[PATCH rtems-lwip v1 0/9] Bring in devel patches and add ZynqMP
Kinsey Moore
kinsey.moore at oarcorp.com
Sat Jul 2 02:18:50 UTC 2022
On 7/1/2022 18:50, Vijay Kumar Banerjee wrote:
> On Fri, Jul 1, 2022 at 5:49 PM Vijay Kumar Banerjee<vijay at rtems.org> wrote:
>> Hi Kinsey,
>> This patchset is looking great. Thank you!
>> Unfortunately, I won't be able to test the BBB right away but I see
>> that most patches are probably from the devel branch of lwip, which I
> correction: most of BBB related changes. :)
It should actually be all of the BBB related changes, I just squashed
some of them together since I was doing a pretty heavy rework anyway.
You mentioned on Discord that a couple of the patches didn't make it
through. You can find the entire patch set on top of main here:
https://github.com/KinseyMoore/rtems-lwip
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220701/4041aa36/attachment-0001.htm>
