[PATCH rtems-lwip v1 0/9] Bring in devel patches and add ZynqMP
Vijay Kumar Banerjee
vijay at rtems.org
Sat Jul 2 03:20:41 UTC 2022
On Fri, Jul 1, 2022 at 8:19 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> On 7/1/2022 18:50, Vijay Kumar Banerjee wrote:
> On Fri, Jul 1, 2022 at 5:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi Kinsey,
> This patchset is looking great. Thank you!
> Unfortunately, I won't be able to test the BBB right away but I see
> that most patches are probably from the devel branch of lwip, which I
> correction: most of BBB related changes. :)
> It should actually be all of the BBB related changes, I just squashed some of them together since I was doing a pretty heavy rework anyway.
Makes sense.
> You mentioned on Discord that a couple of the patches didn't make it through. You can find the entire patch set on top of main here:
> https://github.com/KinseyMoore/rtems-lwip
Thanks for posting the repo link.
Best regards,
Vijay
> Kinsey
