[PATCH rtems-libbsd 1/2] microblaze: Add AXI Ethernet support
Alex White alex.white at oarcorp.com
Thu Jan 20 03:54:12 UTC 2022
From: Jennifer Averett <jennifer.averett at oarcorp.com>
 buildset/default.ini                          |    1 +
 freebsd/sys/dev/mii/tiphy.h                   |   57 +
 freebsd/sys/dev/xdma/xdma.c                   |  501 ++++++++
 freebsd/sys/dev/xdma/xdma.h                   |  285 +++++
 freebsd/sys/dev/xdma/xdma_bank.c              |  100 ++
 freebsd/sys/dev/xdma/xdma_mbuf.c              |  151 +++
 freebsd/sys/dev/xdma/xdma_queue.c             |  126 ++
 freebsd/sys/dev/xdma/xdma_sg.c                |  660 ++++++++++
 freebsd/sys/dev/xdma/xdma_sglist.c            |  103 ++
 freebsd/sys/dev/xilinx/axidma.c               |  666 ++++++++++
 freebsd/sys/dev/xilinx/axidma.h               |   96 ++
 freebsd/sys/dev/xilinx/if_xae.c               | 1111 +++++++++++++++++
 freebsd/sys/dev/xilinx/if_xaereg.h            |  122 ++
 freebsd/sys/dev/xilinx/if_xaevar.h            |   80 ++
 .../sys/microblaze/include/machine/in_cksum.h |   82 ++
 freebsd/sys/microblaze/microblaze/in_cksum.c  |  255 ++++
 libbsd.py                                     |   43 +
 rtemsbsd/include/bsp/nexus-devices.h          |   10 +-
 rtemsbsd/include/rtems/bsd/local/xdma_if.h    |  144 +++
 rtemsbsd/local/xdma_if.c                      |   57 +
 rtemsbsd/rtems/rtems-kernel-vmem.c            |   17 +
 21 files changed, 4666 insertions(+), 1 deletion(-)
 create mode 100644 freebsd/sys/dev/mii/tiphy.h
 create mode 100644 freebsd/sys/dev/xdma/xdma.c
 create mode 100644 freebsd/sys/dev/xdma/xdma.h
 create mode 100644 freebsd/sys/dev/xdma/xdma_bank.c
 create mode 100644 freebsd/sys/dev/xdma/xdma_mbuf.c
 create mode 100644 freebsd/sys/dev/xdma/xdma_queue.c
 create mode 100644 freebsd/sys/dev/xdma/xdma_sg.c
 create mode 100644 freebsd/sys/dev/xdma/xdma_sglist.c
 create mode 100644 freebsd/sys/dev/xilinx/axidma.c
 create mode 100644 freebsd/sys/dev/xilinx/axidma.h
 create mode 100644 freebsd/sys/dev/xilinx/if_xae.c
 create mode 100644 freebsd/sys/dev/xilinx/if_xaereg.h
 create mode 100644 freebsd/sys/dev/xilinx/if_xaevar.h
 create mode 100644 freebsd/sys/microblaze/include/machine/in_cksum.h
 create mode 100644 freebsd/sys/microblaze/microblaze/in_cksum.c
 create mode 100644 rtemsbsd/include/rtems/bsd/local/xdma_if.h
 create mode 100644 rtemsbsd/local/xdma_if.c
diff --git a/buildset/default.ini b/buildset/default.ini
index 454cc74e..1113c26f 100644
--- a/buildset/default.ini
+++ b/buildset/default.ini
@@ -23,6 +23,7 @@ dev_nic = on
 dev_nic_broadcomm = on
 dev_nic_dc = on
 dev_nic_e1000 = on
+dev_nic_xilinx = on
 dev_nic_fxp = on
 dev_nic_re = on
 dev_nic_smc = on
diff --git a/freebsd/sys/dev/mii/tiphy.h b/freebsd/sys/dev/mii/tiphy.h
new file mode 100644
index 00000000..d3c35575
--- /dev/null
+++ b/freebsd/sys/dev/mii/tiphy.h
@@ -0,0 +1,57 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (c) 2019 Ruslan Bukin <br at bsdpad.com>
+ * This software was developed by SRI International and the University of
+ * Cambridge Computer Laboratory (Department of Computer Science and
+ * Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of the
+ * DARPA SSITH research programme.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+ * Texas Instruments DP83867IR/CR Robust, High Immunity
+ * 10/100/1000 Ethernet Physical Layer Transceiver.
+#ifndef _DEV_MII_TIPHY_H_
+#define _DEV_MII_TIPHY_H_
+#define	DP83867_PHYCR			0x10	/* PHY Control Register */
+#define	 PHYCR_SGMII_EN			(1 << 11)
+#define	DP83867_CFG2			0x14	/* Configuration Register 2 */
+#define	 CFG2_SPEED_OPT_10M_EN		(1 << 6) /* Speed Optimization */
+#define	 CFG2_SPEED_OPT_ENHANCED_EN	(1 << 8)
+#define	 CFG2_SPEED_OPT_ATTEMPT_CNT_S	10
+#define	 CFG2_SPEED_OPT_ATTEMPT_CNT_M	(0x3 << CFG2_SPEED_OPT_ATTEMPT_CNT_S)
+#define	 CFG2_SPEED_OPT_ATTEMPT_CNT_1	(0 << CFG2_SPEED_OPT_ATTEMPT_CNT_S)
+#define	 CFG2_SPEED_OPT_ATTEMPT_CNT_2	(1 << CFG2_SPEED_OPT_ATTEMPT_CNT_S)
+#define	 CFG2_SPEED_OPT_ATTEMPT_CNT_4	(2 << CFG2_SPEED_OPT_ATTEMPT_CNT_S)
+#define	 CFG2_SPEED_OPT_ATTEMPT_CNT_8	(3 << CFG2_SPEED_OPT_ATTEMPT_CNT_S)
+#define	 CFG2_INTERRUPT_POLARITY	(1 << 13) /* Int pin is active low. */
+#define	DP83867_CFG4			0x31 /* Configuration Register 4 */
+#endif /* !_DEV_MII_TIPHY_H_ */
diff --git a/freebsd/sys/dev/xdma/xdma.c b/freebsd/sys/dev/xdma/xdma.c
index 00000000..1cc9b10c
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma.c
@@ -0,0 +1,501 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2016-2019 Ruslan Bukin <br at bsdpad.com>
+ * Cambridge Computer Laboratory under DARPA/AFRL contract FA8750-10-C-0237
+ * ("CTSRD"), as part of the DARPA CRASH research programme.
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/local/opt_platform.h>
+#include <sys/param.h>
+#include <sys/conf.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/queue.h>
+#include <sys/kobj.h>
+#include <sys/malloc.h>
+#include <sys/limits.h>
+#include <sys/lock.h>
+#include <sys/sysctl.h>
+#include <sys/systm.h>
+#include <machine/bus.h>
+#ifdef FDT
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#endif
+#ifdef __rtems__
+#define IN_XDMA_C
+#endif
+#include <dev/xdma/xdma.h>
+#include <rtems/bsd/local/xdma_if.h>
+ * Multiple xDMA controllers may work with single DMA device,
+ * so we have global lock for physical channel management.
+static struct mtx xdma_mtx;
+#define	XDMA_LOCK()			mtx_lock(&xdma_mtx)
+#define	XDMA_UNLOCK()			mtx_unlock(&xdma_mtx)
+#define	XDMA_ASSERT_LOCKED()		mtx_assert(&xdma_mtx, MA_OWNED)
+#define	FDT_REG_CELLS	4
+ * Allocate virtual xDMA channel.
+xdma_channel_t *
+xdma_channel_alloc(xdma_controller_t *xdma, uint32_t caps)
+	xdma_channel_t *xchan;
+	int ret;
+	xchan = malloc(sizeof(xdma_channel_t), M_XDMA, M_WAITOK | M_ZERO);
+	xchan->xdma = xdma;
+	xchan->caps = caps;
+	XDMA_LOCK();
+	/* Request a real channel from hardware driver. */
+	ret = XDMA_CHANNEL_ALLOC(xdma->dma_dev, xchan);
+	if (ret != 0) {
+		device_printf(xdma->dev,
+		    "%s: Can't request hardware channel.\n", __func__);
+		XDMA_UNLOCK();
+		free(xchan, M_XDMA);
+		return (NULL);
+	TAILQ_INIT(&xchan->ie_handlers);
+	mtx_init(&xchan->mtx_lock, "xDMA chan", NULL, MTX_DEF);
+	mtx_init(&xchan->mtx_qin_lock, "xDMA qin", NULL, MTX_DEF);
+	mtx_init(&xchan->mtx_qout_lock, "xDMA qout", NULL, MTX_DEF);
+	mtx_init(&xchan->mtx_bank_lock, "xDMA bank", NULL, MTX_DEF);
+	mtx_init(&xchan->mtx_proc_lock, "xDMA proc", NULL, MTX_DEF);
+	TAILQ_INIT(&xchan->bank);
+	TAILQ_INIT(&xchan->queue_in);
+	TAILQ_INIT(&xchan->queue_out);
+	TAILQ_INIT(&xchan->processing);
+	TAILQ_INSERT_TAIL(&xdma->channels, xchan, xchan_next);
+	XDMA_UNLOCK();
+	return (xchan);
+int
+xdma_channel_free(xdma_channel_t *xchan)
+	xdma_controller_t *xdma;
+	int err;
+	xdma = xchan->xdma;
+	KASSERT(xdma != NULL, ("xdma is NULL"));
+	XDMA_LOCK();
+	/* Free the real DMA channel. */
+	err = XDMA_CHANNEL_FREE(xdma->dma_dev, xchan);
+	if (err != 0) {
+		    "%s: Can't free real hw channel.\n", __func__);
+		XDMA_UNLOCK();
+		return (-1);
+	if (xchan->flags & XCHAN_TYPE_SG)
+		xdma_channel_free_sg(xchan);
+	xdma_teardown_all_intr(xchan);
+	mtx_destroy(&xchan->mtx_lock);
+	mtx_destroy(&xchan->mtx_qin_lock);
+	mtx_destroy(&xchan->mtx_qout_lock);
+	mtx_destroy(&xchan->mtx_bank_lock);
+	mtx_destroy(&xchan->mtx_proc_lock);
+	TAILQ_REMOVE(&xdma->channels, xchan, xchan_next);
+	XDMA_UNLOCK();
+	return (0);
+int
+xdma_setup_intr(xdma_channel_t *xchan,
+    int (*cb)(void *, xdma_transfer_status_t *),
+    void *arg, void **ihandler)
+	struct xdma_intr_handler *ih;
+	/* Sanity check. */
+	if (cb == NULL) {
+		    "%s: Can't setup interrupt handler.\n",
+		    __func__);
+		return (-1);
+	ih = malloc(sizeof(struct xdma_intr_handler),
+	    M_XDMA, M_WAITOK | M_ZERO);
+	ih->cb = cb;
+	ih->cb_user = arg;
+	XCHAN_LOCK(xchan);
+	TAILQ_INSERT_TAIL(&xchan->ie_handlers, ih, ih_next);
+	XCHAN_UNLOCK(xchan);
+	if (ihandler != NULL)
+		*ihandler = ih;
+	return (0);
+int
+xdma_teardown_intr(xdma_channel_t *xchan, struct xdma_intr_handler *ih)
+	if (ih == NULL) {
+		    "%s: Can't teardown interrupt.\n", __func__);
+		return (-1);
+	TAILQ_REMOVE(&xchan->ie_handlers, ih, ih_next);
+	free(ih, M_XDMA);
+	return (0);
+int
+xdma_teardown_all_intr(xdma_channel_t *xchan)
+	struct xdma_intr_handler *ih_tmp;
+	TAILQ_FOREACH_SAFE(ih, &xchan->ie_handlers, ih_next, ih_tmp) {
+		free(ih, M_XDMA);
+	return (0);
+int
+xdma_request(xdma_channel_t *xchan, struct xdma_request *req)
+	int ret;
+	ret = XDMA_CHANNEL_REQUEST(xdma->dma_dev, xchan, req);
+	if (ret != 0) {
+		    "%s: Can't request a transfer.\n", __func__);
+		return (-1);
+	return (0);
+int
+xdma_control(xdma_channel_t *xchan, enum xdma_command cmd)
+	int ret;
+	ret = XDMA_CHANNEL_CONTROL(xdma->dma_dev, xchan, cmd);
+	if (ret != 0) {
+		    "%s: Can't process command.\n", __func__);
+		return (-1);
+	return (0);
+void
+xdma_callback(xdma_channel_t *xchan, xdma_transfer_status_t *status)
+		if (ih->cb != NULL)
+			ih->cb(ih->cb_user, status);
+		xdma_queue_submit(xchan);
+#ifdef FDT
+ * Notify the DMA driver we have machine-dependent data in FDT.
+static int
+xdma_ofw_md_data(xdma_controller_t *xdma, pcell_t *cells, int ncells)
+	uint32_t ret;
+	ret = XDMA_OFW_MD_DATA(xdma->dma_dev,
+	    cells, ncells, (void **)&xdma->data);
+	return (ret);
+static int
+xdma_handle_mem_node(vmem_t *vmem, phandle_t memory)
+	pcell_t reg[FDT_REG_CELLS * FDT_MEM_REGIONS];
+	pcell_t *regp;
+	int addr_cells, size_cells;
+	int i, reg_len, ret, tuple_size, tuples;
+	u_long mem_start, mem_size;
+	if ((ret = fdt_addrsize_cells(OF_parent(memory), &addr_cells,
+	    &size_cells)) != 0)
+		return (ret);
+	if (addr_cells > 2)
+		return (ERANGE);
+	tuple_size = sizeof(pcell_t) * (addr_cells + size_cells);
+	reg_len = OF_getproplen(memory, "reg");
+	if (reg_len <= 0 || reg_len > sizeof(reg))
+		return (ERANGE);
+	if (OF_getprop(memory, "reg", reg, reg_len) <= 0)
+		return (ENXIO);
+	tuples = reg_len / tuple_size;
+	regp = (pcell_t *)®
+	for (i = 0; i < tuples; i++) {
+		ret = fdt_data_to_res(regp, addr_cells, size_cells,
+		    &mem_start, &mem_size);
+		if (ret != 0)
+			return (ret);
+		vmem_add(vmem, mem_start, mem_size, 0);
+		regp += addr_cells + size_cells;
+	return (0);
+vmem_t *
+xdma_get_memory(device_t dev)
+	phandle_t mem_node, node;
+	pcell_t mem_handle;
+	vmem_t *vmem;
+	node = ofw_bus_get_node(dev);
+	if (node <= 0) {
+		device_printf(dev,
+		    "%s called on not ofw based device.\n", __func__);
+		return (NULL);
+	if (!OF_hasprop(node, "memory-region"))
+		return (NULL);
+	if (OF_getencprop(node, "memory-region", (void *)&mem_handle,
+	    sizeof(mem_handle)) <= 0)
+		return (NULL);
+	vmem = vmem_create("xDMA vmem", 0, 0, PAGE_SIZE,
+	    PAGE_SIZE, M_BESTFIT | M_WAITOK);
+	if (vmem == NULL)
+		return (NULL);
+	mem_node = OF_node_from_xref(mem_handle);
+	if (xdma_handle_mem_node(vmem, mem_node) != 0) {
+		vmem_destroy(vmem);
+		return (NULL);
+	return (vmem);
+void
+xdma_put_memory(vmem_t *vmem)
+void
+xchan_set_memory(xdma_channel_t *xchan, vmem_t *vmem)
+	xchan->vmem = vmem;
+ * Allocate xdma controller.
