[PATCHES] Fix PPP in libbsd and optimize ATSAM console
    Christian MAUDERER
    christian.mauderer at embedded-brains.de
    Thu Jan 27 12:25:52 UTC 2022
Hello,
again: What can I do to make the patches acceptable?
Best regards
Christian
Am 21.01.22 um 11:57 schrieb Christian MAUDERER:
> Ping.
> Am 18.01.22 um 12:22 schrieb Christian MAUDERER:
>> Hello,
>> I noted that I still have this patch set open. I first posted it in
>> August 2021 and later pinged it in September 2021. Both times no
>> conclusion has been found. I would like to finally finish this topic
>> and get the patches in an acceptable state. To simplify it a bit,
>> let's only discuss the following two:
>> * [PATCH rtems 2/2] termios: Pass number of sent chars to l_start
>>    https://lists.rtems.org/pipermail/devel/2021-August/068892.html
>> * [PATCH rtems-libbsd] ppp: Fix transmitting data
>>    https://lists.rtems.org/pipermail/devel/2021-August/068893.html
>> The third one (or rather first one) is a BSP specific optimization and
>> not necessary for the other two. I'll not push that together with
>> these two. I'll start a separate discussion for it as soon as we are
>> done with these two.
>>  From my point of view, the best case would be to apply the patches to
>> master and 5. Back when I started the discussion I created tickets for
>> both:
>>    https://devel.rtems.org/ticket/4493
>>    https://devel.rtems.org/ticket/4494
>> @Gedare: In the following mail thread you asked about tests on further
>> BSPs:
>> https://lists.rtems.org/pipermail/devel/2021-August/068908.html
>> I now finally tested the patches on an i.MXRT BSP. PPP works with the
>> patches and doesn't work without them on that target. That's what I
>> expected. The patches are tested on three serial drivers now:
>> - ATSAM and i.MXRT: Don't work without patches. Work with them.
>> - SC16IS752: Works for small packets only without patches. Works well
>> with them.
>> @Chris: We had two open discussions:
>> 1. A style topic:
>> https://lists.rtems.org/pipermail/devel/2021-August/068912.html
>> Like said there, I would prefer not to reformat the whole file as long
>> as we don't do that at least a bit automatic for most files.
>> 2. A discussion about the direction and the necessary API change:
>> https://lists.rtems.org/pipermail/devel/2021-September/069468.html
>> Like I explained: That PPP bug exists basically on all BSPs. Depending
>> on how many bytes a serial driver can process in it's write function,
>> PPP works better or worse. My assumption is that at the moment, the
>> PPP runs only on BSPs where it is "well enough" that no one noted the
>> bug.
>> To fix that bug, the PPP needs the information how many characters
>> have been sent out. My patch set uses our RTEMS default path via
>> rtems_termios_dequeue_characters().
>> I'm not entirely happy that I had to change the API. But I didn't find
>> a better solution and the API is still compatible. It will only
>> trigger a warning if someone doesn't use that extra parameter. If you
>> have a better idea how the bug could be fixed, I'm open to adapt the
>> patches. But I need a suggestion what would be a better solution
>> because - like I said - I didn't find one.
>> Best regards
>> Christian
>> Am 12.08.21 um 13:41 schrieb Christian Mauderer:
>>> Hello,
>>> this set of patches fixes PPP. Basically the current implementation in
>>> libbsd can't work with console drivers that can't buffer a lot of
>>> characters. The pppstart() function just assumes that the low level
>>> console write can send an arbitrary number of characters without
>>> checking how many characters are actually send.
>>> In the extreme case of the ATSAM interfaces (only one character can be
>>> send at once) it's not even possible to establish a PPP connection with
>>> that. For UARTS that have some FIFO establishing might work but bigger
>>> packets won't go through. I opened tickets for 6 and 5 here:
>>> I would like to apply the patches to both branches (5 and 6).
>>> The solution I implemented in this patch set is the following: PPP
>>> output processing is done in the line discipline function l_start (or
>>> rather the function where l_start points to: pppstart). Our device
>>> writes don't return how many characters have been sent. Instead, that
>>> feedback is given via rtems_termios_dequeue(). Luckily that's the
>>> function that calls the l_start function.
>>> The RTEMS patch for termios extends the l_start function so that it gets
>>> the number of characters as a second argument. This extension shouldn't
>>> be a problem for existing code. In the worst case it will trigger a
>>> warning that the function doesn't match the pointer type. But in the
>>> linked code, that additional argument will just be ignored.
>>> The libbsd patch extends the pppstart function so that it then handles
>>> that new information.
>>> Patches belonging to this set:
>>> * [PATCH rtems 1/2] bsps/atsam: Improve UART / USART tx performance
>>> Best regards
>>> Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
