblaze/in_cksum.c | 255 ++++
freebsd/sys/netinet/tcp_input.c | 9 +
freebsd/sys/netinet/tcp_subr.c | 10 +
freebsd/sys/netinet6/ip6_input.c | 10 +
libbsd.py | 43 +
rtemsbsd/include/bsp/nexus-devices.h | 10 +-
rtemsbsd/include/rtems/bsd/local/xdma_if.h | 144 +++
rtemsbsd/local/xdma_if.c | 57 +
rtemsbsd/rtems/rtems-kernel-vmem.c | 17 +
.../rtems/bsd/test/network-config.h.in | 2 +
25 files changed, 4708 insertions(+), 1 deletion(-)
create mode 100644 freebsd/sys/dev/mii/tiphy.h
create mode 100644 freebsd/sys/dev/xdma/xdma.c
create mode 100644 freebsd/sys/dev/xdma/xdma.h
create mode 100644 freebsd/sys/dev/xdma/xdma_bank.c
create mode 100644 freebsd/sys/dev/xdma/xdma_mbuf.c
create mode 100644 freebsd/sys/dev/xdma/xdma_queue.c
create mode 100644 freebsd/sys/dev/xdma/xdma_sg.c
create mode 100644 freebsd/sys/dev/xdma/xdma_sglist.c
create mode 100644 freebsd/sys/dev/xilinx/axidma.c
create mode 100644 freebsd/sys/dev/xilinx/axidma.h
create mode 100644 freebsd/sys/dev/xilinx/if_xae.c
create mode 100644 freebsd/sys/dev/xilinx/if_xaereg.h
create mode 100644 freebsd/sys/dev/xilinx/if_xaevar.h
create mode 100644 freebsd/sys/microblaze/include/machine/in_cksum.h
create mode 100644 freebsd/sys/microblaze/microblaze/in_cksum.c
create mode 100644 rtemsbsd/include/rtems/bsd/local/xdma_if.h
create mode 100644 rtemsbsd/local/xdma_if.c
2.30.2