+xdma_controller_t *
+xdma_ofw_get(device_t dev, const char *prop)
+	phandle_t node, parent;
+	device_t dma_dev;
+	pcell_t *cells;
+	int ncells;
+	int error;
+	int ndmas;
+	int idx;
+	if (node <= 0)
+	error = ofw_bus_parse_xref_list_get_length(node,
+	    "dmas", "#dma-cells", &ndmas);
+	if (error) {
+		    "%s can't get dmas list.\n", __func__);
+		return (NULL);
+	if (ndmas == 0) {
+		    "%s dmas list is empty.\n", __func__);
+		return (NULL);
+	error = ofw_bus_find_string_index(node, "dma-names", prop, &idx);
+	if (error != 0) {
+		    "%s can't find string index.\n", __func__);
+		return (NULL);
+	error = ofw_bus_parse_xref_list_alloc(node, "dmas", "#dma-cells",
+	    idx, &parent, &ncells, &cells);
+	if (error != 0) {
+		    "%s can't get dma device xref.\n", __func__);
+		return (NULL);
+	dma_dev = OF_device_from_xref(parent);
+	if (dma_dev == NULL) {
+		    "%s can't get dma device.\n", __func__);
+		return (NULL);
+	xdma = malloc(sizeof(struct xdma_controller),
+	xdma->dev = dev;
+	xdma->dma_dev = dma_dev;
+	TAILQ_INIT(&xdma->channels);
+	xdma_ofw_md_data(xdma, cells, ncells);
+	free(cells, M_OFWPROP);
+	return (xdma);
+#endif
+ * Free xDMA controller object.
+int
+xdma_put(xdma_controller_t *xdma)
+	XDMA_LOCK();
+	/* Ensure no channels allocated. */
+	if (!TAILQ_EMPTY(&xdma->channels)) {
+		device_printf(xdma->dev, "%s: Can't free xDMA\n", __func__);
+		return (-1);
+	free(xdma->data, M_DEVBUF);
+	free(xdma, M_XDMA);
+	XDMA_UNLOCK();
+	return (0);
+static void
+xdma_init(void)
+	mtx_init(&xdma_mtx, "xDMA", NULL, MTX_DEF);
+SYSINIT(xdma, SI_SUB_DRIVERS, SI_ORDER_FIRST, xdma_init, NULL);
diff --git a/freebsd/sys/dev/xdma/xdma.h b/freebsd/sys/dev/xdma/xdma.h
index 00000000..39e5b48b
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma.h
@@ -0,0 +1,285 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_XDMA_XDMA_H_
+#define _DEV_XDMA_XDMA_H_
+#include <sys/proc.h>
+#include <sys/vmem.h>
+#ifdef __rtems__
+#include <dev/ofw/openfirm.h>
+#endif
+enum xdma_direction {
+	XDMA_MEM_TO_MEM,
+	XDMA_MEM_TO_DEV,
+	XDMA_DEV_TO_MEM,
+	XDMA_DEV_TO_DEV,
+enum xdma_operation_type {
+	XDMA_MEMCPY,
+	XDMA_CYCLIC,
+	XDMA_FIFO,
+	XDMA_SG,
+enum xdma_request_type {
+	XR_TYPE_PHYS,
+	XR_TYPE_VIRT,
+	XR_TYPE_MBUF,
+	XR_TYPE_BIO,
+enum xdma_command {
+	XDMA_CMD_BEGIN,
+	XDMA_CMD_PAUSE,
+	XDMA_CMD_TERMINATE,
+struct xdma_transfer_status {
+	uint32_t	transferred;
+	int		error;
+typedef struct xdma_transfer_status xdma_transfer_status_t;
+struct xdma_controller {
+	device_t dev;		/* DMA consumer device_t. */
+	device_t dma_dev;	/* A real DMA device_t. */
+	void *data;		/* OFW MD part. */
+	vmem_t *vmem;		/* Bounce memory. */
+	/* List of virtual channels allocated. */
+	TAILQ_HEAD(xdma_channel_list, xdma_channel)	channels;
+typedef struct xdma_controller xdma_controller_t;
+struct xchan_buf {
+	bus_dmamap_t			map;
+	uint32_t			nsegs;
+	uint32_t			nsegs_left;
+	vm_offset_t			vaddr;
+	vm_offset_t			paddr;
+	vm_size_t			size;
+struct xdma_request {
+	struct mbuf			*m;
+	struct bio			*bp;
+	enum xdma_operation_type	operation;
+	enum xdma_request_type		req_type;
+	enum xdma_direction		direction;
+	bus_addr_t			src_addr;
+	bus_addr_t			dst_addr;
+	uint8_t				src_width;
+	uint8_t				dst_width;
+	bus_size_t			block_num;
+	bus_size_t			block_len;
+	xdma_transfer_status_t		status;
+	void				*user;
+	TAILQ_ENTRY(xdma_request)	xr_next;
+	struct xchan_buf		buf;
+struct xdma_sglist {
+	size_t				len;
+	bool				first;
+	bool				last;
+struct xdma_channel {
+	vmem_t				*vmem;
+	uint32_t			flags;
+#define	XCHAN_BUFS_ALLOCATED		(1 << 0)
+#define	XCHAN_SGLIST_ALLOCATED		(1 << 1)
+#define	XCHAN_CONFIGURED		(1 << 2)
+#define	XCHAN_TYPE_CYCLIC		(1 << 3)
+#define	XCHAN_TYPE_MEMCPY		(1 << 4)
+#define	XCHAN_TYPE_FIFO			(1 << 5)
+#define	XCHAN_TYPE_SG			(1 << 6)
+	uint32_t			caps;
+#define	XCHAN_CAP_BUSDMA		(1 << 0)
+#define	XCHAN_CAP_NOSEG			(1 << 1)
+#define	XCHAN_CAP_NOBUFS		(1 << 2)
+	/* A real hardware driver channel. */
+	void				*chan;
+	/* Interrupt handlers. */
+	TAILQ_HEAD(, xdma_intr_handler)	ie_handlers;
+	TAILQ_ENTRY(xdma_channel)	xchan_next;
+	struct mtx			mtx_lock;
+	struct mtx			mtx_qin_lock;
+	struct mtx			mtx_qout_lock;
+	struct mtx			mtx_bank_lock;
+	struct mtx			mtx_proc_lock;
+	/* Request queue. */
+	bus_dma_tag_t			dma_tag_bufs;
+	struct xdma_request		*xr_mem;
+	uint32_t			xr_num;
+	/* Bus dma tag options. */
+	bus_size_t			maxsegsize;
+	bus_size_t			maxnsegs;
+	bus_size_t			alignment;
+	bus_addr_t			boundary;
+	bus_addr_t			lowaddr;
+	bus_addr_t			highaddr;
+	struct xdma_sglist		*sg;
+	TAILQ_HEAD(, xdma_request)	bank;
+	TAILQ_HEAD(, xdma_request)	queue_in;
+	TAILQ_HEAD(, xdma_request)	queue_out;
+	TAILQ_HEAD(, xdma_request)	processing;
+typedef struct xdma_channel xdma_channel_t;
+struct xdma_intr_handler {
+	int		(*cb)(void *cb_user, xdma_transfer_status_t *status);
+	void		*cb_user;
+	TAILQ_ENTRY(xdma_intr_handler)	ih_next;
+#ifndef __rtems__
+static MALLOC_DEFINE(M_XDMA, "xdma", "xDMA framework");
+#else
+#ifdef IN_XDMA_C
+MALLOC_DEFINE(M_XDMA, "xdma", "xDMA framework");
+#else
+MALLOC_DECLARE(M_XDMA);
+#endif
+#endif
+#define	XCHAN_LOCK(xchan)		mtx_lock(&(xchan)->mtx_lock)
+#define	XCHAN_UNLOCK(xchan)		mtx_unlock(&(xchan)->mtx_lock)
+#define	XCHAN_ASSERT_LOCKED(xchan)	\
+    mtx_assert(&(xchan)->mtx_lock, MA_OWNED)
+#define	QUEUE_IN_LOCK(xchan)		mtx_lock(&(xchan)->mtx_qin_lock)
+#define	QUEUE_IN_UNLOCK(xchan)		mtx_unlock(&(xchan)->mtx_qin_lock)
+#define	QUEUE_IN_ASSERT_LOCKED(xchan)	\
+    mtx_assert(&(xchan)->mtx_qin_lock, MA_OWNED)
+#define	QUEUE_OUT_LOCK(xchan)		mtx_lock(&(xchan)->mtx_qout_lock)
+#define	QUEUE_OUT_UNLOCK(xchan)		mtx_unlock(&(xchan)->mtx_qout_lock)
+#define	QUEUE_OUT_ASSERT_LOCKED(xchan)	\
+    mtx_assert(&(xchan)->mtx_qout_lock, MA_OWNED)
+#define	QUEUE_BANK_LOCK(xchan)		mtx_lock(&(xchan)->mtx_bank_lock)
+#define	QUEUE_BANK_UNLOCK(xchan)	mtx_unlock(&(xchan)->mtx_bank_lock)
+#define	QUEUE_BANK_ASSERT_LOCKED(xchan)	\
+    mtx_assert(&(xchan)->mtx_bank_lock, MA_OWNED)
+#define	QUEUE_PROC_LOCK(xchan)		mtx_lock(&(xchan)->mtx_proc_lock)
+#define	QUEUE_PROC_UNLOCK(xchan)	mtx_unlock(&(xchan)->mtx_proc_lock)
+#define	QUEUE_PROC_ASSERT_LOCKED(xchan)	\
+    mtx_assert(&(xchan)->mtx_proc_lock, MA_OWNED)
+#define	XDMA_SGLIST_MAXLEN	2048
+#define	XDMA_MAX_SEG		128
+/* xDMA controller ops */
+xdma_controller_t *xdma_ofw_get(device_t dev, const char *prop);
+int xdma_put(xdma_controller_t *xdma);
+vmem_t * xdma_get_memory(device_t dev);
+void xdma_put_memory(vmem_t *vmem);
+/* xDMA channel ops */
+xdma_channel_t * xdma_channel_alloc(xdma_controller_t *, uint32_t caps);
+int xdma_channel_free(xdma_channel_t *);
+int xdma_request(xdma_channel_t *xchan, struct xdma_request *r);
+void xchan_set_memory(xdma_channel_t *xchan, vmem_t *vmem);
+/* SG interface */
+int xdma_prep_sg(xdma_channel_t *, uint32_t,
+    bus_size_t, bus_size_t, bus_size_t, bus_addr_t, bus_addr_t, bus_addr_t);
+void xdma_channel_free_sg(xdma_channel_t *xchan);
+int xdma_queue_submit_sg(xdma_channel_t *xchan);
+void xchan_seg_done(xdma_channel_t *xchan, xdma_transfer_status_t *);
+/* Queue operations */
+int xdma_dequeue_mbuf(xdma_channel_t *xchan, struct mbuf **m,
+    xdma_transfer_status_t *);
+int xdma_enqueue_mbuf(xdma_channel_t *xchan, struct mbuf **m, uintptr_t addr,
+    uint8_t, uint8_t, enum xdma_direction dir);
+int xdma_dequeue_bio(xdma_channel_t *xchan, struct bio **bp,
+    xdma_transfer_status_t *status);
+int xdma_enqueue_bio(xdma_channel_t *xchan, struct bio **bp, bus_addr_t addr,
+int xdma_dequeue(xdma_channel_t *xchan, void **user,
+int xdma_enqueue(xdma_channel_t *xchan, uintptr_t src, uintptr_t dst,
+    uint8_t, uint8_t, bus_size_t, enum xdma_direction dir, void *);
+int xdma_queue_submit(xdma_channel_t *xchan);
+/* Mbuf operations */
+uint32_t xdma_mbuf_defrag(xdma_channel_t *xchan, struct xdma_request *xr);
+uint32_t xdma_mbuf_chain_count(struct mbuf *m0);
+/* Channel Control */
+int xdma_control(xdma_channel_t *xchan, enum xdma_command cmd);
+/* Interrupt callback */
+int xdma_setup_intr(xdma_channel_t *xchan, int (*cb)(void *,
+    xdma_transfer_status_t *), void *arg, void **);
+int xdma_teardown_intr(xdma_channel_t *xchan, struct xdma_intr_handler *ih);
+int xdma_teardown_all_intr(xdma_channel_t *xchan);
+void xdma_callback(struct xdma_channel *xchan, xdma_transfer_status_t *status);
+/* Sglist */
+int xchan_sglist_alloc(xdma_channel_t *xchan);
+void xchan_sglist_free(xdma_channel_t *xchan);
+int xdma_sglist_add(struct xdma_sglist *sg, struct bus_dma_segment *seg,
+    uint32_t nsegs, struct xdma_request *xr);
+/* Requests bank */
+void xchan_bank_init(xdma_channel_t *xchan);
+int xchan_bank_free(xdma_channel_t *xchan);
+struct xdma_request * xchan_bank_get(xdma_channel_t *xchan);
+int xchan_bank_put(xdma_channel_t *xchan, struct xdma_request *xr);
+#endif /* !_DEV_XDMA_XDMA_H_ */
diff --git a/freebsd/sys/dev/xdma/xdma_bank.c b/freebsd/sys/dev/xdma/xdma_bank.c
index 00000000..96ddef97
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma_bank.c
@@ -0,0 +1,100 @@
+ * Copyright (c) 2018-2019 Ruslan Bukin <br at bsdpad.com>
+ * All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+void
+xchan_bank_init(xdma_channel_t *xchan)
+	struct xdma_request *xr;
+	int i;
+	xchan->xr_mem = malloc(sizeof(struct xdma_request) * xchan->xr_num,
+	for (i = 0; i < xchan->xr_num; i++) {
+		xr = &xchan->xr_mem[i];
+		TAILQ_INSERT_TAIL(&xchan->bank, xr, xr_next);
+int
+xchan_bank_free(xdma_channel_t *xchan)
+	free(xchan->xr_mem, M_XDMA);
+	return (0);
+xchan_bank_get(xdma_channel_t *xchan)
+	struct xdma_request *xr_tmp;
+	QUEUE_BANK_LOCK(xchan);
+	TAILQ_FOREACH_SAFE(xr, &xchan->bank, xr_next, xr_tmp) {
+		TAILQ_REMOVE(&xchan->bank, xr, xr_next);
+		break;
+	QUEUE_BANK_UNLOCK(xchan);
+	return (xr);
+int
+xchan_bank_put(xdma_channel_t *xchan, struct xdma_request *xr)
+	return (0);
diff --git a/freebsd/sys/dev/xdma/xdma_mbuf.c b/freebsd/sys/dev/xdma/xdma_mbuf.c
index 00000000..cbd32984
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma_mbuf.c
@@ -0,0 +1,151 @@
+ * Copyright (c) 2017-2019 Ruslan Bukin <br at bsdpad.com>
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/mbuf.h>
+#ifdef FDT
+#endif
+int
+xdma_dequeue_mbuf(xdma_channel_t *xchan, struct mbuf **mp,
+	QUEUE_OUT_LOCK(xchan);
+	TAILQ_FOREACH_SAFE(xr, &xchan->queue_out, xr_next, xr_tmp) {
+		TAILQ_REMOVE(&xchan->queue_out, xr, xr_next);
+		break;
+	QUEUE_OUT_UNLOCK(xchan);
+	if (xr == NULL)
+		return (-1);
+	*mp = xr->m;
+	status->error = xr->status.error;
+	status->transferred = xr->status.transferred;
+	xchan_bank_put(xchan, xr);
+	return (0);
+int
+xdma_enqueue_mbuf(xdma_channel_t *xchan, struct mbuf **mp,
+    uintptr_t addr, uint8_t src_width, uint8_t dst_width,
+    enum xdma_direction dir)
+	xr = xchan_bank_get(xchan);
+	if (xr == NULL)
+		return (-1); /* No space is available yet. */
+	xr->direction = dir;
+	xr->m = *mp;
+	xr->req_type = XR_TYPE_MBUF;
+	if (dir == XDMA_MEM_TO_DEV) {
+		xr->dst_addr = addr;
+		xr->src_addr = 0;
+	} else {
+		xr->src_addr = addr;
+		xr->dst_addr = 0;
+	xr->src_width = src_width;
+	xr->dst_width = dst_width;
+	QUEUE_IN_LOCK(xchan);
+	TAILQ_INSERT_TAIL(&xchan->queue_in, xr, xr_next);
+	QUEUE_IN_UNLOCK(xchan);
+	return (0);
+uint32_t
+xdma_mbuf_chain_count(struct mbuf *m0)
+	struct mbuf *m;
+	uint32_t c;
+	c = 0;
+	for (m = m0; m != NULL; m = m->m_next)
+		c++;
+	return (c);
+uint32_t
+xdma_mbuf_defrag(xdma_channel_t *xchan, struct xdma_request *xr)
+	struct mbuf *m;
+	uint32_t c;
+	c = xdma_mbuf_chain_count(xr->m);
+	if (c == 1)
+		return (c); /* Nothing to do. */
+	if ((m = m_defrag(xr->m, M_NOWAIT)) == NULL) {
+		device_printf(xdma->dma_dev,
+		    "%s: Can't defrag mbuf\n",
+		    __func__);
+		return (c);
+	xr->m = m;
+	c = 1;
+	return (c);
diff --git a/freebsd/sys/dev/xdma/xdma_queue.c b/freebsd/sys/dev/xdma/xdma_queue.c
index 00000000..22d7e2e2
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma_queue.c
@@ -0,0 +1,126 @@
+ * are met:
+ * SUCH DAMAGE.
