[tools] tester: Remove hard coded time limits for SIS
Mon Jul 4 22:38:20 UTC 2022
OK
On 4/7/2022 6:52 pm, Sebastian Huber wrote:
> Remove the hard coded time limits in the SIS configurations which would
> overrule the general tester settings (for example the--timeout command line
> option).
>  tester/rtems/testing/bsps/erc32-sis.ini      | 2 +-
>  tester/rtems/testing/bsps/gr740-sis.ini      | 2 +-
>  tester/rtems/testing/bsps/griscv-sis-cov.ini | 2 +-
>  tester/rtems/testing/bsps/griscv-sis.ini     | 2 +-
>  tester/rtems/testing/bsps/leon2-sis.ini      | 2 +-
>  tester/rtems/testing/bsps/leon3-sis-cov.ini  | 2 +-
>  tester/rtems/testing/bsps/leon3-sis.ini      | 2 +-
>  7 files changed, 7 insertions(+), 7 deletions(-)
> diff --git a/tester/rtems/testing/bsps/erc32-sis.ini b/tester/rtems/testing/bsps/erc32-sis.ini
> index fca2122..fe1eaa0 100644
> --- a/tester/rtems/testing/bsps/erc32-sis.ini
> +++ b/tester/rtems/testing/bsps/erc32-sis.ini
> @@ -36,4 +36,4 @@ bsp          = erc32
>  arch         = sparc
>  tester       = %{_rtscripts}/run.cfg
>  bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> -bsp_run_opts = -nouartrx -r -tlim 600 s
> +bsp_run_opts = -nouartrx -r
> diff --git a/tester/rtems/testing/bsps/gr740-sis.ini b/tester/rtems/testing/bsps/gr740-sis.ini
> index b71048c..5f8dea7 100644
> --- a/tester/rtems/testing/bsps/gr740-sis.ini
> +++ b/tester/rtems/testing/bsps/gr740-sis.ini
> @@ -35,4 +35,4 @@ bsp          = gr740
>  arch         = sparc
> -bsp_run_opts = -gr740 -nouartrx -r -tlim 200 s -m 4
> +bsp_run_opts = -gr740 -nouartrx -r -m 4
> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> index 9ab37a8..e356a4d 100644
> --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> @@ -36,5 +36,5 @@ bsp            = griscv-sis
>  arch           = riscv
> -bsp_run_opts   = -nouartrx -r -tlim 300 s -m 4 -cov
> +bsp_run_opts   = -nouartrx -r -m 4 -cov
>  bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
> diff --git a/tester/rtems/testing/bsps/griscv-sis.ini b/tester/rtems/testing/bsps/griscv-sis.ini
> index b21cba1..8676ea5 100644
> --- a/tester/rtems/testing/bsps/griscv-sis.ini
> +++ b/tester/rtems/testing/bsps/griscv-sis.ini
> @@ -36,4 +36,4 @@ bsp          = griscv
>  arch         = riscv
> diff --git a/tester/rtems/testing/bsps/leon2-sis.ini b/tester/rtems/testing/bsps/leon2-sis.ini
> index 61205ad..844665c 100644
> --- a/tester/rtems/testing/bsps/leon2-sis.ini
> +++ b/tester/rtems/testing/bsps/leon2-sis.ini
> @@ -36,4 +36,4 @@ bsp          = leon2
>  arch         = sparc
> -bsp_run_opts = -leon2 -nouartrx -r -tlim 200 s
> +bsp_run_opts = -leon2 -nouartrx -r
> diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> index d8ffe28..59d415f 100644
> --- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> @@ -36,5 +36,5 @@ bsp            = leon3-sis
>  arch           = sparc
> -bsp_run_opts   = -leon3 -nouartrx -r -tlim 200 s -cov
> +bsp_run_opts   = -leon3 -nouartrx -r -cov
> diff --git a/tester/rtems/testing/bsps/leon3-sis.ini b/tester/rtems/testing/bsps/leon3-sis.ini
> index 2f933a7..afa9082 100644
> --- a/tester/rtems/testing/bsps/leon3-sis.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis.ini
> @@ -36,4 +36,4 @@ bsp          = leon3
>  arch         = sparc
> -bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -m 4
> +bsp_run_opts = -leon3 -nouartrx -r -m 4
