New validation test suites
Sun Jan 30 22:26:14 UTC 2022
On 27/1/22 6:09 pm, Sebastian Huber wrote:
> On 27/01/2022 03:24, Chris Johns wrote:
>> On 25/1/22 5:37 pm, Sebastian Huber wrote:
>>> On 25/01/2022 01:09, Chris Johns wrote:
>>>> On 25/1/22 1:39 am, Sebastian Huber wrote:
>>>>> how do we want to proceed with the integration of the new validation test
>>>>> suite?
>>>>> At the moment it is not clear to me what issues are left to resolve and what I
>>>>> can do to address them?
>>>> I believe I have been clear about what I see as being needed:
>>>> https://lists.rtems.org/pipermail/devel/2022-January/070323.html
>>> Sorry, I don't know what I have to do next.
>> Sure and I am sorry if this was not clear.
>>> The release process for rtems-central is quite clear from my point of view.
>> I would not have raised this if I was in the same position. You are the only
>> person I know who understand rtems-central. I only have an overview of it and I
>> I am sorry but I have no spare time in invest in learning more about it. I do
>> have the responsibility of releasing RTEMS and if I accept these changes without
>> any of the needed support in place history has taught me I am left to provide
>> it. Tools and scripts that shows how a process is to work would go a long long
>> way to resolving this issue.
>> The RTEMS Release repo is a series of FreeBSD scripts I use to release ...
>> https://git.rtems.org/rtems-release/
>> I have not touched it in a while and it needs work to change it to support waf.
> Ok, I will update
> https://docs.rtems.org/branches/master/eng/release-process.html
> to account for rtems-central.git.
> It seems that there is some work to do to make an RTEMS 6.1 release happen in
> general (this issue is independent of the new validation tests). We should
> figure out which core developers can contribute what.
Yes and I would welcome that.
>>> We just have to create a
>>> release branch for RTEMS 6 and reference release branch commits in the
>>> submodules.
>> How do you validate the generated sources in the sub-modules match those in the
>> branched submodules? I think this should be done as part of the release
>> procedure to catch any mistakes.
> I will write something about this in the release procedure documentation.
Thank you, I appreciate this. This is a big help.