+int
+xdma_dequeue(xdma_channel_t *xchan, void **user,
+		break;
+	if (xr == NULL)
+		return (-1);
+	*user = xr->user;
+	return (0);
+int
+xdma_enqueue(xdma_channel_t *xchan, uintptr_t src, uintptr_t dst,
+    uint8_t src_width, uint8_t dst_width, bus_size_t len,
+    enum xdma_direction dir, void *user)
+	if (xr == NULL)
+		return (-1); /* No space is available. */
+	xr->user = user;
+	xr->m = NULL;
+	xr->bp = NULL;
+	xr->block_num = 1;
+	xr->block_len = len;
+	xr->req_type = XR_TYPE_VIRT;
+	xr->src_addr = src;
+	xr->dst_addr = dst;
+	return (0);
+int
+xdma_queue_submit(xdma_channel_t *xchan)
+	int ret;
+	ret = 0;
+		ret = xdma_queue_submit_sg(xchan);
+	return (ret);
diff --git a/freebsd/sys/dev/xdma/xdma_sg.c b/freebsd/sys/dev/xdma/xdma_sg.c
index 00000000..fa69a297
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma_sg.c
@@ -0,0 +1,660 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/rwlock.h>
+#include <vm/vm.h>
+#include <vm/vm_extern.h>
+#include <vm/vm_page.h>
+#ifdef FDT
+#endif
+struct seg_load_request {
+	struct bus_dma_segment *seg;
+	uint32_t nsegs;
+	uint32_t error;
+static void
+xchan_bufs_free_reserved(xdma_channel_t *xchan)
+	vm_size_t size;
+	int i;
+		size = xr->buf.size;
+#ifndef __rtems__    /* XXX */
+		if (xr->buf.vaddr) {
+			pmap_kremove_device(xr->buf.vaddr, size);
+			kva_free(xr->buf.vaddr, size);
+			xr->buf.vaddr = 0;
+#endif
+		if (xr->buf.paddr) {
+			vmem_free(xchan->vmem, xr->buf.paddr, size);
+			xr->buf.paddr = 0;
+		xr->buf.size = 0;
+static int
+xchan_bufs_alloc_reserved(xdma_channel_t *xchan)
+	vmem_addr_t addr;
+	vm_size_t size;
+	int i;
+	if (xchan->vmem == NULL)
+		return (ENOBUFS);
+		size = round_page(xchan->maxsegsize);
+		if (vmem_alloc(xchan->vmem, size,
+		    M_BESTFIT | M_NOWAIT, &addr)) {
+			    "%s: Can't allocate memory\n", __func__);
+			xchan_bufs_free_reserved(xchan);
+			return (ENOMEM);
+		xr->buf.size = size;
+		xr->buf.paddr = addr;
+#ifndef __rtems__
+		xr->buf.vaddr = kva_alloc(size);
+#else
+		xr->buf.vaddr = calloc(1,size);
+#endif
+		if (xr->buf.vaddr == 0) {
+			    "%s: Can't allocate KVA\n", __func__);
+			return (ENOMEM);
+#ifndef __rtems__
+		pmap_kenter_device(xr->buf.vaddr, size, addr);
+#else
+/* XXX */
+#endif
+	return (0);
+static int
+xchan_bufs_alloc_busdma(xdma_channel_t *xchan)
+	int err;
+	int i;
+	/* Create bus_dma tag */
+	err = bus_dma_tag_create(
+	    bus_get_dma_tag(xdma->dev),	/* Parent tag. */
+	    xchan->alignment,		/* alignment */
+	    xchan->boundary,		/* boundary */
+	    xchan->lowaddr,		/* lowaddr */
+	    xchan->highaddr,		/* highaddr */
+	    NULL, NULL,			/* filter, filterarg */
+	    xchan->maxsegsize * xchan->maxnsegs, /* maxsize */
+	    xchan->maxnsegs,		/* nsegments */
+	    xchan->maxsegsize,		/* maxsegsize */
+	    0,				/* flags */
+	    NULL, NULL,			/* lockfunc, lockarg */
+	    &xchan->dma_tag_bufs);
+	if (err != 0) {
+		    "%s: Can't create bus_dma tag.\n", __func__);
+		return (-1);
+		err = bus_dmamap_create(xchan->dma_tag_bufs, 0,
+		    &xr->buf.map);
+		if (err != 0) {
+			    "%s: Can't create buf DMA map.\n", __func__);
+			/* Cleanup. */
+			bus_dma_tag_destroy(xchan->dma_tag_bufs);
+			return (-1);
+	return (0);
+static int
+xchan_bufs_alloc(xdma_channel_t *xchan)
+	int ret;
+	if (xdma == NULL) {
+		printf("%s: Channel was not allocated properly.\n", __func__);
+		return (-1);
+	if (xchan->caps & XCHAN_CAP_BUSDMA)
+		ret = xchan_bufs_alloc_busdma(xchan);
+	else {
+		ret = xchan_bufs_alloc_reserved(xchan);
+	if (ret != 0) {
+		    "%s: Can't allocate bufs.\n", __func__);
+		return (-1);
+	xchan->flags |= XCHAN_BUFS_ALLOCATED;
+	return (0);
+static int
+xchan_bufs_free(xdma_channel_t *xchan)
+	struct xchan_buf *b;
+	int i;
+	if ((xchan->flags & XCHAN_BUFS_ALLOCATED) == 0)
+		return (-1);
+	if (xchan->caps & XCHAN_CAP_BUSDMA) {
+			b = &xr->buf;
+			bus_dmamap_destroy(xchan->dma_tag_bufs, b->map);
+	} else
+	xchan->flags &= ~XCHAN_BUFS_ALLOCATED;
+	return (0);
+void
+xdma_channel_free_sg(xdma_channel_t *xchan)
+	xchan_bufs_free(xchan);
+	xchan_sglist_free(xchan);
+	xchan_bank_free(xchan);
+ * Prepare xchan for a scatter-gather transfer.
+ * xr_num - xdma requests queue size,
+ * maxsegsize - maximum allowed scatter-gather list element size in bytes
+int
+xdma_prep_sg(xdma_channel_t *xchan, uint32_t xr_num,
+    bus_size_t maxsegsize, bus_size_t maxnsegs,
+    bus_size_t alignment, bus_addr_t boundary,
+    bus_addr_t lowaddr, bus_addr_t highaddr)
+	int ret;
+	if (xchan->flags & XCHAN_CONFIGURED) {
+		    "%s: Channel is already configured.\n", __func__);
+		return (-1);
+	xchan->xr_num = xr_num;
+	xchan->maxsegsize = maxsegsize;
+	xchan->maxnsegs = maxnsegs;
+	xchan->alignment = alignment;
+	xchan->boundary = boundary;
+	xchan->lowaddr = lowaddr;
+	xchan->highaddr = highaddr;
+	if (xchan->maxnsegs > XDMA_MAX_SEG) {
+		device_printf(xdma->dev, "%s: maxnsegs is too big\n",
+		    __func__);
+		return (-1);
+	xchan_bank_init(xchan);
+	/* Allocate sglist. */
+	ret = xchan_sglist_alloc(xchan);
+	if (ret != 0) {
+		    "%s: Can't allocate sglist.\n", __func__);
+		return (-1);
+	/* Allocate buffers if required. */
+	if ((xchan->caps & XCHAN_CAP_NOBUFS) == 0) {
+		ret = xchan_bufs_alloc(xchan);
+		if (ret != 0) {
+			/* Cleanup */
+			return (-1);
+	xchan->flags |= (XCHAN_CONFIGURED | XCHAN_TYPE_SG);
+	ret = XDMA_CHANNEL_PREP_SG(xdma->dma_dev, xchan);
+	if (ret != 0) {
+		    "%s: Can't prepare SG transfer.\n", __func__);
+		return (-1);
+	return (0);
+void
+xchan_seg_done(xdma_channel_t *xchan,
+    struct xdma_transfer_status *st)
+	xr = TAILQ_FIRST(&xchan->processing);
+	if (xr == NULL)
+		panic("request not found\n");
+	b = &xr->buf;
+	atomic_subtract_int(&b->nsegs_left, 1);
+	if (b->nsegs_left == 0) {
+			if (xr->direction == XDMA_MEM_TO_DEV)
+				bus_dmamap_sync(xchan->dma_tag_bufs, b->map,
+				    BUS_DMASYNC_POSTWRITE);
+			else
+				    BUS_DMASYNC_POSTREAD);
+			bus_dmamap_unload(xchan->dma_tag_bufs, b->map);
+		} else {
+			if ((xchan->caps & XCHAN_CAP_NOBUFS) == 0 &&
+			    xr->req_type == XR_TYPE_MBUF &&
+			    xr->direction == XDMA_DEV_TO_MEM)
+				m_copyback(xr->m, 0, st->transferred,
+				    (void *)xr->buf.vaddr);
+		xr->status.error = st->error;
+		xr->status.transferred = st->transferred;
+		QUEUE_PROC_LOCK(xchan);
+		TAILQ_REMOVE(&xchan->processing, xr, xr_next);
+		QUEUE_PROC_UNLOCK(xchan);
+		TAILQ_INSERT_TAIL(&xchan->queue_out, xr, xr_next);
+static void
+xdma_dmamap_cb(void *arg, bus_dma_segment_t *segs, int nsegs, int error)
+	struct seg_load_request *slr;
+	int i;
+	slr = arg;
+	seg = slr->seg;
+	if (error != 0) {
+		slr->error = error;
+		return;
+	slr->nsegs = nsegs;
+	for (i = 0; i < nsegs; i++) {
+		seg[i].ds_addr = segs[i].ds_addr;
+		seg[i].ds_len = segs[i].ds_len;
+static int
+_xdma_load_data_busdma(xdma_channel_t *xchan, struct xdma_request *xr,
+    struct bus_dma_segment *seg)
+	struct seg_load_request slr;
+	uint32_t nsegs;
+	void *addr;
+	int error;
+	error = 0;
+	nsegs = 0;
+	switch (xr->req_type) {
+	case XR_TYPE_MBUF:
+		error = bus_dmamap_load_mbuf_sg(xchan->dma_tag_bufs,
+		    xr->buf.map, xr->m, seg, &nsegs, BUS_DMA_NOWAIT);
+		break;
+#ifndef __rtems__
+	case XR_TYPE_BIO:
+		slr.nsegs = 0;
+		slr.error = 0;
+		slr.seg = seg;
+		error = bus_dmamap_load_bio(xchan->dma_tag_bufs,
+		    xr->buf.map, xr->bp, xdma_dmamap_cb, &slr, BUS_DMA_NOWAIT);
+		if (slr.error != 0) {
+			    "%s: bus_dmamap_load failed, err %d\n",
+			    __func__, slr.error);
+			return (0);
+		nsegs = slr.nsegs;
+		break;
+#endif   /* XXX */
+	case XR_TYPE_VIRT:
+		switch (xr->direction) {
+		case XDMA_MEM_TO_DEV:
+			addr = (void *)xr->src_addr;
+			break;
+		case XDMA_DEV_TO_MEM:
+			addr = (void *)xr->dst_addr;
+			break;
+		default:
+			    "%s: Direction is not supported\n", __func__);
+			return (0);
+		slr.nsegs = 0;
+		slr.error = 0;
+		slr.seg = seg;
+		error = bus_dmamap_load(xchan->dma_tag_bufs, xr->buf.map,
+		    addr, (xr->block_len * xr->block_num),
+		    xdma_dmamap_cb, &slr, BUS_DMA_NOWAIT);
+			return (0);
+		break;
+	default:
+		break;
+	if (error != 0) {
+		if (error == ENOMEM) {
+			 * Out of memory. Try again later.
+			 * TODO: count errors.
+		} else
+			    "%s: bus_dmamap_load failed with err %d\n",
+			    __func__, error);
+		return (0);
+		bus_dmamap_sync(xchan->dma_tag_bufs, xr->buf.map,
+		    BUS_DMASYNC_PREWRITE);
+	else
+		    BUS_DMASYNC_PREREAD);
+	return (nsegs);
+static int
+_xdma_load_data(xdma_channel_t *xchan, struct xdma_request *xr,
+	struct mbuf *m;
+	uint32_t nsegs;
+	m = xr->m;
+	nsegs = 1;
+				m_copydata(m, 0, m->m_pkthdr.len,
+			seg[0].ds_addr = (bus_addr_t)xr->buf.paddr;
+		} else
+			seg[0].ds_addr = mtod(m, bus_addr_t);
+		seg[0].ds_len = m->m_pkthdr.len;
+		break;
+	case XR_TYPE_BIO:
+	default:
+		panic("implement me\n");
+	return (nsegs);
+static int
+xdma_load_data(xdma_channel_t *xchan,
+    struct xdma_request *xr, struct bus_dma_segment *seg)
+	int error;
+	int nsegs;
+	error = 0;
+	nsegs = 0;
+		nsegs = _xdma_load_data_busdma(xchan, xr, seg);
+	else
+		nsegs = _xdma_load_data(xchan, xr, seg);
+	if (nsegs == 0)
+		return (0); /* Try again later. */
+	xr->buf.nsegs = nsegs;
+	xr->buf.nsegs_left = nsegs;
+	return (nsegs);
+static int
+xdma_process(xdma_channel_t *xchan,
+    struct xdma_sglist *sg)
+	struct bus_dma_segment seg[XDMA_MAX_SEG];
+	uint32_t capacity;
+	uint32_t n;
+	uint32_t c;
+	int nsegs;
+	int ret;
+	XCHAN_ASSERT_LOCKED(xchan);
+	n = 0;
+	c = 0;
+	ret = XDMA_CHANNEL_CAPACITY(xdma->dma_dev, xchan, &capacity);
+	if (ret != 0) {
+		    "%s: Can't get DMA controller capacity.\n", __func__);
+		return (-1);
+	TAILQ_FOREACH_SAFE(xr, &xchan->queue_in, xr_next, xr_tmp) {
+			if ((xchan->caps & XCHAN_CAP_NOSEG) ||
+			    (c > xchan->maxnsegs))
+				c = xdma_mbuf_defrag(xchan, xr);
+			break;
+		case XR_TYPE_BIO:
+		default:
+			c = 1;
+		if (capacity <= (c + n)) {
+			 * No space yet available for the entire
+			 * request in the DMA engine.
+			break;
+		if ((c + n + xchan->maxnsegs) >= XDMA_SGLIST_MAXLEN) {
+			/* Sglist is full. */
+			break;
+		nsegs = xdma_load_data(xchan, xr, seg);
+		if (nsegs == 0)
+			break;
+		xdma_sglist_add(&sg[n], seg, nsegs, xr);
+		n += nsegs;
+		TAILQ_REMOVE(&xchan->queue_in, xr, xr_next);
+		TAILQ_INSERT_TAIL(&xchan->processing, xr, xr_next);
+	return (n);
+int
+xdma_queue_submit_sg(xdma_channel_t *xchan)
+	uint32_t sg_n;
+	int ret;
+	sg = xchan->sg;
+	   (xchan->flags & XCHAN_BUFS_ALLOCATED) == 0) {
+		    "%s: Can't submit a transfer: no bufs\n",
+		    __func__);
+		return (-1);
+	sg_n = xdma_process(xchan, sg);
+	if (sg_n == 0)
+		return (0); /* Nothing to submit */
+	/* Now submit sglist to DMA engine driver. */
+	ret = XDMA_CHANNEL_SUBMIT_SG(xdma->dma_dev, xchan, sg, sg_n);
+	if (ret != 0) {
+		    "%s: Can't submit an sglist.\n", __func__);
+		return (-1);
+	return (0);
diff --git a/freebsd/sys/dev/xdma/xdma_sglist.c b/freebsd/sys/dev/xdma/xdma_sglist.c
index 00000000..8c3c5ab0
--- /dev/null
+++ b/freebsd/sys/dev/xdma/xdma_sglist.c
@@ -0,0 +1,103 @@
+ * Copyright (c) 2017-2018 Ruslan Bukin <br at bsdpad.com>
+ * are met:
+ * SUCH DAMAGE.
