RISC-V BSP Build Failures on Ubuntu
Chris Johns
chrisj at rtems.org
Sun Jan 30 22:27:49 UTC 2022
On 30/1/22 7:19 am, Joel Sherrill wrote:
> Hi
> https://lists.rtems.org/pipermail/build/2022-January/031425.html
> bsp-builder is reporting this. Help appreciated. Looks like it could
> be a tooling issue
> Failures Report
> 1 posix-debug riscv/frdme310arty build:
> configure: /home/tester/rtems-cron-6/rtems/waf configure\
> --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
> /rtems-cron-6/rtems --rtems-config=config-riscv-frdme310arty-posix-\
> debug.ini
> error: ld/collect2:0 error: no error message found!
Could you please check the detailed and log and see what the actual error
message is? There is code in the bsp builder to handle these linker errors and
it seems it may need an update.
