[tools] tester: Remove hard coded time limits for SIS
Mon Jul 4 08:52:29 UTC 2022
Remove the hard coded time limits in the SIS configurations which would
overrule the general tester settings (for example the--timeout command line
option).
 tester/rtems/testing/bsps/erc32-sis.ini      | 2 +-
 tester/rtems/testing/bsps/gr740-sis.ini      | 2 +-
 tester/rtems/testing/bsps/griscv-sis-cov.ini | 2 +-
 tester/rtems/testing/bsps/griscv-sis.ini     | 2 +-
 tester/rtems/testing/bsps/leon2-sis.ini      | 2 +-
 tester/rtems/testing/bsps/leon3-sis-cov.ini  | 2 +-
 tester/rtems/testing/bsps/leon3-sis.ini      | 2 +-
 7 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/tester/rtems/testing/bsps/erc32-sis.ini b/tester/rtems/testing/bsps/erc32-sis.ini
index fca2122..fe1eaa0 100644
--- a/tester/rtems/testing/bsps/erc32-sis.ini
+++ b/tester/rtems/testing/bsps/erc32-sis.ini
@@ -36,4 +36,4 @@ bsp          = erc32
 arch         = sparc
 tester       = %{_rtscripts}/run.cfg
 bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
-bsp_run_opts = -nouartrx -r -tlim 600 s
+bsp_run_opts = -nouartrx -r
diff --git a/tester/rtems/testing/bsps/gr740-sis.ini b/tester/rtems/testing/bsps/gr740-sis.ini
index b71048c..5f8dea7 100644
--- a/tester/rtems/testing/bsps/gr740-sis.ini
+++ b/tester/rtems/testing/bsps/gr740-sis.ini
@@ -35,4 +35,4 @@ bsp          = gr740
 arch         = sparc
-bsp_run_opts = -gr740 -nouartrx -r -tlim 200 s -m 4
+bsp_run_opts = -gr740 -nouartrx -r -m 4
diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
index 9ab37a8..e356a4d 100644
--- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
+++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
@@ -36,5 +36,5 @@ bsp            = griscv-sis
 arch           = riscv
-bsp_run_opts   = -nouartrx -r -tlim 300 s -m 4 -cov
+bsp_run_opts   = -nouartrx -r -m 4 -cov
 bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
diff --git a/tester/rtems/testing/bsps/griscv-sis.ini b/tester/rtems/testing/bsps/griscv-sis.ini
index b21cba1..8676ea5 100644
--- a/tester/rtems/testing/bsps/griscv-sis.ini
+++ b/tester/rtems/testing/bsps/griscv-sis.ini
@@ -36,4 +36,4 @@ bsp          = griscv
 arch         = riscv
diff --git a/tester/rtems/testing/bsps/leon2-sis.ini b/tester/rtems/testing/bsps/leon2-sis.ini
index 61205ad..844665c 100644
--- a/tester/rtems/testing/bsps/leon2-sis.ini
+++ b/tester/rtems/testing/bsps/leon2-sis.ini
@@ -36,4 +36,4 @@ bsp          = leon2
 arch         = sparc
-bsp_run_opts = -leon2 -nouartrx -r -tlim 200 s
+bsp_run_opts = -leon2 -nouartrx -r
diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini b/tester/rtems/testing/bsps/leon3-sis-cov.ini
index d8ffe28..59d415f 100644
--- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
+++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
@@ -36,5 +36,5 @@ bsp            = leon3-sis
 arch           = sparc
-bsp_run_opts   = -leon3 -nouartrx -r -tlim 200 s -cov
+bsp_run_opts   = -leon3 -nouartrx -r -cov
diff --git a/tester/rtems/testing/bsps/leon3-sis.ini b/tester/rtems/testing/bsps/leon3-sis.ini
index 2f933a7..afa9082 100644
--- a/tester/rtems/testing/bsps/leon3-sis.ini
+++ b/tester/rtems/testing/bsps/leon3-sis.ini
@@ -36,4 +36,4 @@ bsp          = leon3
 arch         = sparc
-bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -m 4
+bsp_run_opts = -leon3 -nouartrx -r -m 4
2.35.3