+int
+xchan_sglist_alloc(xdma_channel_t *xchan)
+	uint32_t sz;
+	if (xchan->flags & XCHAN_SGLIST_ALLOCATED)
+		return (-1);
+	sz = (sizeof(struct xdma_sglist) * XDMA_SGLIST_MAXLEN);
+	xchan->sg = malloc(sz, M_XDMA, M_WAITOK | M_ZERO);
+	xchan->flags |= XCHAN_SGLIST_ALLOCATED;
+	return (0);
+void
+xchan_sglist_free(xdma_channel_t *xchan)
+		free(xchan->sg, M_XDMA);
+	xchan->flags &= ~XCHAN_SGLIST_ALLOCATED;
+int
+xdma_sglist_add(struct xdma_sglist *sg, struct bus_dma_segment *seg,
+	int i;
+	if (nsegs == 0)
+		return (-1);
+		sg[i].src_width = xr->src_width;
+		sg[i].dst_width = xr->dst_width;
+		if (xr->direction == XDMA_MEM_TO_DEV) {
+			sg[i].src_addr = seg[i].ds_addr;
+			sg[i].dst_addr = xr->dst_addr;
+		} else {
+			sg[i].src_addr = xr->src_addr;
+			sg[i].dst_addr = seg[i].ds_addr;
+		sg[i].len = seg[i].ds_len;
+		sg[i].direction = xr->direction;
+		sg[i].first = 0;
+		sg[i].last = 0;
+	sg[0].first = 1;
+	sg[nsegs - 1].last = 1;
+	return (0);
diff --git a/freebsd/sys/dev/xilinx/axidma.c b/freebsd/sys/dev/xilinx/axidma.c
index 00000000..00ae2f1d
--- /dev/null
+++ b/freebsd/sys/dev/xilinx/axidma.c
@@ -0,0 +1,666 @@
+ * are met:
+ * SUCH DAMAGE.
+/* Xilinx AXI DMA controller driver. */
+#include <sys/module.h>
+#include <sys/rman.h>
+#include <vm/vm.h>
+#ifdef FDT
+#endif
+#include <dev/xilinx/axidma.h>
+#define AXIDMA_DEBUG
+#undef AXIDMA_DEBUG
+#ifdef __rtems__
+#include <sys/endian.h>
+#endif
+#ifdef AXIDMA_DEBUG
+#define dprintf(fmt, ...)  printf(fmt, ##__VA_ARGS__)
+#else
+#endif
+#define	AXIDMA_NCHANNELS	2
+#define	AXIDMA_DESCS_NUM	512
+#define	AXIDMA_TX_CHAN		0
+#define	AXIDMA_RX_CHAN		1
+extern struct bus_space memmap_bus;
+struct axidma_fdt_data {
+	int id;
+struct axidma_channel {
+	struct axidma_softc	*sc;
+	bool			used;
+	int			idx_head;
+	int			idx_tail;
+	struct axidma_desc	**descs;
+	vm_paddr_t		*descs_phys;
+	uint32_t		descs_num;
+	vm_size_t		mem_size;
+	vm_offset_t		mem_paddr;
+	vm_offset_t		mem_vaddr;
+	uint32_t		descs_used_count;
+struct axidma_softc {
+	device_t		dev;
+	struct resource		*res[3];
+	bus_space_tag_t		bst;
+	bus_space_handle_t	bsh;
+	void			*ih[2];
+	struct axidma_desc	desc;
+	struct axidma_channel	channels[AXIDMA_NCHANNELS];
+static struct resource_spec axidma_spec[] = {
+	{ SYS_RES_MEMORY,	0,	RF_ACTIVE },
+	{ SYS_RES_IRQ,		0,	RF_ACTIVE },
+	{ SYS_RES_IRQ,		1,	RF_ACTIVE },
+	{ -1, 0 }
+#define	HWTYPE_NONE	0
+#define	HWTYPE_STD	1
+static struct ofw_compat_data compat_data[] = {
+	{ "xlnx,eth-dma",	HWTYPE_STD },
+	{ NULL,			HWTYPE_NONE },
+static int axidma_probe(device_t dev);
+static int axidma_attach(device_t dev);
+static int axidma_detach(device_t dev);
+static inline uint32_t
+axidma_next_desc(struct axidma_channel *chan, uint32_t curidx)
+	return ((curidx + 1) % chan->descs_num);
+static void
+axidma_intr(struct axidma_softc *sc,
+    struct axidma_channel *chan)
+	xdma_transfer_status_t st;
+	struct axidma_fdt_data *data;
+	struct axidma_desc *desc;
+	struct xdma_channel *xchan;
+	uint32_t tot_copied;
+	int pending;
+	int errors;
+	xchan = chan->xchan;
+	data = xdma->data;
+	pending = READ4(sc, AXI_DMASR(data->id));
+	WRITE4(sc, AXI_DMASR(data->id), pending);
+	errors = (pending & (DMASR_DMAINTERR | DMASR_DMASLVERR
+			| DMASR_DMADECOREERR | DMASR_SGINTERR
+			| DMASR_SGSLVERR | DMASR_SGDECERR));
+	dprintf("%s: AXI_DMASR %x\n", __func__,
+	    READ4(sc, AXI_DMASR(data->id)));
+	dprintf("%s: AXI_CURDESC %x\n", __func__,
+	    READ4(sc, AXI_CURDESC(data->id)));
+	dprintf("%s: AXI_TAILDESC %x\n", __func__,
+	    READ4(sc, AXI_TAILDESC(data->id)));
+	tot_copied = 0;
+	while (chan->idx_tail != chan->idx_head) {
+		desc = chan->descs[chan->idx_tail];
+		if ((desc->status & BD_STATUS_CMPLT) == 0)
+			break;
+		st.error = errors;
+		st.transferred = desc->status & BD_CONTROL_LEN_M;
+		tot_copied += st.transferred;
+		xchan_seg_done(xchan, &st);
+		chan->idx_tail = axidma_next_desc(chan, chan->idx_tail);
+		atomic_subtract_int(&chan->descs_used_count, 1);
+	/* Finish operation */
+	status.error = errors;
+	status.transferred = tot_copied;
+	xdma_callback(chan->xchan, &status);
+static void
+axidma_intr_rx(void *arg)
+	struct axidma_channel *chan;
+	dprintf("%s\n", __func__);
+	sc = arg;
+	chan = &sc->channels[AXIDMA_RX_CHAN];
+	axidma_intr(sc, chan);
+static void
+axidma_intr_tx(void *arg)
+	sc = arg;
+	chan = &sc->channels[AXIDMA_TX_CHAN];
+static int
+axidma_reset(struct axidma_softc *sc, int chan_id)
+	int timeout;
+	WRITE4(sc, AXI_DMACR(chan_id), DMACR_RESET);
+	timeout = 100;
+	do {
+		if ((READ4(sc, AXI_DMACR(chan_id)) & DMACR_RESET) == 0)
+			break;
+	} while (timeout--);
+	dprintf("timeout %d\n", timeout);
+	if (timeout == 0)
+		return (-1);
+	dprintf("%s: %d read control after reset: %x\n",
+	    __func__, chan_id, READ4(sc, AXI_DMACR(chan_id)));
+	return (0);
+static int
+axidma_probe(device_t dev)
+	int hwtype;
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	hwtype = ofw_bus_search_compatible(dev, compat_data)->ocd_data;
+	if (hwtype == HWTYPE_NONE)
+		return (ENXIO);
+	device_set_desc(dev, "Xilinx AXI DMA");
+	return (BUS_PROBE_DEFAULT);
+static int
+axidma_attach(device_t dev)
+	phandle_t xref, node;
+	int err;
+	sc = device_get_softc(dev);
+	sc->dev = dev;
+	if (bus_alloc_resources(dev, axidma_spec, sc->res)) {
+		device_printf(dev, "could not allocate resources.\n");
+		return (ENXIO);
+	/* CSR memory interface */
+	sc->bst = rman_get_bustag(sc->res[0]);
+	sc->bsh = rman_get_bushandle(sc->res[0]);
+	/* Setup interrupt handler */
+	err = bus_setup_intr(dev, sc->res[1], INTR_TYPE_MISC | INTR_MPSAFE,
+	    NULL, axidma_intr_tx, sc, &sc->ih[0]);
+	if (err) {
+		device_printf(dev, "Unable to alloc interrupt resource.\n");
+		return (ENXIO);
+	err = bus_setup_intr(dev, sc->res[2], INTR_TYPE_MISC | INTR_MPSAFE,
+	    NULL, axidma_intr_rx, sc, &sc->ih[1]);
+	if (err) {
+		return (ENXIO);
+	xref = OF_xref_from_node(node);
+	OF_device_register_xref(xref, dev);
+	return (0);
+static int
+axidma_detach(device_t dev)
+	bus_teardown_intr(dev, sc->res[1], sc->ih[0]);
+	bus_teardown_intr(dev, sc->res[2], sc->ih[1]);
+	bus_release_resources(dev, axidma_spec, sc->res);
+	return (0);
+static int
+axidma_desc_free(struct axidma_softc *sc, struct axidma_channel *chan)
+	int nsegments;
+	nsegments = chan->descs_num;
+	free(chan->descs, M_DEVBUF);
+	free(chan->descs_phys, M_DEVBUF);
+#ifndef __rtems__
+	pmap_kremove_device(chan->mem_vaddr, chan->mem_size);
+	kva_free(chan->mem_vaddr, chan->mem_size);
+#endif
+	vmem_free(xchan->vmem, chan->mem_paddr, chan->mem_size);
+	return (0);
+static int
+axidma_desc_alloc(struct axidma_softc *sc, struct xdma_channel *xchan,
+    uint32_t desc_size)
+	int nsegments;
+	int i;
+	chan = (struct axidma_channel *)xchan->chan;
+	chan->descs = malloc(nsegments * sizeof(struct axidma_desc *),
+	    M_DEVBUF, M_NOWAIT | M_ZERO);
+	if (chan->descs == NULL) {
+		device_printf(sc->dev,
+		    "%s: Can't allocate memory.\n", __func__);
+		return (-1);
+	chan->descs_phys = malloc(nsegments * sizeof(bus_dma_segment_t),
+	chan->mem_size = desc_size * nsegments;
+	if (vmem_alloc(xchan->vmem, chan->mem_size, M_FIRSTFIT | M_NOWAIT,
+	    &chan->mem_paddr)) {
+		device_printf(sc->dev, "Failed to allocate memory.\n");
+		return (-1);
+#ifndef __rtems__
+	chan->mem_vaddr = kva_alloc(chan->mem_size);
+	pmap_kenter_device(chan->mem_vaddr, chan->mem_size, chan->mem_paddr);
+#else
+	chan->mem_vaddr = calloc(1, chan->mem_size);
+#endif
+	device_printf(sc->dev, "Allocated chunk %lx %d\n",
+	    chan->mem_paddr, chan->mem_size);
+	for (i = 0; i < nsegments; i++) {
+		chan->descs[i] = (struct axidma_desc *)
+		    ((uint64_t)chan->mem_vaddr + desc_size * i);
+		chan->descs_phys[i] = chan->mem_paddr + desc_size * i;
+	return (0);
+static int
+axidma_channel_alloc(device_t dev, struct xdma_channel *xchan)
+		    "Error: busdma operation is not implemented.");
+		return (-1);
+	chan = &sc->channels[data->id];
+	if (chan->used == false) {
+		if (axidma_reset(sc, data->id) != 0)
+			return (-1);
+		chan->xchan = xchan;
+		xchan->chan = (void *)chan;
+		chan->sc = sc;
+		chan->used = true;
+		chan->idx_head = 0;
+		chan->idx_tail = 0;
+		chan->descs_used_count = 0;
+		chan->descs_num = AXIDMA_DESCS_NUM;
+		return (0);
+	return (-1);
+static int
+axidma_channel_free(device_t dev, struct xdma_channel *xchan)
+	axidma_desc_free(sc, chan);
+	chan->used = false;
+	return (0);
+static int
+axidma_channel_capacity(device_t dev, xdma_channel_t *xchan,
+    uint32_t *capacity)
+	uint32_t c;
+	/* At least one descriptor must be left empty. */
+	c = (chan->descs_num - chan->descs_used_count - 1);
+	*capacity = c;
+	return (0);
+static int
+axidma_channel_submit_sg(device_t dev, struct xdma_channel *xchan,
+    struct xdma_sglist *sg, uint32_t sg_n)
+	uint32_t src_addr;
+	uint32_t dst_addr;
+	uint32_t addr;
+	uint32_t len;
+	uint32_t tmp;
+	int i;
+	int tail;
+	dprintf("%s: sg_n %d\n", __func__, sg_n);
+	if (sg_n == 0)
+		return (0);
+	tail = chan->idx_head;
+	tmp = 0;
+	for (i = 0; i < sg_n; i++) {
+		src_addr = (uint32_t)sg[i].src_addr;
+		dst_addr = (uint32_t)sg[i].dst_addr;
+		len = (uint32_t)sg[i].len;
+		dprintf("%s(%d): src %x dst %x len %d\n", __func__,
+		    data->id, src_addr, dst_addr, len);
+		desc = chan->descs[chan->idx_head];
+		if (sg[i].direction == XDMA_MEM_TO_DEV)
+			desc->phys = src_addr;
+		else
+			desc->phys = dst_addr;
+		desc->status = 0;
+		desc->control = len;
+		if (sg[i].first == 1)
+			desc->control |= BD_CONTROL_TXSOF;
+		if (sg[i].last == 1)
+			desc->control |= BD_CONTROL_TXEOF;
+		tmp = chan->idx_head;
+		atomic_add_int(&chan->descs_used_count, 1);
+		chan->idx_head = axidma_next_desc(chan, chan->idx_head);
+	dprintf("%s(%d): _curdesc(msb) %x\n", __func__, data->id,
+	    READ8(sc, AXI_CURDESC_MSB(data->id)));
+	dprintf("%s(%d): _curdesc %x\n", __func__, data->id,
+	    READ8(sc, AXI_CURDESC(data->id)));
+	dprintf("%s(%d): status %x\n", __func__, data->id,
+	addr = chan->descs_phys[tmp];
+	WRITE8(sc, AXI_TAILDESC(data->id), addr);
+	return (0);
+static int
+axidma_channel_prep_sg(device_t dev, struct xdma_channel *xchan)
+	uint32_t addr;
+	uint32_t reg;
+	int ret;
+	int i;
+	dprintf("%s(%d)\n", __func__, data->id);
+	ret = axidma_desc_alloc(sc, xchan, sizeof(struct axidma_desc));
+	if (ret != 0) {
+		    "%s: Can't allocate descriptors.\n", __func__);
+		return (-1);
+	for (i = 0; i < chan->descs_num; i++) {
+		desc = chan->descs[i];
+		bzero(desc, sizeof(struct axidma_desc));
+		if (i == (chan->descs_num - 1))
+			desc->next = chan->descs_phys[0];
+		else
+			desc->next = chan->descs_phys[i + 1];
+		desc->status = 0;
+		desc->control = 0;
+#ifndef __rtems__
+		dprintf("%s(%d): desc %d vaddr %lx next paddr %x\n", __func__,
+		    data->id, i, (uint64_t)desc, le32toh(desc->next));
+#else
+		    data->id, i, desc, le32toh(desc->next));
+#endif
+	addr = chan->descs_phys[0];
+	WRITE8(sc, AXI_CURDESC(data->id), addr);
+	reg = READ4(sc, AXI_DMACR(data->id));
+	reg |= DMACR_IOC_IRQEN | DMACR_DLY_IRQEN | DMACR_ERR_IRQEN;
+	WRITE4(sc, AXI_DMACR(data->id), reg);
+	reg |= DMACR_RS;
+#ifdef __rtems__
+	dprintf("%s: %d read control: %x\n",
+	    __func__, data->id, READ4(sc, AXI_DMACR(data->id)));
+#endif
+	return (0);
+static int
+axidma_channel_control(device_t dev, xdma_channel_t *xchan, int cmd)
+	switch (cmd) {
+	case XDMA_CMD_BEGIN:
+	case XDMA_CMD_TERMINATE:
+	case XDMA_CMD_PAUSE:
+		/* TODO: implement me */
+		return (-1);
+	return (0);
+#ifdef FDT
+static int
+axidma_ofw_md_data(device_t dev, pcell_t *cells, int ncells, void **ptr)
+	if (ncells != 1)
+		return (-1);
+	data = malloc(sizeof(struct axidma_fdt_data),
+	    M_DEVBUF, (M_WAITOK | M_ZERO));
+	data->id = cells[0];
