RISC-V BSP Build Failures on Ubuntu
Joel Sherrill
joel at rtems.org
Sat Jan 29 20:19:37 UTC 2022
Hi
https://lists.rtems.org/pipermail/build/2022-January/031425.html
bsp-builder is reporting this. Help appreciated. Looks like it could
be a tooling issue
Failures Report
1 posix-debug riscv/frdme310arty build:
configure: /home/tester/rtems-cron-6/rtems/waf configure\
--prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
/rtems-cron-6/rtems --rtems-config=config-riscv-frdme310arty-posix-\
debug.ini
error: ld/collect2:0 error: no error message found!
2 debug riscv/rv32i build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32i-debug.ini
3 network-debug riscv/rv32i build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32i-network-\
debug.ini
4 profiling riscv/rv32iac build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32iac-\
profiling.ini
5 debug riscv/rv32imac build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32imac-debug.ini
6 network-debug riscv/rv32imac build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32imac-network-\
debug.ini
