[tools] tester: Remove hard coded time limits for SIS
Tue Jul 5 06:02:48 UTC 2022
On 05/07/2022 07:14, Chris Johns wrote:
> On 5/7/2022 2:58 pm, Sebastian Huber wrote:
>> On 05/07/2022 03:08, Chris Johns wrote:
>>> On 5/7/2022 9:44 am, Joel Sherrill wrote:
>>>> The limit removed in sis and tsim is the simulated cpu time used. If not using
>>>> that, the behavior of the tester is to let the simulator run for so much real
>>>> processor time.
>>>> Replacing these with a command line argument is probably good but just removing
>>>> these mean these simulators will just run much longer before being killed.
>>>> How best to capture the distinction between target run time and host run time?
>>> Thank you for the explanation. I was not sure how the option effected things and
>>> yes it does matter we have this set correctly.
>>> Options can be set in the $HOME/.rtemstesterrc is via the --user-config option.
>>> Maybe this can be used to control the time out for specific user tests?
>> I would not make this more complicated than necessary. We have a --timeout
>> command line option and the default timeout value can be set by *.ini files. The
>> simulator speed is just a detail similar to running a target at 100MHz or 1GHz.
> It is actually simpler to have this option and to measure time against the cpu
> time. The work loads on SMP hosts with qemu shows simulation timeouts are
> difficult to get right.
I don't know what is wrong with the patch. Overruling command line
options is just bad.
>>> Sebastian, are some of the standard testsuite test's failing because of this
>>> setting?
>> Yes, with -O0 and code coverage enabled the tests run longer than usual.
> Looks to me like the timeout may need to be adjusted?
One of the performance tests needed 14 minutes on a fast computer. I
would keep the timeouts as is for now. There is more work to do before
the gcov coverage is generally usable.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