+	*ptr = data;
+	return (0);
+#endif
+static device_method_t axidma_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,			axidma_probe),
+	DEVMETHOD(device_attach,		axidma_attach),
+	DEVMETHOD(device_detach,		axidma_detach),
+	/* xDMA Interface */
+	DEVMETHOD(xdma_channel_alloc,		axidma_channel_alloc),
+	DEVMETHOD(xdma_channel_free,		axidma_channel_free),
+	DEVMETHOD(xdma_channel_control,		axidma_channel_control),
+	/* xDMA SG Interface */
+	DEVMETHOD(xdma_channel_capacity,	axidma_channel_capacity),
+	DEVMETHOD(xdma_channel_prep_sg,		axidma_channel_prep_sg),
+	DEVMETHOD(xdma_channel_submit_sg,	axidma_channel_submit_sg),
+#ifdef FDT
+	DEVMETHOD(xdma_ofw_md_data,		axidma_ofw_md_data),
+#endif
+	DEVMETHOD_END
+static driver_t axidma_driver = {
+	"axidma",
+	axidma_methods,
+	sizeof(struct axidma_softc),
+static devclass_t axidma_devclass;
+EARLY_DRIVER_MODULE(axidma, simplebus, axidma_driver, axidma_devclass, 0, 0,
+    BUS_PASS_INTERRUPT + BUS_PASS_ORDER_LATE);
diff --git a/freebsd/sys/dev/xilinx/axidma.h b/freebsd/sys/dev/xilinx/axidma.h
index 00000000..8e5d8387
--- /dev/null
+++ b/freebsd/sys/dev/xilinx/axidma.h
@@ -0,0 +1,96 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_XILINX_AXIDMA_H_
+#define _DEV_XILINX_AXIDMA_H_
+#define	AXI_DMACR(n)		(0x00 + 0x30 * (n)) /* DMA Control register */
+#define	 DMACR_RS		(1 << 0) /* Run / Stop. */
+#define	 DMACR_RESET		(1 << 2) /* Soft reset the AXI DMA core. */
+#define	 DMACR_IOC_IRQEN	(1 << 12) /* Interrupt on Complete (IOC) Interrupt Enable. */
+#define	 DMACR_DLY_IRQEN	(1 << 13) /* Interrupt on Delay Timer Interrupt Enable. */
+#define	 DMACR_ERR_IRQEN	(1 << 14) /* Interrupt on Error Interrupt Enable. */
+#define	AXI_DMASR(n)		(0x04 + 0x30 * (n)) /* DMA Status register */
+#define	 DMASR_HALTED		(1 << 0)
+#define	 DMASR_IDLE		(1 << 1)
+#define	 DMASR_SGINCLD		(1 << 3) /* Scatter Gather Enabled */
+#define	 DMASR_DMAINTERR	(1 << 4) /* DMA Internal Error. */
+#define	 DMASR_DMASLVERR	(1 << 5) /* DMA Slave Error. */
+#define	 DMASR_DMADECOREERR	(1 << 6) /* Decode Error. */
+#define	 DMASR_SGINTERR		(1 << 8) /* Scatter Gather Internal Error. */
+#define	 DMASR_SGSLVERR		(1 << 9) /* Scatter Gather Slave Error. */
+#define	 DMASR_SGDECERR		(1 << 10) /* Scatter Gather Decode Error. */
+#define	 DMASR_IOC_IRQ		(1 << 12) /* Interrupt on Complete. */
+#define	 DMASR_DLY_IRQ		(1 << 13) /* Interrupt on Delay. */
+#define	 DMASR_ERR_IRQ		(1 << 14) /* Interrupt on Error. */
+#define	AXI_CURDESC(n)		(0x08 + 0x30 * (n)) /* Current Descriptor Pointer. Lower 32 bits of the address. */
+#define	AXI_CURDESC_MSB(n)	(0x0C + 0x30 * (n)) /* Current Descriptor Pointer. Upper 32 bits of address. */
+#define	AXI_TAILDESC(n)		(0x10 + 0x30 * (n)) /* Tail Descriptor Pointer. Lower 32 bits. */
+#define	AXI_TAILDESC_MSB(n)	(0x14 + 0x30 * (n)) /* Tail Descriptor Pointer. Upper 32 bits of address. */
+#define	AXI_SG_CTL		0x2C /* Scatter/Gather User and Cache */
+#define	READ4(_sc, _reg)	\
+	bus_space_read_4(_sc->bst, _sc->bsh, _reg)
+#define	WRITE4(_sc, _reg, _val)	\
+	bus_space_write_4(_sc->bst, _sc->bsh, _reg, _val)
+#define	READ8(_sc, _reg)	\
+	bus_space_read_8(_sc->bst, _sc->bsh, _reg)
+#define	WRITE8(_sc, _reg, _val)	\
+	bus_space_write_8(_sc->bst, _sc->bsh, _reg, _val)
+struct axidma_desc {
+	uint32_t next;
+	uint32_t reserved1;
+	uint32_t phys;
+	uint32_t reserved2;
+	uint32_t reserved3;
+	uint32_t reserved4;
+	uint32_t control;
+#define	BD_CONTROL_TXSOF	(1 << 27) /* Start of Frame. */
+#define	BD_CONTROL_TXEOF	(1 << 26) /* End of Frame. */
+#define	BD_CONTROL_LEN_S	0	/* Buffer Length. */
+#define	BD_CONTROL_LEN_M	(0x3ffffff << BD_CONTROL_LEN_S)
+	uint32_t status;
+#define	BD_STATUS_CMPLT		(1 << 31)
+#define	BD_STATUS_TRANSFERRED_S	0
+#define	BD_STATUS_TRANSFERRED_M	(0x7fffff << BD_STATUS_TRANSFERRED_S)
+	uint32_t app0;
+	uint32_t app1;
+	uint32_t app2;
+	uint32_t app3;
+	uint32_t app4;
+	uint32_t reserved[3];
+#endif /* !_DEV_XILINX_AXIDMA_H_ */
diff --git a/freebsd/sys/dev/xilinx/if_xae.c b/freebsd/sys/dev/xilinx/if_xae.c
index 00000000..0582a588
--- /dev/null
+++ b/freebsd/sys/dev/xilinx/if_xae.c
@@ -0,0 +1,1111 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/mutex.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <net/bpf.h>
+#include <net/if.h>
+#include <net/ethernet.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include <dev/mii/tiphy.h>
+#include <dev/xilinx/if_xaereg.h>
+#include <dev/xilinx/if_xaevar.h>
+#include <rtems/bsd/local/miibus_if.h>
+	bus_read_4((_sc)->res[0], _reg)
+	bus_write_4((_sc)->res[0], _reg, _val)
+	bus_read_8((_sc)->res[0], _reg)
+	bus_write_8((_sc)->res[0], _reg, _val)
+#define	XAE_LOCK(sc)			mtx_lock(&(sc)->mtx)
+#define	XAE_UNLOCK(sc)			mtx_unlock(&(sc)->mtx)
+#define	XAE_ASSERT_LOCKED(sc)		mtx_assert(&(sc)->mtx, MA_OWNED)
+#define	XAE_ASSERT_UNLOCKED(sc)		mtx_assert(&(sc)->mtx, MA_NOTOWNED)
+#define XAE_DEBUG
+#undef XAE_DEBUG
+#ifdef __rtems__
+#define DEBUG_MII
+#undef DEBUG_MII
+#endif
+#ifdef XAE_DEBUG
+#else
+#endif
+#define	RX_QUEUE_SIZE		64
+#define	TX_QUEUE_SIZE		64
+#define	NUM_RX_MBUF		16
+#define	BUFRING_SIZE		8192
+#define	MDIO_CLK_DIV_DEFAULT	29
+#define	PHY1_RD(sc, _r)		\
+	xae_miibus_read_reg(sc->dev, 1, _r)
+#define	PHY1_WR(sc, _r, _v)	\
+	xae_miibus_write_reg(sc->dev, 1, _r, _v)
+#define	PHY_RD(sc, _r)		\
+	xae_miibus_read_reg(sc->dev, sc->phy_addr, _r)
+#define	PHY_WR(sc, _r, _v)	\
+	xae_miibus_write_reg(sc->dev, sc->phy_addr, _r, _v)
+/* Use this macro to access regs > 0x1f */
+#define WRITE_TI_EREG(sc, reg, data) {					\
+	PHY_WR(sc, MII_MMDACR, MMDACR_DADDRMASK);			\
+	PHY_WR(sc, MII_MMDAADR, reg);					\
+	PHY_WR(sc, MII_MMDACR, MMDACR_DADDRMASK | MMDACR_FN_DATANPI);	\
+	PHY_WR(sc, MII_MMDAADR, data);					\
+/* Not documented, Xilinx VCU118 workaround */
+#define	 CFG4_SGMII_TMR			0x160 /* bits 8:7 MUST be '10' */
+#define	DP83867_SGMIICTL1		0xD3 /* not documented register */
+#define	 SGMIICTL1_SGMII_6W		(1 << 14) /* no idea what it is */
+static struct resource_spec xae_spec[] = {
+	{ -1, 0 }
+static void xae_stop_locked(struct xae_softc *sc);
+static void xae_setup_rxfilter(struct xae_softc *sc);
+static int
+xae_rx_enqueue(struct xae_softc *sc, uint32_t n)
+	struct mbuf *m;
+	int i;
+	for (i = 0; i < n; i++) {
+		m = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+		if (m == NULL) {
+			    "%s: Can't alloc rx mbuf\n", __func__);
+			return (-1);
+		m->m_pkthdr.len = m->m_len = m->m_ext.ext_size;
+		xdma_enqueue_mbuf(sc->xchan_rx, &m, 0, 4, 4, XDMA_DEV_TO_MEM);
+	return (0);
+static int
+xae_get_phyaddr(phandle_t node, int *phy_addr)
+	phandle_t phy_node;
+	pcell_t phy_handle, phy_reg;
+	if (OF_getencprop(node, "phy-handle", (void *)&phy_handle,
+	    sizeof(phy_handle)) <= 0)
+		return (ENXIO);
+	phy_node = OF_node_from_xref(phy_handle);
+	if (OF_getencprop(phy_node, "reg", (void *)&phy_reg,
+	    sizeof(phy_reg)) <= 0)
+		return (ENXIO);
+	*phy_addr = phy_reg;
+	return (0);
+static int
+xae_xdma_tx_intr(void *arg, xdma_transfer_status_t *status)
+	struct xae_softc *sc;
+	struct ifnet *ifp;
+	struct mbuf *m;
+	int err;
+#ifdef __rtems__
+#endif
+	sc = arg;
+	XAE_LOCK(sc);
+	ifp = sc->ifp;
+	for (;;) {
+		err = xdma_dequeue_mbuf(sc->xchan_tx, &m, &st);
+		if (err != 0) {
+			break;
+		if (st.error != 0) {
+			if_inc_counter(ifp, IFCOUNTER_OERRORS, 1);
+		m_freem(m);
+	ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+	XAE_UNLOCK(sc);
+	return (0);
+static int
+xae_xdma_rx_intr(void *arg, xdma_transfer_status_t *status)
+	struct mbuf *m;
+	int err;
+	uint32_t cnt_processed;
+	sc = arg;
+	XAE_LOCK(sc);
+	ifp = sc->ifp;
+	cnt_processed = 0;
+	for (;;) {
+		err = xdma_dequeue_mbuf(sc->xchan_rx, &m, &st);
+		if (err != 0) {
+			break;
+		cnt_processed++;
+			if_inc_counter(ifp, IFCOUNTER_IERRORS, 1);
+			m_freem(m);
+			continue;
+		m->m_pkthdr.len = m->m_len = st.transferred;
+		m->m_pkthdr.rcvif = ifp;
+		XAE_UNLOCK(sc);
+		(*ifp->if_input)(ifp, m);
+		XAE_LOCK(sc);
+	xae_rx_enqueue(sc, cnt_processed);
+	XAE_UNLOCK(sc);
+	return (0);
+static void
+xae_qflush(struct ifnet *ifp)
+	sc = ifp->if_softc;
+static int
+xae_transmit_locked(struct ifnet *ifp)
+	struct mbuf *m;
+	struct buf_ring *br;
+	int error;
+	int enq;
+	br = sc->br;
+	enq = 0;
+	while ((m = drbr_peek(ifp, br)) != NULL) {
+		error = xdma_enqueue_mbuf(sc->xchan_tx,
+		    &m, 0, 4, 4, XDMA_MEM_TO_DEV);
+		if (error != 0) {
+			/* No space in request queue available yet. */
+			drbr_putback(ifp, br, m);
+			break;
+		drbr_advance(ifp, br);
+		enq++;
+		/* If anyone is interested give them a copy. */
+		ETHER_BPF_MTAP(ifp, m);
+	if (enq > 0)
+		xdma_queue_submit(sc->xchan_tx);
+	return (0);
+static int
+xae_transmit(struct ifnet *ifp, struct mbuf *m)
+	int error;
+	XAE_LOCK(sc);
+	error = drbr_enqueue(ifp, sc->br, m);
+	if (error) {
+		XAE_UNLOCK(sc);
+		return (error);
+	if ((ifp->if_drv_flags & (IFF_DRV_RUNNING | IFF_DRV_OACTIVE)) !=
+	    IFF_DRV_RUNNING) {
+		XAE_UNLOCK(sc);
+		return (0);
+	if (!sc->link_is_up) {
+		XAE_UNLOCK(sc);
+		return (0);
+	error = xae_transmit_locked(ifp);
+	XAE_UNLOCK(sc);
+	return (error);
+static void
+xae_stop_locked(struct xae_softc *sc)
+	uint32_t reg;
+	XAE_ASSERT_LOCKED(sc);
+	ifp = sc->ifp;
+	ifp->if_drv_flags &= ~(IFF_DRV_RUNNING | IFF_DRV_OACTIVE);
+	callout_stop(&sc->xae_callout);
+	/* Stop the transmitter */
+	reg = READ4(sc, XAE_TC);
+	reg &= ~TC_TX;
+	WRITE4(sc, XAE_TC, reg);
+	/* Stop the receiver. */
+	reg = READ4(sc, XAE_RCW1);
+	reg &= ~RCW1_RX;
+	WRITE4(sc, XAE_RCW1, reg);
+static uint64_t
+xae_stat(struct xae_softc *sc, int counter_id)
+	uint64_t new, old;
+	uint64_t delta;
+	KASSERT(counter_id < XAE_MAX_COUNTERS,
+		("counter %d is out of range", counter_id));
+	new = READ8(sc, XAE_STATCNT(counter_id));
+	old = sc->counters[counter_id];
+	if (new >= old)
+		delta = new - old;
+	else
+		delta = UINT64_MAX - old + new;
+	sc->counters[counter_id] = new;
+	return (delta);
+static void
+xae_harvest_stats(struct xae_softc *sc)
+	ifp = sc->ifp;
+	if_inc_counter(ifp, IFCOUNTER_IPACKETS, xae_stat(sc, RX_GOOD_FRAMES));
+	if_inc_counter(ifp, IFCOUNTER_IMCASTS, xae_stat(sc, RX_GOOD_MCASTS));
+	    xae_stat(sc, RX_FRAME_CHECK_SEQ_ERROR) +
+	    xae_stat(sc, RX_LEN_OUT_OF_RANGE) +
+	    xae_stat(sc, RX_ALIGNMENT_ERRORS));
+	if_inc_counter(ifp, IFCOUNTER_OBYTES, xae_stat(sc, TX_BYTES));
+	if_inc_counter(ifp, IFCOUNTER_OPACKETS, xae_stat(sc, TX_GOOD_FRAMES));
+	if_inc_counter(ifp, IFCOUNTER_OMCASTS, xae_stat(sc, TX_GOOD_MCASTS));
+	    xae_stat(sc, TX_GOOD_UNDERRUN_ERRORS));
+	if_inc_counter(ifp, IFCOUNTER_COLLISIONS,
+	    xae_stat(sc, TX_SINGLE_COLLISION_FRAMES) +
+	    xae_stat(sc, TX_MULTI_COLLISION_FRAMES) +
+	    xae_stat(sc, TX_LATE_COLLISIONS) +
+	    xae_stat(sc, TX_EXCESS_COLLISIONS));
+static void
+xae_tick(void *arg)
+	int link_was_up;
+	sc = arg;
+	ifp = sc->ifp;
+	if (!(ifp->if_drv_flags & IFF_DRV_RUNNING))
+		return;
+	/* Gather stats from hardware counters. */
+	xae_harvest_stats(sc);
+	/* Check the media status. */
+	link_was_up = sc->link_is_up;
+	mii_tick(sc->mii_softc);
+	if (sc->link_is_up && !link_was_up)
+		xae_transmit_locked(sc->ifp);
+	/* Schedule another check one second from now. */
+	callout_reset(&sc->xae_callout, hz, xae_tick, sc);
+static void
+xae_init_locked(struct xae_softc *sc)
+	ifp = sc->ifp;
+	if (ifp->if_drv_flags & IFF_DRV_RUNNING)
+		return;
+	ifp->if_drv_flags |= IFF_DRV_RUNNING;
+	xae_setup_rxfilter(sc);
+	/* Enable the transmitter */
+	WRITE4(sc, XAE_TC, TC_TX);
+	/* Enable the receiver. */
+	WRITE4(sc, XAE_RCW1, RCW1_RX);
+	 * Call mii_mediachg() which will call back into xae_miibus_statchg()
+	 * to set up the remaining config registers based on current media.
