[tools] tester: Remove hard coded time limits for SIS
Tue Jul 5 05:14:02 UTC 2022
On 5/7/2022 2:58 pm, Sebastian Huber wrote:
> On 05/07/2022 03:08, Chris Johns wrote:
>> On 5/7/2022 9:44 am, Joel Sherrill wrote:
>>> The limit removed in sis and tsim is the simulated cpu time used. If not using
>>> that, the behavior of the tester is to let the simulator run for so much real
>>> processor time.
>>> Replacing these with a command line argument is probably good but just removing
>>> these mean these simulators will just run much longer before being killed.
>>> How best to capture the distinction between target run time and host run time?
>> Thank you for the explanation. I was not sure how the option effected things and
>> yes it does matter we have this set correctly.
>> Options can be set in the $HOME/.rtemstesterrc is via the --user-config option.
>> Maybe this can be used to control the time out for specific user tests?
> I would not make this more complicated than necessary. We have a --timeout
> command line option and the default timeout value can be set by *.ini files. The
> simulator speed is just a detail similar to running a target at 100MHz or 1GHz.
It is actually simpler to have this option and to measure time against the cpu
time. The work loads on SMP hosts with qemu shows simulation timeouts are
difficult to get right.
>> Sebastian, are some of the standard testsuite test's failing because of this
>> setting?
> Yes, with -O0 and code coverage enabled the tests run longer than usual.
Looks to me like the timeout may need to be adjusted?
