[PATCH] cpukit: Prevent error with disabled stack checker
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jan 26 22:07:43 UTC 2022
When the stack checker is not enabled, the stack checker reporting
function can still be called. This prevents that call from performing a
null memory access in trying to find the high water mark if the stack
checker was never initialized.
This also introduces a test to ensure this call does not cause a crash.
Closes #4588
cpukit/libmisc/stackchk/check.c | 6 ++
spec/build/testsuites/libtests/grp.yml | 2 +
spec/build/testsuites/libtests/stackchk02.yml | 19 ++++++
testsuites/libtests/stackchk02/init.c | 67 +++++++++++++++++++
testsuites/libtests/stackchk02/stackchk02.doc | 16 +++++
testsuites/libtests/stackchk02/stackchk02.scn | 4 ++
6 files changed, 114 insertions(+)
create mode 100644 spec/build/testsuites/libtests/stackchk02.yml
create mode 100644 testsuites/libtests/stackchk02/init.c
create mode 100644 testsuites/libtests/stackchk02/stackchk02.doc
create mode 100644 testsuites/libtests/stackchk02/stackchk02.scn
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index a2b63345d9..9119f8d940 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -487,6 +487,12 @@ void rtems_stack_checker_report_usage_with_plugin(
uint32_t cpu_max;
uint32_t cpu_index;
+ /* Make sure that the stack checker is enabled */
+ if ( Stack_check_Interrupt_stack[ 0 ].area == NULL ) {
+ rtems_printf(printer, "RTEMS Stack Checker not enabled\n");
+ return;
rtems_printf(
printer,
" STACK USAGE BY THREAD\n"
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index cd5cc210e2..4717081312 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -249,6 +249,8 @@ links:
uid: stackchk
- role: build-dependency
uid: stackchk01
+- role: build-dependency
+ uid: stackchk02
uid: stat
diff --git a/spec/build/testsuites/libtests/stackchk02.yml b/spec/build/testsuites/libtests/stackchk02.yml
new file mode 100644
index 0000000000..4a4cbf9660
--- /dev/null
+++ b/spec/build/testsuites/libtests/stackchk02.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/stackchk02/init.c
+stlib: []
+target: testsuites/libtests/stackchk02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/libtests/stackchk02/init.c b/testsuites/libtests/stackchk02/init.c
index 0000000000..0904e37c68
--- /dev/null
+++ b/testsuites/libtests/stackchk02/init.c
@@ -0,0 +1,67 @@
+ * @file
+ * @ingroup libtests
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include <tmacros.h>
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE*3)
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
+#include <rtems/stackchk.h>
+const char rtems_test_name[] = "STACKCHK02";
+rtems_task Init(
+ rtems_task_argument argument
+ TEST_BEGIN();
+ rtems_stack_checker_report_usage();
+ TEST_END();
+ rtems_test_exit( 0 );
diff --git a/testsuites/libtests/stackchk02/stackchk02.doc b/testsuites/libtests/stackchk02/stackchk02.doc
index 0000000000..7907f216a8
--- /dev/null
+++ b/testsuites/libtests/stackchk02/stackchk02.doc
@@ -0,0 +1,16 @@
+# COPYRIGHT (c) 2022.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: stackchk02
+directives:
+ + rtems_stack_checker_report_usage
+concepts:
+ + This task verifies that the stack checker will not perform bad
+ accesses when not properly enabled.
diff --git a/testsuites/libtests/stackchk02/stackchk02.scn b/testsuites/libtests/stackchk02/stackchk02.scn
index 0000000000..233d7bf5c7
--- /dev/null
+++ b/testsuites/libtests/stackchk02/stackchk02.scn
@@ -0,0 +1,4 @@
+*** TEST STACKCHK02 ***
+RTEMS Stack Checker not enabled
+*** END OF TEST STACKCHK02 ***
2.30.2