+	mii_mediachg(sc->mii_softc);
+static void
+xae_init(void *arg)
+	sc = arg;
+	XAE_LOCK(sc);
+	xae_init_locked(sc);
+	XAE_UNLOCK(sc);
+static void
+xae_media_status(struct ifnet * ifp, struct ifmediareq *ifmr)
+	struct mii_data *mii;
+	mii = sc->mii_softc;
+	XAE_LOCK(sc);
+	mii_pollstat(mii);
+	ifmr->ifm_active = mii->mii_media_active;
+	ifmr->ifm_status = mii->mii_media_status;
+	XAE_UNLOCK(sc);
+static int
+xae_media_change_locked(struct xae_softc *sc)
+	return (mii_mediachg(sc->mii_softc));
+static int
+xae_media_change(struct ifnet * ifp)
+	int error;
+	XAE_LOCK(sc);
+	error = xae_media_change_locked(sc);
+	XAE_UNLOCK(sc);
+	return (error);
+static void
+xae_setup_rxfilter(struct xae_softc *sc)
+	struct ifmultiaddr *ifma;
+	uint32_t reg;
+	uint8_t *ma;
+	int i;
+#ifdef __rtems__
+#endif
+	ifp = sc->ifp;
+	 * Set the multicast (group) filter hash.
+	if ((ifp->if_flags & (IFF_ALLMULTI | IFF_PROMISC)) != 0) {
+		reg = READ4(sc, XAE_FFC);
+		reg |= FFC_PM;
+		WRITE4(sc, XAE_FFC, reg);
+	} else {
+		reg &= ~FFC_PM;
+		if_maddr_rlock(ifp);
+		i = 0;
+		CK_STAILQ_FOREACH(ifma, &sc->ifp->if_multiaddrs, ifma_link) {
+			if (ifma->ifma_addr->sa_family != AF_LINK)
+				continue;
+			if (i >= XAE_MULTICAST_TABLE_SIZE)
+				break;
+			ma = LLADDR((struct sockaddr_dl *)ifma->ifma_addr);
+			reg = READ4(sc, XAE_FFC) & 0xffffff00;
+			reg |= i++;
+			reg = (ma[0]);
+			reg |= (ma[1] << 8);
+			reg |= (ma[2] << 16);
+			reg |= (ma[3] << 24);
+			WRITE4(sc, XAE_FFV(0), reg);
+			reg = ma[4];
+			reg |= ma[5] << 8;
+			WRITE4(sc, XAE_FFV(1), reg);
+		if_maddr_runlock(ifp);
+	 * Set the primary address.
+	reg = sc->macaddr[0];
+	reg |= (sc->macaddr[1] << 8);
+	reg |= (sc->macaddr[2] << 16);
+	reg |= (sc->macaddr[3] << 24);
+	WRITE4(sc, XAE_UAW0, reg);
+	reg = sc->macaddr[4];
+	reg |= (sc->macaddr[5] << 8);
+	WRITE4(sc, XAE_UAW1, reg);
+static int
+xae_ioctl(struct ifnet *ifp, u_long cmd, caddr_t data)
+	struct ifreq *ifr;
+	int mask, error;
+	ifr = (struct ifreq *)data;
+	error = 0;
+	switch (cmd) {
+	case SIOCSIFFLAGS:
+		XAE_LOCK(sc);
+		if (ifp->if_flags & IFF_UP) {
+			if (ifp->if_drv_flags & IFF_DRV_RUNNING) {
+				if ((ifp->if_flags ^ sc->if_flags) &
+				    (IFF_PROMISC | IFF_ALLMULTI))
+			} else {
+				if (!sc->is_detaching)
+		} else {
+				xae_stop_locked(sc);
+		sc->if_flags = ifp->if_flags;
+		XAE_UNLOCK(sc);
+		break;
+	case SIOCADDMULTI:
+	case SIOCDELMULTI:
+			XAE_LOCK(sc);
+			XAE_UNLOCK(sc);
+		break;
+	case SIOCSIFMEDIA:
+	case SIOCGIFMEDIA:
+		error = ifmedia_ioctl(ifp, ifr, &mii->mii_media, cmd);
+		break;
+	case SIOCSIFCAP:
+		mask = ifp->if_capenable ^ ifr->ifr_reqcap;
+		if (mask & IFCAP_VLAN_MTU) {
+			/* No work to do except acknowledge the change took */
+			ifp->if_capenable ^= IFCAP_VLAN_MTU;
+		break;
+	default:
+		error = ether_ioctl(ifp, cmd, data);
+		break;
+	return (error);
+static void
+xae_intr(void *arg)
+static int
+xae_get_hwaddr(struct xae_softc *sc, uint8_t *hwaddr)
+	phandle_t node;
+	int len;
+	node = ofw_bus_get_node(sc->dev);
+	/* Check if there is property */
+	if ((len = OF_getproplen(node, "local-mac-address")) <= 0)
+		return (EINVAL);
+	if (len != ETHER_ADDR_LEN)
+		return (EINVAL);
+	OF_getprop(node, "local-mac-address", hwaddr,
+	    ETHER_ADDR_LEN);
+	return (0);
+static int
+mdio_wait(struct xae_softc *sc)
+	uint32_t reg;
+	int timeout;
+	timeout = 200;
+	do {
+		reg = READ4(sc, XAE_MDIO_CTRL);
+		if (reg & MDIO_CTRL_READY)
+			break;
+		DELAY(1);
+	if (timeout <= 0) {
+		printf("Failed to get MDIO ready\n");
+		return (1);
+	return (0);
+static int
+xae_miibus_read_reg(device_t dev, int phy, int reg)
+	uint32_t mii;
+	int rv;
+	if (mdio_wait(sc))
+		return (0);
+	mii = MDIO_CTRL_TX_OP_READ | MDIO_CTRL_INITIATE;
+	mii |= (reg << MDIO_TX_REGAD_S);
+	mii |= (phy << MDIO_TX_PHYAD_S);
+	WRITE4(sc, XAE_MDIO_CTRL, mii);
+		return (0);
+	rv = READ4(sc, XAE_MDIO_READ);
+#if defined(__rtems__) && defined(DEBUG_MII)
+	dprintf("%s: reg: %d phy %d val 0x%x\n", __func__, reg, phy, rv);
+#endif
+	return (rv);
+static int
+xae_miibus_write_reg(device_t dev, int phy, int reg, int val)
+	uint32_t mii;
+		return (1);
+	mii = MDIO_CTRL_TX_OP_WRITE | MDIO_CTRL_INITIATE;
+	WRITE4(sc, XAE_MDIO_WRITE, val);
+		return (1);
+	dprintf("%s: reg: %d phy %d val 0x%x\n", __func__, reg, phy, val);
+#endif
+	return (0);
+static void
+xae_phy_fixup(struct xae_softc *sc)
+	uint32_t reg;
+	device_t dev;
+	dev = sc->dev;
+	do {
+		WRITE_TI_EREG(sc, DP83867_SGMIICTL1, SGMIICTL1_SGMII_6W);
+		PHY_WR(sc, DP83867_PHYCR, PHYCR_SGMII_EN);
+		reg = PHY_RD(sc, DP83867_CFG2);
+		reg &= ~CFG2_SPEED_OPT_ATTEMPT_CNT_M;
+		reg |= (CFG2_SPEED_OPT_ATTEMPT_CNT_4);
+		reg |= CFG2_INTERRUPT_POLARITY;
+		reg |= CFG2_SPEED_OPT_ENHANCED_EN;
+		reg |= CFG2_SPEED_OPT_10M_EN;
+		PHY_WR(sc, DP83867_CFG2, reg);
+		WRITE_TI_EREG(sc, DP83867_CFG4, CFG4_SGMII_TMR);
+		PHY_WR(sc, MII_BMCR,
+		    BMCR_AUTOEN | BMCR_FDX | BMCR_SPEED1 | BMCR_RESET);
+	} while (PHY1_RD(sc, MII_BMCR) == 0x0ffff);
+	do {
+		PHY1_WR(sc, MII_BMCR,
+		    BMCR_AUTOEN | BMCR_FDX | BMCR_SPEED1 | BMCR_STARTNEG);
+		DELAY(40000);
+	} while ((PHY1_RD(sc, MII_BMSR) & BMSR_ACOMP) == 0);
+static int
+setup_xdma(struct xae_softc *sc)
+	device_t dev;
+	vmem_t *vmem;
+	int error;
+	dev = sc->dev;
+	/* Get xDMA controller */
+	sc->xdma_tx = xdma_ofw_get(sc->dev, "tx");
+	if (sc->xdma_tx == NULL) {
+		device_printf(dev, "Could not find DMA controller.\n");
+		return (ENXIO);
+	sc->xdma_rx = xdma_ofw_get(sc->dev, "rx");
+	if (sc->xdma_rx == NULL) {
+		return (ENXIO);
+	/* Alloc xDMA TX virtual channel. */
+	sc->xchan_tx = xdma_channel_alloc(sc->xdma_tx, 0);
+	if (sc->xchan_tx == NULL) {
+		device_printf(dev, "Can't alloc virtual DMA TX channel.\n");
+		return (ENXIO);
+	/* Setup interrupt handler. */
+	error = xdma_setup_intr(sc->xchan_tx,
+	    xae_xdma_tx_intr, sc, &sc->ih_tx);
+	if (error) {
+		    "Can't setup xDMA TX interrupt handler.\n");
+		return (ENXIO);
+	/* Alloc xDMA RX virtual channel. */
+	sc->xchan_rx = xdma_channel_alloc(sc->xdma_rx, 0);
+	if (sc->xchan_rx == NULL) {
+		device_printf(dev, "Can't alloc virtual DMA RX channel.\n");
+		return (ENXIO);
+	error = xdma_setup_intr(sc->xchan_rx,
+	    xae_xdma_rx_intr, sc, &sc->ih_rx);
+	if (error) {
+		    "Can't setup xDMA RX interrupt handler.\n");
+		return (ENXIO);
+	/* Setup bounce buffer */
+	vmem = xdma_get_memory(dev);
+	if (vmem) {
+		xchan_set_memory(sc->xchan_tx, vmem);
+		xchan_set_memory(sc->xchan_rx, vmem);
+	xdma_prep_sg(sc->xchan_tx,
+	    TX_QUEUE_SIZE,	/* xchan requests queue size */
+	    MCLBYTES,	/* maxsegsize */
+	    8,		/* maxnsegs */
+	    16,		/* alignment */
+	    0,		/* boundary */
+	    BUS_SPACE_MAXADDR_32BIT,
+	    BUS_SPACE_MAXADDR);
+	xdma_prep_sg(sc->xchan_rx,
+	    RX_QUEUE_SIZE,	/* xchan requests queue size */
+	    1,		/* maxnsegs */
+	    0,		/* boundary */
+	return (0);
+static int
+xae_probe(device_t dev)
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "xlnx,axi-ethernet-1.00.a"))
+		return (ENXIO);
+	device_set_desc(dev, "Xilinx AXI Ethernet");
+#define XAE_RAF_NEWFNCENBL_MASK  	0x00000800 /**< New function mode */
+static int
+xae_attach(device_t dev)
+	phandle_t node;
+	uint32_t reg;
+	int error;
+        bool removeme;
+	sc->dev = dev;
+	if (setup_xdma(sc) != 0) {
+		device_printf(dev, "Could not setup xDMA.\n");
+		return (ENXIO);
+	mtx_init(&sc->mtx, device_get_nameunit(sc->dev),
+	    MTX_NETWORK_LOCK, MTX_DEF);
+	sc->br = buf_ring_alloc(BUFRING_SIZE, M_DEVBUF,
+	    M_NOWAIT, &sc->mtx);
+	if (sc->br == NULL)
+		return (ENOMEM);
+	if (bus_alloc_resources(dev, xae_spec, sc->res)) {
+		device_printf(dev, "could not allocate resources\n");
+		return (ENXIO);
+	/* Memory interface */
+	device_printf(sc->dev, "Identification: %x\n",
+	    READ4(sc, XAE_IDENT));
+	/* Get MAC addr */
+	if (xae_get_hwaddr(sc, sc->macaddr)) {
+		device_printf(sc->dev, "can't get mac\n");
+		return (ENXIO);
+	/* Enable MII clock */
+	reg = (MDIO_CLK_DIV_DEFAULT << MDIO_SETUP_CLK_DIV_S);
+	reg |= MDIO_SETUP_ENABLE;
+	WRITE4(sc, XAE_MDIO_SETUP, reg);
+		return (ENXIO);
+	callout_init_mtx(&sc->xae_callout, &sc->mtx, 0);
+	error = bus_setup_intr(dev, sc->res[1], INTR_TYPE_NET | INTR_MPSAFE,
+	    NULL, xae_intr, sc, &sc->intr_cookie);
+	if (error != 0) {
+		device_printf(dev, "could not setup interrupt handler.\n");
+		return (ENXIO);
+	/* Set up the ethernet interface. */
+	sc->ifp = ifp = if_alloc(IFT_ETHER);
+	if (ifp == NULL) {
+		device_printf(dev, "could not allocate ifp.\n");
+		return (ENXIO);
+	ifp->if_softc = sc;
+	if_initname(ifp, device_get_name(dev), device_get_unit(dev));
+	ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX | IFF_MULTICAST;
+	ifp->if_capabilities = IFCAP_VLAN_MTU;
+	ifp->if_capenable = ifp->if_capabilities;
+	ifp->if_transmit = xae_transmit;
+	ifp->if_qflush = xae_qflush;
+	ifp->if_ioctl = xae_ioctl;
+	ifp->if_init = xae_init;
+	IFQ_SET_MAXLEN(&ifp->if_snd, TX_DESC_COUNT - 1);
+	ifp->if_snd.ifq_drv_maxlen = TX_DESC_COUNT - 1;
+	IFQ_SET_READY(&ifp->if_snd);
+	if (xae_get_phyaddr(node, &sc->phy_addr) != 0)
+		return (ENXIO);
+	/* Attach the mii driver. */
+	error = mii_attach(dev, &sc->miibus, ifp, xae_media_change,
+	    xae_media_status, BMSR_DEFCAPMASK, sc->phy_addr,
+	    MII_OFFSET_ANY, 0);
+	if (error != 0) {
+		device_printf(dev, "PHY attach failed\n");
+		return (ENXIO);
+	sc->mii_softc = device_get_softc(sc->miibus);
+	/* Apply vcu118 workaround. */
+	// if (OF_getproplen(node, "xlnx,vcu118") >= 0)
+		xae_phy_fixup(sc);
+	/* All ready to run, attach the ethernet interface. */
+	ether_ifattach(ifp, sc->macaddr);
+	sc->is_attached = true;
+	xae_rx_enqueue(sc, NUM_RX_MBUF);
+	xdma_queue_submit(sc->xchan_rx);
+	return (0);
+static int
+xae_detach(device_t dev)
+	KASSERT(mtx_initialized(&sc->mtx), ("%s: mutex not initialized",
+	    device_get_nameunit(dev)));
+	ifp = sc->ifp;
+	/* Only cleanup if attach succeeded. */
+	if (device_is_attached(dev)) {
+		XAE_LOCK(sc);
+		XAE_UNLOCK(sc);
+		callout_drain(&sc->xae_callout);
+		ether_ifdetach(ifp);
+	if (sc->miibus != NULL)
+		device_delete_child(dev, sc->miibus);
+	if (ifp != NULL)
+		if_free(ifp);
+	mtx_destroy(&sc->mtx);
+	bus_teardown_intr(dev, sc->res[1], sc->intr_cookie);
+	bus_release_resources(dev, xae_spec, sc->res);
+	xdma_channel_free(sc->xchan_tx);
+	xdma_channel_free(sc->xchan_rx);
+	xdma_put(sc->xdma_tx);
+	xdma_put(sc->xdma_rx);
+	return (0);
+static void
+xae_miibus_statchg(device_t dev)
+	uint32_t reg;
+	 * Called by the MII bus driver when the PHY establishes
+	 * link to set the MAC interface registers.
