[PATCHES] Fix PPP in libbsd and optimize ATSAM console
Christian MAUDERER
christian.mauderer at embedded-brains.de
Fri Jan 21 10:57:59 UTC 2022
Ping.
Am 18.01.22 um 12:22 schrieb Christian MAUDERER:
> Hello,
> I noted that I still have this patch set open. I first posted it in
> August 2021 and later pinged it in September 2021. Both times no
> conclusion has been found. I would like to finally finish this topic and
> get the patches in an acceptable state. To simplify it a bit, let's only
> discuss the following two:
> * [PATCH rtems 2/2] termios: Pass number of sent chars to l_start
> https://lists.rtems.org/pipermail/devel/2021-August/068892.html
> * [PATCH rtems-libbsd] ppp: Fix transmitting data
> https://lists.rtems.org/pipermail/devel/2021-August/068893.html
> The third one (or rather first one) is a BSP specific optimization and
> not necessary for the other two. I'll not push that together with these
> two. I'll start a separate discussion for it as soon as we are done with
> these two.
> From my point of view, the best case would be to apply the patches to
> master and 5. Back when I started the discussion I created tickets for
> both:
> https://devel.rtems.org/ticket/4493
> https://devel.rtems.org/ticket/4494
> @Gedare: In the following mail thread you asked about tests on further
> BSPs:
> https://lists.rtems.org/pipermail/devel/2021-August/068908.html
> I now finally tested the patches on an i.MXRT BSP. PPP works with the
> patches and doesn't work without them on that target. That's what I
> expected. The patches are tested on three serial drivers now:
> - ATSAM and i.MXRT: Don't work without patches. Work with them.
> - SC16IS752: Works for small packets only without patches. Works well
> with them.
> @Chris: We had two open discussions:
> 1. A style topic:
> https://lists.rtems.org/pipermail/devel/2021-August/068912.html
> Like said there, I would prefer not to reformat the whole file as long
> as we don't do that at least a bit automatic for most files.
> 2. A discussion about the direction and the necessary API change:
> https://lists.rtems.org/pipermail/devel/2021-September/069468.html
> Like I explained: That PPP bug exists basically on all BSPs. Depending
> on how many bytes a serial driver can process in it's write function,
> PPP works better or worse. My assumption is that at the moment, the PPP
> runs only on BSPs where it is "well enough" that no one noted the bug.
> To fix that bug, the PPP needs the information how many characters have
> been sent out. My patch set uses our RTEMS default path via
> rtems_termios_dequeue_characters().
> I'm not entirely happy that I had to change the API. But I didn't find a
> better solution and the API is still compatible. It will only trigger a
> warning if someone doesn't use that extra parameter. If you have a
> better idea how the bug could be fixed, I'm open to adapt the patches.
> But I need a suggestion what would be a better solution because - like I
> said - I didn't find one.
> Best regards
> Christian
> Am 12.08.21 um 13:41 schrieb Christian Mauderer:
>> Hello,
>> this set of patches fixes PPP. Basically the current implementation in
>> libbsd can't work with console drivers that can't buffer a lot of
>> characters. The pppstart() function just assumes that the low level
>> console write can send an arbitrary number of characters without
>> checking how many characters are actually send.
>> In the extreme case of the ATSAM interfaces (only one character can be
>> send at once) it's not even possible to establish a PPP connection with
>> that. For UARTS that have some FIFO establishing might work but bigger
>> packets won't go through. I opened tickets for 6 and 5 here:
>> I would like to apply the patches to both branches (5 and 6).
>> The solution I implemented in this patch set is the following: PPP
>> output processing is done in the line discipline function l_start (or
>> rather the function where l_start points to: pppstart). Our device
>> writes don't return how many characters have been sent. Instead, that
>> feedback is given via rtems_termios_dequeue(). Luckily that's the
>> function that calls the l_start function.
>> The RTEMS patch for termios extends the l_start function so that it gets
>> the number of characters as a second argument. This extension shouldn't
>> be a problem for existing code. In the worst case it will trigger a
>> warning that the function doesn't match the pointer type. But in the
>> linked code, that additional argument will just be ignored.
>> The libbsd patch extends the pppstart function so that it then handles
>> that new information.
>> Patches belonging to this set:
>> * [PATCH rtems 1/2] bsps/atsam: Improve UART / USART tx performance
>> Best regards
>> Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
