[PATCH] cpukit: Prevent error with disabled stack checker
Sebastian Huber
Thu Jan 27 07:20:19 UTC 2022
On 26/01/2022 23:07, Kinsey Moore wrote:
> diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
> index a2b63345d9..9119f8d940 100644
> --- a/cpukit/libmisc/stackchk/check.c
> +++ b/cpukit/libmisc/stackchk/check.c
> @@ -487,6 +487,12 @@ void rtems_stack_checker_report_usage_with_plugin(
> uint32_t cpu_max;
> uint32_t cpu_index;
> + /* Make sure that the stack checker is enabled */
> + if ( Stack_check_Interrupt_stack[ 0 ].area == NULL ) {
> + rtems_printf(printer, "RTEMS Stack Checker not enabled\n");
> + return;
> rtems_printf(
> printer,
> " STACK USAGE BY THREAD\n"
This check is insufficient in SMP configurations. It also prevents a
stack report without the stack usage information.
I would move the check to Stack_check_Dump_stack_usage(). Simply report
nothing if stack == NULL.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