+	if (mii->mii_media_status & IFM_ACTIVE)
+		sc->link_is_up = true;
+	else
+		sc->link_is_up = false;
+	switch (IFM_SUBTYPE(mii->mii_media_active)) {
+	case IFM_1000_T:
+	case IFM_1000_SX:
+		reg = SPEED_1000;
+		break;
+	case IFM_100_TX:
+		reg = SPEED_100;
+		break;
+	case IFM_10_T:
+		reg = SPEED_10;
+		break;
+	case IFM_NONE:
+		return;
+	default:
+		device_printf(dev, "Unsupported media %u\n",
+		    IFM_SUBTYPE(mii->mii_media_active));
+		return;
+	WRITE4(sc, XAE_SPEED, reg);
+static device_method_t xae_methods[] = {
+	DEVMETHOD(device_probe,		xae_probe),
+	DEVMETHOD(device_attach,	xae_attach),
+	DEVMETHOD(device_detach,	xae_detach),
+	/* MII Interface */
+	DEVMETHOD(miibus_readreg,	xae_miibus_read_reg),
+	DEVMETHOD(miibus_writereg,	xae_miibus_write_reg),
+	DEVMETHOD(miibus_statchg,	xae_miibus_statchg),
+	{ 0, 0 }
+driver_t xae_driver = {
+	"xae",
+	xae_methods,
+	sizeof(struct xae_softc),
+static devclass_t xae_devclass;
+DRIVER_MODULE(xae, simplebus, xae_driver, xae_devclass, 0, 0);
+DRIVER_MODULE(miibus, xae, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(xae, ether, 1, 1, 1);
+MODULE_DEPEND(xae, miibus, 1, 1, 1);
diff --git a/freebsd/sys/dev/xilinx/if_xaereg.h b/freebsd/sys/dev/xilinx/if_xaereg.h
new file mode 100644
index 00000000..1c4f0493
--- /dev/null
+++ b/freebsd/sys/dev/xilinx/if_xaereg.h
@@ -0,0 +1,122 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (c) 2019 Ruslan Bukin <br at bsdpad.com>
+ * This software was developed by SRI International and the University of
+ * Cambridge Computer Laboratory (Department of Computer Science and
+ * Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of the
+ * DARPA SSITH research programme.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_XILINX_IF_XAE_H_
+#define _DEV_XILINX_IF_XAE_H_
+#define	XAE_RAF		0x00000 /* Reset and Address Filter RW */
+#define	XAE_TPF		0x00004 /* Transmit Pause Frame RW */
+#define	XAE_IFGP	0x00008 /* Transmit Inter Frame Gap Adjustment RW */
+#define	XAE_IS		0x0000C /* Interrupt Status register RW */
+#define	XAE_IP		0x00010 /* Interrupt Pending register RO */
+#define	XAE_IE		0x00014 /* Interrupt Enable register RW */
+#define	XAE_TTAG	0x00018 /* Transmit VLAN Tag RW */
+#define	XAE_RTAG	0x0001C /* Receive VLAN Tag  RW */
+#define	XAE_UAWL	0x00020 /* Unicast Address Word Lower RW */
+#define	XAE_UAWU	0x00024 /* Unicast Address Word Upper RW */
+#define	XAE_TPID0	0x00028 /* VLAN TPID Word 0 RW */
+#define	XAE_TPID1	0x0002C /* VLAN TPID Word 1 RW */
+#define	XAE_PPST	0x00030 /* PCS PMA Status register RO */
+#define	XAE_STATCNT(n)	(0x00200 + 0x8 * (n)) /* Statistics Counters RO */
+#define	XAE_RCW0	0x00400 /* Receive Configuration Word 0 Register RW */
+#define	XAE_RCW1	0x00404 /* Receive Configuration Word 1 Register RW */
+#define	 RCW1_RX	(1 << 28) /* Receive Enable */
+#define	XAE_TC		0x00408 /* Transmitter Configuration register RW */
+#define	 TC_TX		(1 << 28) /* Transmit Enable */
+#define	XAE_FCC		0x0040C /* Flow Control Configuration register RW */
+#define	 FCC_FCRX	(1 << 29) /* Flow Control Enable (RX) */
+#define	XAE_SPEED	0x00410 /* MAC Speed Configuration Word RW */
+#define	 SPEED_CONF_S	30
+#define	 SPEED_10	(0 << SPEED_CONF_S)
+#define	 SPEED_100	(1 << SPEED_CONF_S)
+#define	 SPEED_1000	(2 << SPEED_CONF_S)
+#define	XAE_RX_MAXFRAME	0x00414 /* RX Max Frame Configuration RW */
+#define	XAE_TX_MAXFRAME	0x00418 /* TX Max Frame Configuration RW */
+#define	XAE_TX_TIMESTMP	0x0041C /* TX timestamp adjust control register RW */
+#define	XAE_IDENT	0x004F8 /* Identification register RO */
+#define	XAE_ABILITY	0x004FC /* Ability register RO */
+#define	XAE_MDIO_SETUP	0x00500 /* MDIO Setup register RW */
+#define	 MDIO_SETUP_ENABLE	(1 << 6) /* MDIO Enable */
+#define	 MDIO_SETUP_CLK_DIV_S	0 /* Clock Divide */
+#define	XAE_MDIO_CTRL	0x00504 /* MDIO Control RW */
+#define	 MDIO_TX_REGAD_S	16 /* This controls the register address being accessed. */
+#define	 MDIO_TX_REGAD_M	(0x1f << MDIO_TX_REGAD_S)
+#define	 MDIO_TX_PHYAD_S	24 /* This controls the PHY address being accessed. */
+#define	 MDIO_TX_PHYAD_M	(0x1f << MDIO_TX_PHYAD_S)
+#define	 MDIO_CTRL_TX_OP_S	14 /* Type of access performed. */
+#define	 MDIO_CTRL_TX_OP_M	(0x3 << MDIO_CTRL_TX_OP_S)
+#define	 MDIO_CTRL_TX_OP_READ	(0x2 << MDIO_CTRL_TX_OP_S)
+#define	 MDIO_CTRL_TX_OP_WRITE	(0x1 << MDIO_CTRL_TX_OP_S)
+#define	 MDIO_CTRL_INITIATE	(1 << 11) /* Start an MDIO transfer. */
+#define	 MDIO_CTRL_READY	(1 << 7) /* MDIO is ready for a new xfer */
+#define	XAE_MDIO_WRITE	0x00508 /* MDIO Write Data RW */
+#define	XAE_MDIO_READ	0x0050C /* MDIO Read Data RO */
+#define	XAE_INT_STATUS	0x00600 /* Interrupt Status Register RW */
+#define	XAE_INT_PEND	0x00610 /* Interrupt Pending Register RO */
+#define	XAE_INT_ENABLE	0x00620 /* Interrupt Enable Register RW */
+#define	XAE_INT_CLEAR	0x00630 /* Interrupt Clear Register RW */
+#define	XAE_UAW0	0x00700 /* Unicast Address Word 0 register (UAW0) RW */
+#define	XAE_UAW1	0x00704 /* Unicast Address Word 1 register (UAW1) RW */
+#define	XAE_FFC		0x00708 /* Frame Filter Control RW */
+#define	 FFC_PM		(1 << 31) /* Promiscuous Mode */
+#define	XAE_FFV(n)	(0x00710 + 0x4 * (n)) /* Frame Filter Value RW */
+#define	XAE_FFMV(n)	(0x00750 + 0x4 * (n)) /* Frame Filter Mask Value RW */
+#define	XAE_TX_VLAN(n)	(0x04000 + 0x4 * (n)) /* Transmit VLAN Data Table RW */
+#define	XAE_RX_VLAN(n)	(0x08000 + 0x4 * (n)) /* Receive VLAN Data Table RW */
+#define	XAE_AVB(n)	(0x10000 + 0x4 * (n)) /* Ethernet AVB RW */
+#define	XAE_MAT(n)	(0x20000 + 0x4 * (n)) /* Multicast Address Table RW */
+#define	XAE_MULTICAST_TABLE_SIZE	4
+/* RX statistical counters. */
+#define	RX_BYTES			0
+#define	RX_GOOD_FRAMES			18
+#define	RX_FRAME_CHECK_SEQ_ERROR	19
+#define	RX_GOOD_MCASTS			21
+#define	RX_LEN_OUT_OF_RANGE		23
+#define	RX_ALIGNMENT_ERRORS		40
+/* TX statistical counters. */
+#define	TX_BYTES			1
+#define	TX_GOOD_FRAMES			27
+#define	TX_GOOD_MCASTS			29
+#define	TX_GOOD_UNDERRUN_ERRORS		30
+#define	TX_SINGLE_COLLISION_FRAMES	34
+#define	TX_MULTI_COLLISION_FRAMES	35
+#define	TX_LATE_COLLISIONS		37
+#define	TX_EXCESS_COLLISIONS		38
+#define	XAE_MAX_COUNTERS		43
+#endif	/* _DEV_XILINX_IF_XAE_H_ */
diff --git a/freebsd/sys/dev/xilinx/if_xaevar.h b/freebsd/sys/dev/xilinx/if_xaevar.h
index 00000000..30396537
--- /dev/null
+++ b/freebsd/sys/dev/xilinx/if_xaevar.h
@@ -0,0 +1,80 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_DEV_XILINX_IF_XAEVAR_H_
+#define	_DEV_XILINX_IF_XAEVAR_H_
+#include <dev/xdma/xdma.h>
+ * Driver data and defines.
+#define	RX_DESC_COUNT	1024
+#define	TX_DESC_COUNT	1024
+struct xae_softc {
+	struct resource		*res[2];
+	device_t		dev;
+	uint8_t			macaddr[ETHER_ADDR_LEN];
+	device_t		miibus;
+	struct mii_data *	mii_softc;
+	int			if_flags;
+	struct mtx		mtx;
+	void *			intr_cookie;
+	struct callout		xae_callout;
+	boolean_t		link_is_up;
+	boolean_t		is_attached;
+	boolean_t		is_detaching;
+	int			phy_addr;
+	/* xDMA TX */
+	xdma_controller_t	*xdma_tx;
+	xdma_channel_t		*xchan_tx;
+	void			*ih_tx;
+	/* xDMA RX */
+	xdma_controller_t	*xdma_rx;
+	xdma_channel_t		*xchan_rx;
+	void			*ih_rx;
+	/* Counters */
+	uint64_t		counters[XAE_MAX_COUNTERS];
+#endif	/* _DEV_XILINX_IF_XAEVAR_H_ */
diff --git a/freebsd/sys/microblaze/include/machine/in_cksum.h b/freebsd/sys/microblaze/include/machine/in_cksum.h
index 00000000..fd34e13d
--- /dev/null
+++ b/freebsd/sys/microblaze/include/machine/in_cksum.h
@@ -0,0 +1,82 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1990 The Regents of the University of California.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ *	from tahoe:	in_cksum.c	1.2	86/01/05
+ *	from:		@(#)in_cksum.c	1.3 (Berkeley) 1/19/91
+ *	from: Id: in_cksum.c,v 1.8 1995/12/03 18:35:19 bde Exp
+ * $FreeBSD$
+#ifndef _MACHINE_IN_CKSUM_H_
+#define	_MACHINE_IN_CKSUM_H_	1
+#include <sys/cdefs.h>
+#define in_cksum(m, len)	in_cksum_skip(m, len, 0)
+#if defined(IPVERSION) && (IPVERSION == 4)
+ * It it useful to have an Internet checksum routine which is inlineable
+ * and optimized specifically for the task of computing IP header checksums
+ * in the normal case (where there are no options and the header length is
+ * therefore always exactly five 32-bit words.
+#ifdef __CC_SUPPORTS___INLINE
+static __inline void
+in_cksum_update(struct ip *ip)
+	int __tmpsum;
+	__tmpsum = (int)ntohs(ip->ip_sum) + 256;
+	ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));
+#else
+#define	in_cksum_update(ip) \
+	do { \
+		int __tmpsum; \
+		__tmpsum = (int)ntohs(ip->ip_sum) + 256; \
+		ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16)); \
+	} while(0)
+#endif
+#endif
+#ifdef _KERNEL
+u_int in_cksum_hdr(const struct ip *ip);
+#endif
+u_short	in_addword(u_short sum, u_short b);
+u_short	in_pseudo(u_int sum, u_int b, u_int c);
+u_short	in_cksum_skip(struct mbuf *m, int len, int skip);
+#endif
+#endif /* _MACHINE_IN_CKSUM_H_ */
diff --git a/freebsd/sys/microblaze/microblaze/in_cksum.c b/freebsd/sys/microblaze/microblaze/in_cksum.c
index 00000000..22e19d83
--- /dev/null
+++ b/freebsd/sys/microblaze/microblaze/in_cksum.c
@@ -0,0 +1,255 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 1988, 1992, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * Copyright (c) 1996
+ *	Matt Thomas <matt at 3am-software.com>
+ * are met:
+ * 3. All advertising materials mentioning features or use of this software
+ *    must display the following acknowledgement:
+ *	This product includes software developed by the University of
+ *	California, Berkeley and its contributors.
+ * 4. Neither the name of the University nor the names of its contributors
+ * SUCH DAMAGE.
+ *	@(#)in_cksum.c	8.1 (Berkeley) 6/10/93
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <netinet/in_systm.h>
+#include <netinet/in.h>
+#include <netinet/ip.h>
+#include <machine/in_cksum.h>
+ * Checksum routine for Internet Protocol family headers
+ *    (Portable Alpha version).
+ * This routine is very heavily used in the network
+ * code and should be modified for each CPU to be as fast as possible.
+#define ADDCARRY(x)  (x > 65535 ? x -= 65535 : x)
+#define REDUCE32							  \
+	q_util.q = sum;							  \
+	sum = q_util.s[0] + q_util.s[1] + q_util.s[2] + q_util.s[3];	  \
+#define REDUCE16							  \
+	q_util.q = sum;							  \
+	l_util.l = q_util.s[0] + q_util.s[1] + q_util.s[2] + q_util.s[3]; \
+	sum = l_util.s[0] + l_util.s[1];				  \
+	ADDCARRY(sum);							  \
+static const u_int32_t in_masks[] = {
+#if _BYTE_ORDER == _LITTLE_ENDIAN
+	/*0 bytes*/ /*1 byte*/	/*2 bytes*/ /*3 bytes*/
+	0x00000000, 0x000000FF, 0x0000FFFF, 0x00FFFFFF,	/* offset 0 */
+	0x00000000, 0x0000FF00, 0x00FFFF00, 0xFFFFFF00,	/* offset 1 */
+	0x00000000, 0x00FF0000, 0xFFFF0000, 0xFFFF0000,	/* offset 2 */
+	0x00000000, 0xFF000000, 0xFF000000, 0xFF000000,	/* offset 3 */
+#else
+	0x00000000, 0xFF000000, 0xFFFF0000, 0xFFFFFF00,	/* offset 0 */
+	0x00000000, 0x00FF0000, 0x00FFFF00, 0x00FFFFFF,	/* offset 1 */
+	0x00000000, 0x0000FF00, 0x0000FFFF, 0x0000FFFF,	/* offset 2 */
+	0x00000000, 0x000000FF, 0x000000FF, 0x000000FF,	/* offset 3 */
+#endif
+union l_util {
+	u_int16_t s[2];
+	u_int32_t l;
+union q_util {
+	u_int16_t s[4];
+	u_int32_t l[2];
+	u_int64_t q;
+static u_int64_t
+in_cksumdata(const void *buf, int len)
+	const u_int32_t *lw = (const u_int32_t *) buf;
+	u_int64_t sum = 0;
+	u_int64_t prefilled;
+	int offset;
+	union q_util q_util;
+	if ((3 & (long) lw) == 0 && len == 20) {
+		sum = (u_int64_t) lw[0] + lw[1] + lw[2] + lw[3] + lw[4];
+		REDUCE32;
+		return sum;
+	if ((offset = 3 & (long) lw) != 0) {
+		const u_int32_t *masks = in_masks + (offset << 2);
+		lw = (u_int32_t *) (((long) lw) - offset);
+		sum = *lw++ & masks[len >= 3 ? 3 : len];
+		len -= 4 - offset;
+		if (len <= 0) {
+			REDUCE32;
+			return sum;
+#if 0
+	 * Force to cache line boundary.
+	offset = 32 - (0x1f & (long) lw);
+	if (offset < 32 && len > offset) {
+		len -= offset;
+		if (4 & offset) {
+			sum += (u_int64_t) lw[0];
+			lw += 1;
+		if (8 & offset) {
+			sum += (u_int64_t) lw[0] + lw[1];
+			lw += 2;
+		if (16 & offset) {
+			sum += (u_int64_t) lw[0] + lw[1] + lw[2] + lw[3];
+			lw += 4;
+#endif
+	 * access prefilling to start load of next cache line.
+	 * then add current cache line
+	 * save result of prefilling for loop iteration.
+	prefilled = lw[0];
+	while ((len -= 32) >= 4) {
+		u_int64_t prefilling = lw[8];
+		sum += prefilled + lw[1] + lw[2] + lw[3]
+			+ lw[4] + lw[5] + lw[6] + lw[7];
+		lw += 8;
+		prefilled = prefilling;
+	if (len >= 0) {
+		lw += 8;
+	} else {
+		len += 32;
+	while ((len -= 16) >= 0) {
+		lw += 4;
+	len += 16;
+	while ((len -= 4) >= 0) {
+		sum += (u_int64_t) *lw++;
+	len += 4;
+	if (len > 0)
+		sum += (u_int64_t) (in_masks[len] & *lw);
+	REDUCE32;
+	return sum;
+u_short
+in_addword(u_short a, u_short b)
+	u_int64_t sum = a + b;
+	ADDCARRY(sum);
+	return (sum);
+u_short
+#ifdef __rtems__
+/* Prototype does not match in FreeBSD code */
+in_pseudo(u_int a, u_int b, u_int c)
+#else
+in_pseudo(u_int32_t a, u_int32_t b, u_int32_t c)
+#endif
+	u_int64_t sum;
+	union l_util l_util;
+	sum = (u_int64_t) a + b + c;
+	REDUCE16;
+	return (sum);
+u_short
+in_cksum_skip(struct mbuf *m, int len, int skip)
+	int mlen = 0;
+	int clen = 0;
+	caddr_t addr;
+	len -= skip;
+	for (; skip && m; m = m->m_next) {
+		if (m->m_len > skip) {
+			mlen = m->m_len - skip;
+			addr = mtod(m, caddr_t) + skip;
+			goto skip_start;
+		} else {
+			skip -= m->m_len;
+	for (; m && len; m = m->m_next) {
+		if (m->m_len == 0)
+			continue;
+		mlen = m->m_len;
+		addr = mtod(m, caddr_t);
+skip_start:
+		if (len < mlen)
+			mlen = len;
+		if ((clen ^ (uintptr_t) addr) & 1)
+			sum += in_cksumdata(addr, mlen) << 8;
+		else
+			sum += in_cksumdata(addr, mlen);
+		clen += mlen;
+		len -= mlen;
+	REDUCE16;
+	return (~sum & 0xffff);
+	u_int64_t sum = in_cksumdata(ip, sizeof(struct ip));
+	REDUCE16;
diff --git a/libbsd.py b/libbsd.py
index 7593e9ba..2af1741b 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -177,6 +177,7 @@ class rtems(builder.Module):
                 'local/ofw_if.c',
                 'local/pcib_if.c',
                 'local/pci_if.c',
+                'local/xdma_if.c',
                 'local/usb_if.c',
                 'local/mmcbus_if.c',
                 'local/mmcbr_if.c',
@@ -1642,6 +1643,39 @@ class dev_nic_e1000(builder.Module):
             mm.generator['source']()
+# NIC xilinx
+class dev_nic_xilinx(builder.Module):
+    def __init__(self, manager):
+        super(dev_nic_xilinx, self).__init__(manager, type(self).__name__)
+    def generate(self):
+        mm = self.manager
+        self.addKernelSpaceHeaderFiles(
+                'sys/dev/xilinx/if_xaereg.h',
+                'sys/dev/xilinx/if_xaevar.h',
+                'sys/dev/mii/tiphy.h',
+                'sys/dev/xdma/xdma.h',
+                'sys/dev/xilinx/axidma.h',
+        self.addKernelSpaceSourceFiles(
+                'sys/dev/xilinx/if_xae.c',
+                'sys/dev/xdma/xdma.c',
+                'sys/dev/xdma/xdma_mbuf.c',
+                'sys/dev/xdma/xdma_queue.c',
+                'sys/dev/xdma/xdma_sg.c',
+                'sys/dev/xdma/xdma_bank.c',
+                'sys/dev/xdma/xdma_sglist.c',
+                'sys/dev/xilinx/axidma.c',
+            mm.generator['source']()
 # DEC Tulip aka Intel 21143
@@ -5172,6 +5206,7 @@ class in_cksum(builder.Module):
         self.addCPUDependentFreeBSDHeaderFiles(
                 'sys/i386/include/in_cksum.h',
+                'sys/microblaze/include/in_cksum.h',
                 'sys/mips/include/in_cksum.h',
                 'sys/powerpc/include/in_cksum.h',
                 'sys/sparc64/include/in_cksum.h',
@@ -5206,6 +5241,13 @@ class in_cksum(builder.Module):
+        self.addCPUDependentFreeBSDSourceFiles(
+            [ 'microblaze' ],
+                'sys/microblaze/microblaze/in_cksum.c',
             [ 'powerpc' ],
@@ -5593,6 +5635,7 @@ def load(mm):
     mm.addModule(dev_nic_re(mm))
     mm.addModule(dev_nic_fxp(mm))
     mm.addModule(dev_nic_e1000(mm))
+    mm.addModule(dev_nic_xilinx(mm))
     mm.addModule(dev_nic_dc(mm))
     mm.addModule(dev_nic_smc(mm))
     mm.addModule(dev_nic_broadcomm(mm))
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 46df17b4..abbafbad 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -272,6 +272,14 @@ RTEMS_BSD_DRIVER_PC_LEGACY;
 RTEMS_BSD_DRIVER_PCI_DC;
 RTEMS_BSD_DRIVER_UKPHY;
-#endif /* LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H */
+#elif defined(LIBBSP_MICROBLAZE_FPGA_BSP_H)
+RTEMS_BSD_DEFINE_NEXUS_DEVICE(ofwbus, 0, 0, NULL);
+SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
+SYSINIT_DRIVER_REFERENCE(xae, simplebus);
+SYSINIT_DRIVER_REFERENCE(axidma, simplebus);
+RTEMS_BSD_DRIVER_E1000PHY;
+#endif /* LIBBSP_MICROBLAZE_FPGA_BSP_H */
 #endif
diff --git a/rtemsbsd/include/rtems/bsd/local/xdma_if.h b/rtemsbsd/include/rtems/bsd/local/xdma_if.h
index 00000000..e5271f60
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/xdma_if.h
@@ -0,0 +1,144 @@
+ * This file is produced automatically.
+ * Do not modify anything in here by hand.
+ * Created from source file
+ *   xdma_if.m
+ * with
+ *   makeobjops.awk
+ * See the source file for legal information
+#ifndef _xdma_if_h_
+#define _xdma_if_h_
+/** @brief Unique descriptor for the XDMA_CHANNEL_REQUEST() method */
+extern struct kobjop_desc xdma_channel_request_desc;
+/** @brief A function implementing the XDMA_CHANNEL_REQUEST() method */
+typedef int xdma_channel_request_t(device_t dev, struct xdma_channel *xchan,
+                                   struct xdma_request *req);
+static __inline int XDMA_CHANNEL_REQUEST(device_t dev,
+                                         struct xdma_channel *xchan,
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_request);
+	rc = ((xdma_channel_request_t *) _m)(dev, xchan, req);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_CHANNEL_PREP_SG() method */
+extern struct kobjop_desc xdma_channel_prep_sg_desc;
+/** @brief A function implementing the XDMA_CHANNEL_PREP_SG() method */
+typedef int xdma_channel_prep_sg_t(device_t dev, struct xdma_channel *xchan);
+static __inline int XDMA_CHANNEL_PREP_SG(device_t dev,
+                                         struct xdma_channel *xchan)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_prep_sg);
+	rc = ((xdma_channel_prep_sg_t *) _m)(dev, xchan);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_CHANNEL_CAPACITY() method */
+extern struct kobjop_desc xdma_channel_capacity_desc;
+/** @brief A function implementing the XDMA_CHANNEL_CAPACITY() method */
+typedef int xdma_channel_capacity_t(device_t dev, struct xdma_channel *xchan,
+                                    uint32_t *capacity);
+static __inline int XDMA_CHANNEL_CAPACITY(device_t dev,
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_capacity);
+	rc = ((xdma_channel_capacity_t *) _m)(dev, xchan, capacity);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_CHANNEL_SUBMIT_SG() method */
+extern struct kobjop_desc xdma_channel_submit_sg_desc;
+/** @brief A function implementing the XDMA_CHANNEL_SUBMIT_SG() method */
+typedef int xdma_channel_submit_sg_t(device_t dev, struct xdma_channel *xchan,
+                                     struct xdma_sglist *sg, uint32_t sg_n);
+static __inline int XDMA_CHANNEL_SUBMIT_SG(device_t dev,
+                                           uint32_t sg_n)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_submit_sg);
+	rc = ((xdma_channel_submit_sg_t *) _m)(dev, xchan, sg, sg_n);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_OFW_MD_DATA() method */
+extern struct kobjop_desc xdma_ofw_md_data_desc;
+/** @brief A function implementing the XDMA_OFW_MD_DATA() method */
+typedef int xdma_ofw_md_data_t(device_t dev, pcell_t *cells, int ncells,
+                               void **data);
+static __inline int XDMA_OFW_MD_DATA(device_t dev, pcell_t *cells, int ncells,
+                                     void **data)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_ofw_md_data);
+	rc = ((xdma_ofw_md_data_t *) _m)(dev, cells, ncells, data);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_CHANNEL_ALLOC() method */
+extern struct kobjop_desc xdma_channel_alloc_desc;
+/** @brief A function implementing the XDMA_CHANNEL_ALLOC() method */
+typedef int xdma_channel_alloc_t(device_t dev, struct xdma_channel *xchan);
+static __inline int XDMA_CHANNEL_ALLOC(device_t dev, struct xdma_channel *xchan)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_alloc);
+	rc = ((xdma_channel_alloc_t *) _m)(dev, xchan);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_CHANNEL_FREE() method */
+extern struct kobjop_desc xdma_channel_free_desc;
+/** @brief A function implementing the XDMA_CHANNEL_FREE() method */
+typedef int xdma_channel_free_t(device_t dev, struct xdma_channel *xchan);
+static __inline int XDMA_CHANNEL_FREE(device_t dev, struct xdma_channel *xchan)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_free);
+	rc = ((xdma_channel_free_t *) _m)(dev, xchan);
+	return (rc);
+/** @brief Unique descriptor for the XDMA_CHANNEL_CONTROL() method */
+extern struct kobjop_desc xdma_channel_control_desc;
+/** @brief A function implementing the XDMA_CHANNEL_CONTROL() method */
+typedef int xdma_channel_control_t(device_t dev, struct xdma_channel *xchan,
+                                   int cmd);
+static __inline int XDMA_CHANNEL_CONTROL(device_t dev,
+                                         struct xdma_channel *xchan, int cmd)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,xdma_channel_control);
+	rc = ((xdma_channel_control_t *) _m)(dev, xchan, cmd);
+	return (rc);
+#endif /* _xdma_if_h_ */
diff --git a/rtemsbsd/local/xdma_if.c b/rtemsbsd/local/xdma_if.c
index 00000000..574d9598
--- /dev/null
+++ b/rtemsbsd/local/xdma_if.c
@@ -0,0 +1,57 @@
+ *   xdma_if.m
+ * with
+ *   makeobjops.awk
+#include <sys/queue.h>
+#include <sys/kernel.h>
+#include <sys/kobj.h>
+#include <machine/bus.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <rtems/bsd/local/xdma_if.h>
+struct kobjop_desc xdma_channel_request_desc = {
+	0, { &xdma_channel_request_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_channel_prep_sg_desc = {
+	0, { &xdma_channel_prep_sg_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_channel_capacity_desc = {
+	0, { &xdma_channel_capacity_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_channel_submit_sg_desc = {
+	0, { &xdma_channel_submit_sg_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_ofw_md_data_desc = {
+	0, { &xdma_ofw_md_data_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_channel_alloc_desc = {
+	0, { &xdma_channel_alloc_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_channel_free_desc = {
+	0, { &xdma_channel_free_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc xdma_channel_control_desc = {
+	0, { &xdma_channel_control_desc, (kobjop_t)kobj_error_method }
diff --git a/rtemsbsd/rtems/rtems-kernel-vmem.c b/rtemsbsd/rtems/rtems-kernel-vmem.c
index f64fbd17..70708902 100644
--- a/rtemsbsd/rtems/rtems-kernel-vmem.c
+++ b/rtemsbsd/rtems/rtems-kernel-vmem.c
@@ -41,6 +41,11 @@
 static MALLOC_DEFINE(M_VMEM, "vmem", "VMEM buffers");
+int vmem_add(vmem_t *vm, vmem_addr_t addr, vmem_size_t size, int flags)
+	return 0;
 int
 vmem_alloc(vmem_t *vm, vmem_size_t size, int flags, vmem_addr_t *addrp)
@@ -48,6 +53,18 @@ vmem_alloc(vmem_t *vm, vmem_size_t size, int flags, vmem_addr_t *addrp)
 	return 0;
+static int dummy_vmem;
+vmem_t *vmem_create(const char *name, vmem_addr_t base,
+    vmem_size_t size, vmem_size_t quantum, vmem_size_t qcache_max, int flags)
+	return &dummy_vmem;
+void vmem_destroy(vmem_t *vm)
 void
 vmem_free(vmem_t *vm, vmem_addr_t addr, vmem_size_t size)
2.30.2
